GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
11-27-2007, 18:29 | #153 (permalink) |
Registered User Join Date: Sep 2007
Member: 587673 Status: Offline Thanks Meter: 0 | i have the same problem as titan05. my maps are locked and whichever code the keygen generated didn't work. i put everything in the right place (SW.UNL and GMAPSUPP.UNL) and everytime i open the garmin mobile xt on my phone, it says, "cannot unlock maps for garmin device and unit id 2896172285, do you want to unlock now?" then when i go to the about on the software, it just says, "unlock esn: 538760680" what do i do now? |
11-27-2007, 18:33 | #154 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
Put that in the key gen and get your code which is save as SW.UNL and GMAPSUPP.UNL | |
11-27-2007, 18:42 | #156 (permalink) |
Member: 587673 Status: Offline Thanks Meter: 0 | oh yeah, another question.. for the City Navigator North America NT 2008.. did you use all of the map products in it or did you select the ones you needed? cause i only selected california. |
11-27-2007, 19:44 | #159 (permalink) | ||
No Life Poster Join Date: Dec 2003 Location: Wien,Austria
Member: 45985 Status: Offline Thanks Meter: 96 | Quote:
Put it in SW.UNL file. After that calculate (using same unit ID) map unlock code and put it inside GMAPSUPP.UNL. Overwrite old files in garmin folder and test it br gjurobrod | ||
11-27-2007, 20:14 | #160 (permalink) |
Junior Member Join Date: Nov 2007
Member: 636361 Status: Offline Thanks Meter: 0 | No Map Hi Guys, I wonder if anyone can help me with this...... I have installed the program successfully, the internal gps is active, however no map is being found. I have copied the "img" file into the Garmin directory along with the gmapsupp and SW files (minus the .txt). There just doesn't seem to be a map detected (I am using the Great Britain map). Any ideas?? Cheers in advance for any help............... |
11-27-2007, 20:27 | #161 (permalink) | |
11-27-2007, 20:48 | #162 (permalink) | |
Member: 636361 Status: Offline Thanks Meter: 0 | Yes Quote:
Hi. Yes I have saved them properly. I'm thinking the map that I have (which was posted earlier in this thread) is a dudd. I just cannot understand why else it would be showing a black screen and 'no map' message. Think its a lost cause......ashame as the interface looks to kick route 66's botty. Thanks for your suggestion titin05. | |
11-27-2007, 21:52 | #164 (permalink) | |
Freak Poster Join Date: Oct 2003
Member: 41063 Status: Offline Thanks Meter: 9 | Quote:
ok, thanks all for this great news... about product codes.. what code is for portugal? | |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
help with Garmin XT 4.10.60 S60 please?? | se1boy | GPS devices , Navigators & Maps | 22 | 06-23-2008 05:48 |
Garmin XT 4.10.80 (taiwan) | titan05 | Nokia Multimedia | 5 | 03-23-2008 04:27 |
Garmin XT 4.10.60 S60 | deankanonik | GPS devices , Navigators & Maps | 9 | 01-09-2008 22:01 |
Garmin XT 4.10.20 PROBLEM | slososk | GPS devices , Navigators & Maps | 14 | 12-28-2007 00:41 |
