PHP Code:
[QUOTE=mike2111;4845001][SIZE=7]Let us all share our maps ![/SIZE]
[SIZE=6]Requirements for maps to be included in the list:[/SIZE]
[SIZE=3][INDENT]1) [COLOR=orange][B]All maps must be MapSource versions[/B][/COLOR][B] - not gmapsupp.img[/B];
2) [COLOR=orange][B]The map must be routable[/B][/COLOR][B], and may not be prepared from a gmapsupp.img map[/B];
3) New / Other maps to be included in the list must be in a better resolution than the existing maps.[/INDENT][/SIZE]
[SIZE=4]If you have a map, or have knowledge of a map that meets these requirements, please post the link here. Thank you![/SIZE]
[SIZE=4]If you find this post useful, please say thank you..... :D[/SIZE]
[SIZE=5]What is the advantage of using MapSource?[/SIZE]
I think the MapSource program is pretty much a 'must have'. In addition to the ability to load maps, the MapSource software has a lot of other capabilities, for example:
[LIST][*]Maybe you are lucky. Maybe you can have up till 6 maps on your phone at the same time eg. gmapbmap.img (Basemap), gmapprom.img (internal map, used when you have US or EU maps), gmapprom1.img (internal map, used when you have both US and EU maps), gmapsupp.img (Supplemental maps, will be overwritten when you add new maps), gmapsup2.img and gmapoem.img (For OEM Company). But with MapSource you can have many more! (The maximum amount of map-tiles for your unit is the limiting factor.) You just merge more maps together so they will appear as one file (gmapsupp.img) on your device[*]See all the cities, selected map details and POIs on your computer;[*]Set up routes and find out distances. Helps you get an overall picture;[*]Create and transfer waypoints to your device;[*]View and edit .GPX (POI) files;[*]Backup your waypoints from your device to a database (*.gdb) file on your computer;[*]Find the lat/long positions of waypoints;[*]Add description comments to your favourites/waypoints, like addresses and phone numbers;[*]Interact seamlessly with [I]Google Earth[/I][/LIST]
[SIZE=6]How to ...[/SIZE]
[SIZE=5]Prepare your Garmin-device, Mobile, PDA[/SIZE]
[LIST][*][SIZE=4]Nüvi, StreetPilot, etc.[/SIZE]
Download the webupdater to update your device: [URL]http://www8.garmin.com/software/WebUpdaterforWindows_242.exe [/URL][*][SIZE=4]Garmin Mobile PC[/SIZE]
Download the software here: [URL]http://www8.garmin.com/software/GarminMobilePC_50060.exe[/URL][*][SIZE=4]Phones, PDA, etc.[/SIZE][LIST=1][*]Install Garmin Mobile XT Free Basemap: [URL]http://www8.garmin.com/software/GarminMobileXTFreeBasemap_4xxxx.exe[/URL][*]Install Garmin Mobile XT Support Files: [URL]http://www8.garmin.com/software/GarminMobileXTSupportFiles_4xxxx.exe[/URL][*]Install the software for your phone, eg. [URL="http://www8.garmin.com/software/GarminMobileXTforSymbianS603rdEdition_50050.exe"]Garmin Mobile XT for Symbian S60 3rd Edition[/URL]. If your phone uses a different OS find the correct Garmin software [URL="http://www8.garmin.com/support/collection.jsp?product=010-11034-00"]here[/URL].[*]Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card.[*]Start the application.[*]Select settings for text language, voice, unit and for Garmin Online.[*]Exit the application.[*]Open the file called GarminDevice.xml. It is located in the Garmin folder.[*]Look for [I]<Id>XXXXXXXXXX</Id>[/I].[*]Use the [URL="http://www.filefactory.com/file/agcf6hf/n/JM5Digit_rar"]Keygenerator[/URL] to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL[U].txt[/U]) using Notepad. The file should be saved in the Garmin folder. As default Notepad will save your file as a text file! You have to choose “save as” and change the file name from .txt to ALL FILES.[/LIST]
More info [URL="http://www.megaupload.com/?d=UF9MMFF3"]here[/URL]. (Thank you Fugglefeet)
If you - after following the previous steps - start the application get a screen with [I]1) Purchase & Go!, 2) Begin Free Trial, 3) Enter Product Key, and 4) Connect to a Garmin GPS[/I], then you have done something wrong! Did you save the file as "just" [I]sw.unl[/I]? Did you save it into the garmin folder? Try to use your phones filemanager to locate the file and check it is called [I]sw.unl[/I] only.
If your phone, after unlocking, is looking for a Bluetooth GPS and not the internal GPS go to [I]TOOL[/I] > [I]SETTING[/I] > [I]SYSTEM[/I] > [I]REMOTE GPS[/I]. Choose [I]USE BUILT IN GPS[/I] > [I]ENABLE[/I] it then click [I]DONE[/I].[/LIST]
[SIZE=5]Install MapSource[/SIZE]
[LIST=1][*][URL="http://www8.garmin.com/software/MapSource_6137.exe"]Download[/URL] MapSource version 6.13.7
It isn't compatible with the newest maps (2009 NT) from Garmin but [U]it's the last MapSource version that provides you with the [I]Unlock Wizard[/I][/U] and also newer versions have compatibility issues with some free maps.[*]For a clean and fresh setup without any prior installation of MapSource[LIST=1][*]Extract the content of [I]MapSource_6137.exe[/I] (the file you downloaded in step 1) using WinRAR;[*]From the extracted files, run [I]MAIN.msi[/I];[*]Now run [I]Setup.exe[/I].[/LIST]If you don't follow these steps exactly as listed, MapSource will abort the setup-process with an [I]"Previous MapSource not found"[/I] error message.[*]Open [I]Windows Explorer[/I] and navigate to the directory where MapSource is located. (Probably C:\Garmin)[*]Rename [I]MapSource.exe[/I] into [I]MapSource_6-13-7.exe[/I]
If you want to have a localized version of MapSource you need to rename the corresponding .DLL too: In the same directory you'll find a lot of MapSourceXXX.dll files where XXX represents a language-code. (e.g. MapSourceRUS.dll = Russian, MapSourceDEU.dll = German, MapSourceESP.dll = Spanish, etc.). Pick the .DLL representing your language and rename it to MapSource_6-13-7XXX.dll (XXX being the language code) so you end up with e.g. MapSource_6-13-7RUS.DLL. Done.[*]The MapSource-installer has created shortcuts on your Desktop and in the Start-menu. You'll have to adjust them so that they[LIST][*]represent the MapSource version (renaming them from MapSource > Mapsource 6.13.7) and[*]point to the correct file (Properties > Link target)[/LIST]It's just a piece of cake to do that...[*]Now [URL="http://www8.garmin.com/software/MapSource_6156.exe"]download[/URL] MapSource 6.15.6 from Garmin and[*]install it. (Since you already have a installed version of MapSource you don't have to all the unpacking from above. Just run the .EXE)[*][COLOR=silver]There is a patched version of MapSource 6.15.6, allowing you to save map-sets (.IMG) not only to SD-cards and Garmin-devices but to any of your local drives. If you want it, download it from [URL="http://www.mediafire.com/download.php?oyw3yzoygww"]here[/URL].[/COLOR][*]Follow the above steps 3. - 5. accordingly to rename the file(s).
Congratulations, you have two simultaneous installations of MapSource and can now enjoy all the features.[/LIST]
[SIZE=5]Install maps[/SIZE]
[LIST=1][*]Download the map you want;[*]Install the map using the file called something with XXXXXX_ENU.msi - Not the Setup.exe - This will install the map only (this applies to "real" Garmin maps only – with other maps the file might just be called setup.exe);[*]Unlock the map:[LIST][*]Get a key generator which you can find [URL="http://www.filefactory.com/file/agcf6hf/n/JM5Digit_rar"]here[/URL];[*]Enter your GPS ID number and enter your MapID (scroll down to “custom maps”) in the key generator, and you have the unlock-code.[*]Launch MapSource;[*]In MapSource, click [I]Utilities[/I] >[I] Manage Map Products[/I];[*]Select the [I]Unlock Regions[/I] tab, and click [I]Add[/I];[*]Enter your 25-character unlock code and then a comment, if desired. Click [I]OK[/I].[/LIST]For more info read the [URL="http://www8.garmin.com/manuals/MapSource_MapSourceUsersGuide.pdf"]MapSource user guide[/URL][/LIST]If you would like to have more maps, e.g. [I]Garmin City Navigator Europe NT 2009[/I] and [I]Garmin City Navigator North America NT 2009[/I] you can combine the maps and transfer them to your GPS.
Try it! ;)
[SIZE=5]Use Basemaps[/SIZE]
[LIST][*][I]What is a Basemap?[/I]
A Basemap is a map with limited detail and precision.[*][I]Limited? So, what it is good for?[/I]
It serves two purposes:[LIST=1][*]It gives you the possibility to navigate where none of you regular maps provides coverage.[*]When you zoom out on your device it would take lots of processor power - and therefore time - to draw all the details of your regular map. Hence in such moments your device uses the Basemap.[/LIST][*][I]Isn't my device factory equipped with a Basemap?[/I]
Yes, it is. Garmin sells their equipment with one of two preinstalled Basemaps: [I]Americas lite[/I] or [I]Atlantic lite[/I].[*][I]So why should I want different Basemap?[/I]
The two pre-installed Basemaps are limited to their region. They don't provide you with world-wide coverage.[*][I]But there is a [/I]WorldMap[I] from Garmin. Why not use it instead?[/I]
It has no autorouting. :([*][I]You convinced me. What shall I do?[/I]
Follow these steps:
[LIST=1][*]Download the [URL="http://www8.garmin.com/software/iQue3600World-WideBasemap_301.exe"][I]World-Wide routable Basemap v3.01[/I][/URL] from the Garmin Website. ([URL="http://www8.garmin.com/include/basemaps/worldwide_autoroute_iQue.html"]Here[/URL] you can learn about the coverage.)[*][B]Don't[/B] run the .EXE! Instead open it with - for example - WinRAR (Right-click).[*]Navigate within the archive to the [I]worldwide[/I] directory and extract the [I]GMAPBMAP.IMG[/I] file to some place on your computer.[*]Copy it into the [I]garmin[/I] directory on your device.[/LIST][*][I]But this will delete my existing Basemap?! Shouldn't I save or keep it?[/I]
Yes, that would forever delete your pre-installed Basemap. If you want to save or keep it you should either[LIST][*]copy the original file to your computer, a CD or a DVD for possible use in the future. ([U]Backups are always a very good idea![/U] and you should take the chance to make a backup of your entire device) or you[*]could rename the original Basemap to [I]gmapoem.img[/I] and keep it parallel to the new basemap. Your device will handle the rest.[/LIST][*][I]The file I downloaded says iQue 3600. Can i really use it for my device?[/I]
Yes, you can. The only devices you possibly wouldn't use it for are the new Garmin units with 3D terrain. But these are factory supplied with the [I]Worldwide Autoroute DEM Basemap[/I]. (If you accidentally deleted it, you can download a copy [URL="http://www.gpsunderground.com/forums/redirector.php?url=http%3A%2F%2Frapidshare.com%2Ffiles%2F105894187%2Fgmapbmap-WW_DEM-2007-08.rar"]here[/URL].)[/LIST]
[SIZE=5]Use POI Loader[/SIZE]
[I]POI Loader[/I] is a free program from Garmin for your computer that lets you upload customized points of interest (POIs) to your compatible Garmin device. With the help of [I]POI Loader[/I], you can update your compatible Garmin GPS with the latest restaurants, safety camera locations, tourist destinations, etc. More info about poi [URL="http://www.gpsinformation.org/penrod/poiloader/poiloader.html"]here[/URL], and about POI Loader [URL="http://www8.garmin.com/products/poiloader/"]here[/URL]
[SIZE=6]Map list[/SIZE]
Recent changes are marked in [COLOR=yellow]yellow[/COLOR].
[SIZE=5]EUROPE[/SIZE]
[LIST][*][SIZE=3]City Navigator Europe NT 2010.10[/SIZE] - MapID: 449
Commercial streetmap with [URL="https://buy.garmin.com/shop/shop.do?cID=253&pID=6299#coverageTab"]coverage[/URL] of [B]40 European countries[/B]
[URL="http://torrents.thepiratebay.org/4843881/Garmin.City.Navigator.Europe.NT.v2010.Update.4843881.TPB.torrent"]Download (Torrent)[/URL]
Download [URL="http://rapidshare.com/files/220966611/Jenas_City.Navigator.Europe.NT.v2010.10.part01.rar"]Part1[/URL] [URL="http://rapidshare.com/files/220970613/Jenas_City.Navigator.Europe.NT.v2010.10.part02.rar"]Part2[/URL] [URL="http://rapidshare.com/files/220974616/Jenas_City.Navigator.Europe.NT.v2010.10.part03.rar"]Part3[/URL] [URL="http://rapidshare.com/files/220978494/Jenas_City.Navigator.Europe.NT.v2010.10.part04.rar"]Part4[/URL] [URL="http://rapidshare.com/files/220982274/Jenas_City.Navigator.Europe.NT.v2010.10.part05.rar"]Part5[/URL] [URL="http://rapidshare.com/files/220986030/Jenas_City.Navigator.Europe.NT.v2010.10.part06.rar"]Part6[/URL] [URL="http://rapidshare.com/files/220989501/Jenas_City.Navigator.Europe.NT.v2010.10.part07.rar"]Part7[/URL] [URL="http://rapidshare.com/files/220993186/Jenas_City.Navigator.Europe.NT.v2010.10.part08.rar"]Part8[/URL] [URL="http://rapidshare.com/files/221074225/Jenas_City.Navigator.Europe.NT.v2010.10.part09.rar"]Part9[/URL] [URL="http://rapidshare.com/files/221074651/Jenas_City.Navigator.Europe.NT.v2010.10.part10.rar"]Part10[/URL] [URL="http://rapidshare.com/files/221074697/Jenas_City.Navigator.Europe.NT.v2010.10.part11.rar"]Part11[/URL] [URL="http://rapidshare.com/files/221074734/Jenas_City.Navigator.Europe.NT.v2010.10.part12.rar"]Part12[/URL] [URL="http://rapidshare.com/files/221074789/Jenas_City.Navigator.Europe.NT.v2010.10.part13.rar"]Part13[/URL] [URL="http://rapidshare.com/files/221074815/Jenas_City.Navigator.Europe.NT.v2010.10.part14.rar"]Part14[/URL] [URL="http://rapidshare.com/files/221074857/Jenas_City.Navigator.Europe.NT.v2010.10.part15.rar"]Part15[/URL] [URL="http://rapidshare.com/files/221074884/Jenas_City.Navigator.Europe.NT.v2010.10.part16.rar"]Part16[/URL] [URL="http://rapidshare.com/files/221074919/Jenas_City.Navigator.Europe.NT.v2010.10.part17.rar"]Part17[/URL] [URL="http://rapidshare.com/files/221074961/Jenas_City.Navigator.Europe.NT.v2010.10.part18.rar"]Part18[/URL] [URL="http://rapidshare.com/files/221075006/Jenas_City.Navigator.Europe.NT.v2010.10.part19.rar"]Part19[/URL] [URL="http://rapidshare.com/files/221075048/Jenas_City.Navigator.Europe.NT.v2010.10.part20.rar"]Part20[/URL] [URL="http://rapidshare.com/files/221075075/Jenas_City.Navigator.Europe.NT.v2010.10.part21.rar"]Part21[/URL] [URL="http://rapidshare.com/files/221075106/Jenas_City.Navigator.Europe.NT.v2010.10.part22.rar"]Part22[/URL] [URL="http://rapidshare.com/files/221075138/Jenas_City.Navigator.Europe.NT.v2010.10.part23.rar"]Part23[/URL] [URL="http://rapidshare.com/files/221075168/Jenas_City.Navigator.Europe.NT.v2010.10.part24.rar"]Part24[/URL] [URL="http://rapidshare.com/files/221075204/Jenas_City.Navigator.Europe.NT.v2010.10.part25.rar"]Part25[/URL] [URL="http://rapidshare.com/files/221075234/Jenas_City.Navigator.Europe.NT.v2010.10.part26.rar"]Part26[/URL] [URL="http://rapidshare.com/files/221075269/Jenas_City.Navigator.Europe.NT.v2010.10.part27.rar"]Part27[/URL] [URL="http://rapidshare.com/files/221075307/Jenas_City.Navigator.Europe.NT.v2010.10.part28.rar"]Part28[/URL] [URL="http://rapidshare.com/files/221075330/Jenas_City.Navigator.Europe.NT.v2010.10.part29.rar"]Part29[/URL] [URL="http://rapidshare.com/files/221075361/Jenas_City.Navigator.Europe.NT.v2010.10.part30.rar"]Part30[/URL] [URL="http://rapidshare.com/files/221075388/Jenas_City.Navigator.Europe.NT.v2010.10.part31.rar"]Part31[/URL] [URL="http://rapidshare.com/files/221075429/Jenas_City.Navigator.Europe.NT.v2010.10.part32.rar"]Part32[/URL] [URL="http://rapidshare.com/files/221075454/Jenas_City.Navigator.Europe.NT.v2010.10.part33.rar"]Part33[/URL] [URL="http://rapidshare.com/files/221075483/Jenas_City.Navigator.Europe.NT.v2010.10.part34.rar"]Part34[/URL] [URL="http://rapidshare.com/files/221075508/Jenas_City.Navigator.Europe.NT.v2010.10.part35.rar"]Part35[/URL] [URL="http://rapidshare.com/files/221075528/Jenas_City.Navigator.Europe.NT.v2010.10.part36.rar"]Part36[/URL] [URL="http://rapidshare.com/files/221075555/Jenas_City.Navigator.Europe.NT.v2010.10.part37.rar"]Part37[/URL] [URL="http://rapidshare.com/files/221075592/Jenas_City.Navigator.Europe.NT.v2010.10.part38.rar"]Part38[/URL] [URL="http://rapidshare.com/files/221075636/Jenas_City.Navigator.Europe.NT.v2010.10.part39.rar"]Part39[/URL] [URL="http://rapidshare.com/files/221076847/Jenas_City.Navigator.Europe.NT.v2010.10.part40.rar"]Part40[/URL] [URL="http://rapidshare.com/files/221076892/Jenas_City.Navigator.Europe.NT.v2010.10.part41.rar"]Part41[/URL] [URL="http://rapidshare.com/files/221076921/Jenas_City.Navigator.Europe.NT.v2010.10.part42.rar"]Part42[/URL] [URL="http://rapidshare.com/files/221076960/Jenas_City.Navigator.Europe.NT.v2010.10.part43.rar"]Part43[/URL] [URL="http://rapidshare.com/files/221077005/Jenas_City.Navigator.Europe.NT.v2010.10.part44.rar"]Part44[/URL] [URL="http://rapidshare.com/files/221077046/Jenas_City.Navigator.Europe.NT.v2010.10.part45.rar"]Part45[/URL] [URL="http://rapidshare.com/files/221077080/Jenas_City.Navigator.Europe.NT.v2010.10.part46.rar"]Part46[/URL] [URL="http://rapidshare.com/files/221077126/Jenas_City.Navigator.Europe.NT.v2010.10.part47.rar"]Part47[/URL] [URL="http://rapidshare.com/files/220965170/Jenas_City.Navigator.Europe.NT.v2010.10.part48.rar"]Part48[/URL][/LIST][LIST][*][SIZE=3]AdriaROUTE 2.30[/SIZE] - MapID: 708
Commercial streetmap of Albania, Bosnia and Herzegovina, Croatia, Macedonia, Slovenia
Source: [URL]http://www.navigo-sistem.hr/proizvod/370 /[/URL]
[URL="http://navigo-sistem.hr.lin6.c-a.hr/update/AdriaROUTE_2.30_CD_update.exe"]Download[/URL]
[URL="http://rs605.rapidshare.com/files/245477724/AdriaROUTE_2.30_CD_update.exe"]Mirror[/URL][/LIST][LIST][*][SIZE=3]Adria TOPO 2.10 - HR[/SIZE] - MapID: 928
Commercial topographic map of [B]Bosnia and Herzegovina[/B], [B]Croatia[/B] (original map scale 1:25.000)
[URL="http://navigo-sistem.hr.lin6.c-a.hr/update/AdriaTOPO_2.10_HR.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Adria TOPO 2.11 - SLO[/SIZE] - MapID: 844
Commercial topographic map of [B]Slovenia[/B] (original map scale 1:25.000)
[URL="http://www.garmin.si/custom/File/AdriaTOPO_2.11_SLO.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]SCG Route 2.0[/SIZE] - MapID: 929
Commercial streetmap of [B]Montenegro[/B], [B]Serbia[/B]
[URL="http://www.filefactory.com/file/agbgfh4/n/scg_update_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Belarus[/SIZE] - MapID: 4858
Free streetmap of [B]Belarus[/B] - No installer
Source: [URL]http://kartaby.clan.su/[/URL]
[URL="http://rapidshare.com/files/178084325/20081229By_en.zip"]Download (ENG - 2008-12-29)[/URL]
[URL="http://www.megaupload.com/?d=XDAJDKDE"]Download (RUS - 2009-09-07)[/URL][/LIST][LIST][*][SIZE=3]OFRM Bulgaria v4.90[/SIZE] - MapID: 5028
Free street- and offroad map of [B]Bulgaria[/B]
Source: [URL="http://forum.offroad-bulgaria.com/forumdisplay.php?f=94"]OFFRoad Bulgaria[/URL] (BG)
[URL="http://rapidshare.com/files/274789002/BGOFFRoadMapSETUP4.90.exe"]Download[/URL][/LIST][LIST][*][SIZE=3] Garmin MapSource Bulgaria Routeable (BG Route) v4.1[/SIZE] (Map Date: 25.08.2008)
Streetmap of [B]Bulgaria[/B]
[URL="http://www.rapidshare.com/files/140728168/BG_Route_4.2_20080828.rar"]Download[/URL]
[URL="http://torrents.thepiratebay.org/4616412/Garmin_MapSource_Bulgaria_Routeable_v4.1_(Map_Date__25.08.2008).4616412.TPB.torrent"]Download (torrent)[/URL][/LIST][LIST][*][SIZE=3]Atlas Czech v8 NT[/SIZE] - MapID: 1645
Commercial streetmap of the [B]Czech Republic[/B]
[SIZE=1]Providing full coverage of the road network with street level maps for more than 400 cities.[/SIZE]
[URL="http://rapidshare.com/files/215392347/haasteren_Atlas8.part1.rar"]Download, part 1[/URL]
[URL="http://rapidshare.com/files/215397205/haasteren_Atlas8.part2.rar"]Download, part 2[/URL]
[URL="http://rapidshare.com/files/215387711/haasteren_Atlas8.part3.rar"]Download, part 3[/URL][/LIST][LIST][*][SIZE=3]Topo Czech 3.0 PRO[/SIZE] - MapID: 1705
Commercial topographic map of the [B]Czech Republic[/B] (original map scale 1:10.000; effective scale 1:25.000)
[SIZE=1]The map supports automatic route calculation on road and street network and terrain shading in PC. The Topo map includes: cities, towns, road & street network, railroads, lakes, rivers, forests, elevation contour lines, trails.[/SIZE]
[URL="http://rapidshare.com/files/244941751/topo_czech_3_PRO.part1.rar"]Part 1[/URL] [URL="http://rapidshare.com/files/244944775/topo_czech_3_PRO.part2.rar"]Part 2[/URL] [URL="http://rapidshare.com/files/244947886/topo_czech_3_PRO.part3.rar"]Part 3[/URL] [URL="http://rapidshare.com/files/244954346/topo_czech_3_PRO.part4.rar"]Part 4[/URL] [URL="http://rapidshare.com/files/244955894/topo_czech_3_PRO.part5.rar"]Part 5[/URL][/LIST][LIST][*][SIZE=3]Cyprus Map v10[/SIZE] – No installer
Free streetmap of [B]Cyprus[/B]
Source: [URL="http://cymps.com/"]Cymps[/URL]
[URL="http://cymps.com/maps/Cyprus_CympsCom_v10.zip"]Download[/URL][/LIST][LIST][*][SIZE=3]Eesti Teejuht 21.11[/SIZE]
Commercial streetmap of [B]Estonia[/B] - No installer
[SIZE=1]Very detailed map with many topographic features but no contour lines.[/SIZE]
[URL="http://rapidshare.com/files/196840812/Jenas_Eestonia_Topo_EOMAP_21.11.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]NaviGuide Hungary 5.2 NT[/SIZE] - MapID: 709
Commercial streetmap of [B]Hungary[/B]
Source: [URL="http://www.garmin.hu/naviguide-magyarorszag-52 "]Garmin.hu[/URL]
[SIZE=1]Lakes, rivers, cities, motorways, national and regional thoroughfares, and local roads, plus street level maps for 3051 cities. Also contains nautical chart data for Lake Balaton, with depth contours, spot soundings, navaids with view range and coverage and port plans.[/SIZE]
[URL="http://www.garmin.hu/update/NaviGuide_v52NT.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Routeable TOPO map of Iceland 2009 NT[/SIZE] - MapID: 1471
Commercial topographic map of [B]Iceland[/B]
Source: [URL="http://garmin.is/product/kort/islandskort.shtml"]Garmin.is[/URL]
[URL="http://rapidshare.com/files/236649609/Iceland2009NT.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]GPS Kort Iceland v3.5[/SIZE] - MapID: 830
Commercial topographic map of [B]Iceland[/B] (original map scale 1:50.000)
Source: [URL="http://www.velasalan.is/"]Velasalan [/URL]
[SIZE=1]It features contour lines distanced 20 meters.[/SIZE]
[URL="http://www.filefactory.com/file/aggegb4/n/Iceland_rar"]Download (Torrent)[/URL]
[URL="http://torrents.ru/forum/download.php?id=807374"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Lietuvos Topo 1.071[/SIZE] - MapID: 857
Commercial topographic map of [B]Lithuania[/B]
[SIZE=1]The map provides 75.000km of highways, county and residential roads with street level detailed maps of all settlements in Lithuania. Other objects includes lakes, rivers & canals (110.000km), railway lines, Kauno marios, Kuršių marios.[/SIZE]
[URL="http://rapidshare.com/files/227170069/ltz_update1071nt.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]Moldova 14.04.2009[/SIZE] - MapID: 1964
Commercial streetmap of [B]Moldovia[/B]
Source: [URL="http://gps-skynet-md.ucoz.com/index/0-4"]Skynet[/URL]
[URL="http://rapidshare.com/files/270333195/Moldova14.04.2009.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]GPMapa 2009.1 NT[/SIZE] - MapID: 1710
Commercial streetmap of [B]Poland[/B]
Source: [URL="http://www.gpmapa.pl/en/"]GPMapa[/URL]
[SIZE=1]Version GPMapa 2009.1 includes over 2,3 millions of address points, 3069 detailed city and town plans, including 2686 plans provided with addresses and 277 plans bearing only names of the streets, 407 993 km of roads, including 308 039 km of asphalt roads. 167 965 points of interests (POI), including photoradars and "Black Points". 44 cities inclusive if the building outlines (Augustów, Bartoszyce, Białystok, Brodnica, Bydgoszcz, Bytom, Chełmno, Częstochowa, Elbląg, Gdańsk, Gdynia, Giżycko, Gorzów Wielkopolski, Iława, Katowice, Kętrzyn, Kielce, Kościerzyna, Kraków, Krosno Odrzańskie, Lublin, Łódź, Mrągowo, Myślenice, Olkusz, Olsztyn, Ostróda, Poznań, Pruszcz Gdański, Radom, Reda, Rzeszów, Sopot, Starogard Gdański, Szczecin, Szczytno, Tarnów, Tczew, Warszawa, Wieliczka, Wrocław, Września, Zabrze, Zielona Góra). Information about speed limits on selected national roads and 70 villages.[/SIZE]
[URL="http://rapidshare.com/files/248957739/GPMapa_2009.1_oem_NT.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]R.O.A.D. 2008 v3.01[/SIZE] - MapID: 1189
Commercial streetmap of [B]Romania[/B] (original map scale 1:100.000).
[SIZE=1]Covers all the cities, lakes and marshes of Romania, the Danube Delta and the shore of the Black Sea, all the large and middle size rivers, aprox. 75% of the small intermittent rivers and canals; european, national and state roads, highways A1 and A2; contour lines distanced 40 meters apart, railways, ******* runways, bathymetry data in a few selected areas in the Black Sea. Detailed maps reference scale 1:5000 or higher Detailed cities: Bucuresti, Suceava, Iasi, Oradea, Cluj-Napoca, Turda, Huedin, Timisoara, Arad, Targu Mures, Campulung Moldovenesc and Brasov (with street level information, city limits, industry, parks, forests, gardens, orchards and POIs) plus Danube Delta Dunarii (wetlands, canals, lakes, flats, toponames).[/SIZE]
Download [URL="http://www.megaupload.com/?d=PCOE24IH"]Part1[/URL] [URL="http://www.megaupload.com/?d=SMMXJNNS"]Part2[/URL] [URL="http://www.megaupload.com/?d=QFN5566G"]Part3[/URL]
[URL="http://torrents.thepiratebay.org/4587184/Garmin_MapSource_Romania_RO.A.D._2008_v3.1.4587184.TPB.torrent"]Mirror (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Garmin Romania Road 2009.10 3.02 (update of ROAD 2008 3.01)[/SIZE]
Install Romania Road 2008 first, then update with Romania Road 2009.10.
[URL="http://www.anonym.to/?http://www.romaniadigitala.ro/download/ROAD2009.10.updater.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Slovakia Roads v6[/SIZE] - MapID: 1315
Commercial streetmap of [B]Slovakia[/B]
Source: [URL="http://www.garmin.sk/?cls=stoitem&stiid=1009"]Garmin.sk[/URL]
[URL="http://www.conan.sk/Maps/SK_ROADS_v6.exe"]Download[/URL][/LIST][LIST][*][SIZE=3] [COLOR=yellow]Navcity Turkey 2009.06[/COLOR][/SIZE][COLOR=yellow] - MapID: 848[/COLOR]
Commercial streetmap of [B]Turkey[/B]
[SIZE=1] The Basarsoft NavCITY Turkey 2009.02 contains current routing Detailcards of 81 turkish cities (Istanbul, Ankara, Izmir, Adana, Antalya, Bursa, Samsun, Konya, Kayseri, Denizli, Diyarbakir...) and all Cities of the South-Westcoast from Alanya to Ayvalik with 786.199 km of streets and 318.071 Points of Interest. [URL="http://www.garmin.com.tr/index.php?page=alt_kategori_1&kat=83&alt_kat_id=221"]Coverage map[/URL][/SIZE]
[URL="http://rapidshare.com/files/277177648/200906ingilizcekilitli.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]Aeroscan Ukraine 4.03[/SIZE] - MapID: 934
Commercial streetmap of [B]Ukraine[/B]
[SIZE=1]Detailed map of the Ukraine and metropolitan maps of Kiev and about 80 other Ukrainian cities and towns. In some cities house numbers are provided. Includes business and residential streets, rivers, lakes and shoreline details.[/SIZE]
[URL="http://torrents.thepiratebay.org/4586568/Garmin_MapSource_Ukraine_%28Aeroscan%29_v4.03_English.4586568.TPB.torrent"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]CarteBlanche Ukraine 3.60[/SIZE] - MapID: 575
[SIZE=1]The map covers European, national, regional and local roads and provides detailed city maps of about 40 settlements including all regional centres as well as some other important cities. The remaining settlements are provided in the form of points and contours. It also shows railways, rivers, streams, lakes, parks, and forests.[/SIZE]
[URL="http://rapidshare.com/files/244213172/Garmin.Ukraine.CarteBlanche.MapSource.LAT.UKR.v3.60.zip"]Download[/URL]
[URL="http://depositfiles.com/files/s0yg7f7rn"]Mirror[/URL][/LIST][LIST][*][SIZE=3] NavLux Ukraine Navigator (30.06.2009)[/SIZE] - MapID: 1174
Source: [URL="http://garmin.luxena.com/"]Luxena Software Company[/URL]
[SIZE=1]Detailed map of the Ukraine with 250.000 km roads, 30.108 settlements and contours of buildings with address information.[/SIZE]
[URL="http://rapidshare.com/files/268123680/NavLux_Ukraine_Navigator_30.06.2009.rar"]Download[/URL][/LIST][LIST][SIZE=4]European POIs[/SIZE][LIST][*][SIZE=3]SpeedCams 20-05-2009 - Fix camera[/SIZE]
[URL="http://www.filefactory.com/file/ag1ad76/n/Speedcam_rar"]Download[/URL]
[SIZE=1]Speedcam covering A, AND, B, BIH, BR, CH, CZ, D, DK, E, F, FIN, FL, GB, GR, H, I, IRL, IS, L, LT, N, NL, P, PL, RO, RUS, S, SK, SLO and UA. Furthermore Swedish Road Toll & Austria Road Toll.
This one really works (with the right speed limit), and these alerts will sound and become visible once, as you approach the POI location. If you remain under the user specified speed, you will get no more alerts. However, if you exceed that specified speed, a beep will sound every second to remind you of the alert, until either you slow down below the set speed or pass the POI. All use is at your own risk.
To install just copy the 6 files into /garmin/POI/ on your device.
Based on data from [URL="http://www.poiplaza.com/index.php?p=ds&s=616"]POI Plaza[/URL], [URL="http://www.poi.cz/"]Poi.cz[/URL], [URL="http://www.poigps.com/"]Poigps.com[/URL], [URL="http://www.gratispoi.dk/"]gratispoi.dk[/URL] and [URL="http://www.speedcam****/"]Speedcam.tk[/URL][/SIZE][/LIST][/LIST]
[SIZE=5]RUSSIA[/SIZE]
[LIST][*][SIZE=3]Roads of Russia v4.03[/SIZE] (translit.) - MapID: 1120
Commercial map of [B]Russia[/B]
[SIZE=1]The map presents entire Russia with a map scale of 1:100.000 (some regions 1:200.000). Maps of Oblast (Federal district) capitals are based on a scale of 1:10.000 with street level detail while maps of regional centres are based on a 1:25.000 scale and provide partial street level details. Other settlements are presented as points in the geographic centre of the settlement. (RU)[/SIZE]
[URL="http://isohunt.com/download/46452969/garmin.torrent"]Download (Torrent)[/URL]
Mirror [URL="http://rapidshare.com/files/146232683/Roads_of_Russia_4.03.part1.rar"]Part1[/URL] [URL="http://rapidshare.com/files/146915271/Roads_of_Russia_4.03.part2.rar"]Part2[/URL] [URL="http://rapidshare.com/files/147006454/Roads_of_Russia_4.03.part3.rar"]Part3[/URL] [URL="http://rapidshare.com/files/147026567/Roads_of_Russia_4.03.part4.rar"]Part4[/URL] [URL="http://rapidshare.com/files/147043599/Roads_of_Russia_4.03.part5.rar"]Part5[/URL] [URL="http://rapidshare.com/files/147059082/Roads_of_Russia_4.03.part6.rar"]Part6[/URL][/LIST]
[SIZE=5]NORTH AMERICA[/SIZE]
[LIST][*][SIZE=3]City Navigator North America NT 2010.20[/SIZE] - MapID: 2005
Commercial streetmap covering the entire [B]United States[/B] (incl. Alaska, Hawaii and Puerto Rico) plus the seven southern provinces of [B]Canada[/B] - [URL="https://buy.garmin.com/shop/shop.do?pID=1456#coverageTab"]Coverage map[/URL]
[URL="http://www.megaupload.com/?d=ZHQL34W2"]Download, part 1[/URL] [URL="http://www.megaupload.com/?d=16ZC1270"]part 2[/URL] [URL="http://www.megaupload.com/?d=W4KXZTD0"]part 3[/URL] [URL="http://www.megaupload.com/?d=SPJL8GON"]part 4[/URL] [URL="http://www.megaupload.com/?d=BYHL6MWF"]part 5[/URL] [URL="http://www.megaupload.com/?d=IDAT4570"]part 6[/URL] [URL="http://www.megaupload.com/?d=KYM6M96R"]part 7[/URL] [URL="http://www.megaupload.com/?d=RH3AEUXP"]part 8[/URL]
[URL="http://linksave.in/788217984a77f4d4467f2"]Rapidshare protected by Linksave - Password: tom1807 [/URL]
[URL="http://torrents.thepiratebay.org/5045529/Garmin_CNNANT2010.20.5045529.TPB.torrent"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]MetroGuide Canada v4[/SIZE]
Commercial streetmap of [B]Canada[/B]
[SIZE=1]Provides detailed maps and points of interest throughout Canada using DMTI Spatial map data for all provinces in Canada, including provincial highways, controlled access highways and local roads. [URL="https://buy.garmin.com/shop/shop.do?pID=1022&pvID=2309#coverageTab"]Coverage map[/URL][/SIZE]
[SIZE=1]Out of the box the product supports routing within MapSource but not on devices.[/SIZE]
[URL="http://torrents.thepiratebay.org/3939202/Garmin_MapSource_MetroGuide_Canada_v4.3939202.TPB.torrent"]Download (Torrent)
[/URL][/LIST][LIST][SIZE=3]MetroGold[/SIZE]
With MetroGold you can make your GPS capable of autorouting with MetroGuide maps.
[SIZE=1]MetroGold will upgrade your MetroGuide Europe or North America to have this functionality. You can upload up to 2GB of modified maps to your GPS.[/SIZE]
[URL="http://torrents.thepiratebay.org/3797648/Metrogold_for_Mapsource.3797648.TPB.torrent"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]City Navigator Mexico NT 2010[/SIZE] - MapID: 403
Commercial streetmap of [B]Mexico[/B]
[SIZE=1]Coverage includes major metropolitan areas as well as major and intertown roads in Mexico. [URL="https://buy.garmin.com/shop/shop.do?cID=253&pID=11427#coverageTab"]Coverage map[/URL][/SIZE]
[URL="http://rapidshare.com/files/234227214/City_Nav_Mex_2010_UpDate.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]Mexico GPS Atlas v5.0[/SIZE] - MapID: 12080
[SIZE=1]The map covers more than 517.000km of highways, roads, streets, unpaved roads and trails all over the country. More than 280,000 towns and rural locations, providing street details with auto routing for over 2150 settlements. Address search with house number in the downtown area of Mexico City (Miguel Hidalgo, Cuajimalpa, Cuauhtemoc and Benito Juarez sectors), Naucalpan in State of Mexico, Ajijic and Chapala in Jalisco, Palenque in Chiapas, Empalme in Sonora, Valladolid in Yucatán and Ciudad Canatlan in Durango. International and state boundaries, lakes, rivers, national parks. Generally featuring 100m countour lines the Baja Peninsula shows 50 meters and selected regions of outdoor activity even 20m resulution.[/SIZE]
[URL="http://www.bicimapas.com.mx/MapasGPS/DNLD/MexicoGPSAtlas2010V50.exe"]Download[/URL][/LIST]
[SIZE=5]SOUTH AMERICA[/SIZE]
[LIST][*][SIZE=3]Mapear v8.50[/SIZE] - MapID: 900
Free streetmap of [B]Argentina[/B]
Source: [URL="http://www.proyectomapear.com.ar/"]Proyecto Mapear[/URL]
[URL="http://filefactory.com/file/ah2dgac/n/mapearV8_5_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]City Navigator Brazil NT 2010[/SIZE] - MapID: 404
Commercial streetmap of [B]Brazil[/B]
[SIZE=1]Coverage includes major road coverage throughout Brazil and detailed coverage for Minas Gerais, Rio de Janeiro and São Paulo. Contains over 500.000 points of interest. [URL="https://buy.garmin.com/shop/shop.do?cID=253&pID=11163#coverageTab"]Coverage[/URL][/SIZE]
Download [URL="http://www.filefactory.com/file/aggg6f8/n/CNBr2010_MapSource_part1_rar"]Part1[/URL] [URL="http://www.filefactory.com/file/aggg1dg/n/CNBr2010_MapSource_part2_rar"]Part2[/URL][/LIST][LIST][*][SIZE=3]TrackSource Brasil 6.06[/SIZE] – Free map
Free streetmap of [B]Brasil[/B]
Source: [URL="http://www.tracksource.org.br/"] Projeto TrackSource[/URL]
[URL=" http://rapidshare.com/files/268376381/TRC-Brasil_v606.exe "]Download[/URL][/LIST][LIST][*][SIZE=3]Chile Streets 2007[/SIZE] - MapID:724
Commercial streetmap of [B]Chile[/B]
[URL="http://torrents.thepiratebay.org/3874998/Garmin_MapSource_Chile_Streets_2007.3874998.TPB.torrent"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Perut v1.24[/SIZE] (2009-08-28)
Free streetmap of [B]Peru[/B]
Source: [URL="http://gps-peru.forums-free.com/"]Perut = Perú Ruteable[/URL]
[URL="http://gps-peru.forums-free.com/descarga-peru-ruteable-mapa-vial-f3.html"]Download[/URL][/LIST][LIST][*][SIZE=3]Venrut 4.9[/SIZE]
Free streetmap of [B]Venezuela[/B]
Source: [URL="http://www.gpsyv.net/Venrut.html"]GPS YV[/URL]
[URL="http://www.gpsyv.net/download.php?download=8"]Download[/URL]
[URL="http://www.pescapavon.net/download.php?download=5"]Mirror[/URL][/LIST]
[SIZE=5]MIDDLE EAST[/SIZE]
[LIST][*][SIZE=3]City Navigator Middle East NT 2010[/SIZE] - MapID: 445
Commercial streetmap of [B]Bahrain[/B], [B]Kuwait[/B], [B]Oman[/B], [B]Saudi Arabia[/B], [B]Qatar[/B] and [B]United Arab Emirates[/B].
[SIZE=1][URL="https://buy.garmin.com/shop/shop.do?cID=253&pID=1582#coverageTab"]Coverage[/URL] of the map depends on the region: Full coverage is provided for Bahrain, Kuwait, Oman, Qatar and United Arab Emirates while in Saudi Arabia only the major urban areas and intertown roads are covered.[/SIZE]
[URL="http://rapidshare.com/files/222219678/Garmin_RMU_CNMENT2010.rar"]Download[/URL]
[URL="http://www.megaupload.com/?d=5O71HAGK"]Mirror 1[/URL]
[URL="http://rapidshare.com/files/222307125/Garmin_RMU_CNMENT2010.rar.html"]Mirror 2[/URL][/LIST][LIST][*][SIZE=3]Israel rute v.158 [/SIZE] - MapID: 2009
Commercial streetmap of [B]Israel[/B] - No installer
[URL="http://www.filefactory.com/file/ag62fg1/n/Israel_Routable158_rar"]Download[/URL][/LIST]
[SIZE=5]AFRICA[/SIZE]
[LIST][*][SIZE=3]East Africa Street Maps v1[/SIZE] - MapID: 1095
Commercial streetmap of [B]Kenya[/B], [B]Tanzania[/B] and [B]Uganda[/B]
[SIZE=1]The map provides 92.000km of tar and gravel road network between the three countries and a comprehensive street level detail for all cities and selected towns in the East Africa region including Nairobi, Dar Es Salaam, Arusha, Moshe and Kampala.[/SIZE]
[URL="http://rapidshare.com/files/111099579/East_Africa_Streetmaps.rar.html"]Download[/URL]
[URL="http://thepiratebay.org/tor/4161819/Garmin_East_Africa_Streetmaps"]Mirror (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Southern Africa Streetmaps[/SIZE] - MapID: 1214
Commercial streetmap of [B]Botswana[/B], [B]Lesotho[/B], [B]Malawi[/B], [B]Mozambique[/B], [B]Namibia[/B], [B]South Africa[/B], [B]Swaziland[/B], [B]Zambia[/B] and [B]Zimbabwe[/B].
[SIZE=1]Contains more than 750.000km road data across the nine countries and street level data for more than 1700 cities, towns and villages in South Africa and other major cities in the south african region. It also provides routable roads and tracks for 55 game reserves and parks in Botswana, Malawi, South Africa and Zambia.[/SIZE]
[URL="http://www.megaupload.com/?d=605MIFXN"]Download[/URL][/LIST][LIST][*][SIZE=3]Southern Africa Streetmaps[/SIZE], DEM 2009 - MapID: 1218
Commercial topographic of [B]Botswana[/B], [B]Lesotho[/B], [B]Malawi[/B], [B]Mozambique[/B], [B]Namibia[/B], [B]South Africa[/B], [B]Swaziland[/B], [B]Zambia[/B] and [B]Zimbabwe[/B].
[URL="http://thepiratebay.org/torrent/4721355/Southern_Africa_Streetmaps_2009__Digital_Elevation_Model"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Southern Africa Streetmaps (Topo & Rec)[/SIZE], 2009 - MapID: 1215
Commercial topographic map of [B]Botswana[/B], [B]Lesotho[/B], [B]Malawi[/B], [B]Mozambique[/B], [B]Namibia[/B], [B]South Africa[/B], [B]Swaziland[/B], [B]Zambia[/B] and [B]Zimbabwe[/B]
[SIZE=1]The map provides the same information as the normal [I]Southern Africa Streetmaps[/I] plus 20m contour lines, rivers and forests for the nine southern African countries and farm boundaries and names for South Africa and Namibia.[/SIZE]
[URL="http://thepiratebay.org/torrent/4719398/Garmin_Southern_Africa_2009_Topo__amp__Rec"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]Tracks4Africa [/SIZE]
Commercial streetmaps of [B]Africa[/B]
[SIZE=1] RSA Western Cape, Northern Cape (ROUTABLE) 8.10 - Roads: 54129km, Points of Interest: 12943, Coverage: Detailed
RSA Eastern Cape, KZN, Free State (ROUTABLE) 8.10 - Roads: 57353km, Points of Interest: 10684, Coverage: Detailed
RSA Gauteng, North West, Limpopo, M****langa 8.10 - Roads: 66010km, Points of Interest: 10417, Coverage: Detailed
Lesotho (ROUTABLE) 8.10 - Roads: 3429km, Points of Interest: 555, Coverage: Detailed
Swaziland (ROUTABLE) 8.10 - Roads: 5354km, Points of Interest: 1086, Coverage: Detailed
Namibia, Angola (ROUTABLE) 8.10 - Roads: 65971km, Points of Interest: 7999, Coverage: Detailed
Botswana (ROUTABLE) 8.10 - Roads: 30263km, Points of Interest: 3321, Coverage: Detailed
Zambia, Zimbabwe (ROUTABLE) 8.10 - Roads: 30565km, Points of Interest: 2919, Coverage: Detailed
Mozambique, Malawi (ROUTABLE) 8.10 - Roads: 31604km, Points of Interest: 3291, Coverage: Detailed
Kenya, Tanzania, Uganda (ROUTABLE) 8.10 - Roads: 53647km, Points of Interest: 6811, Coverage: Detailed
Ethiopia, Sudan, Egypt, Somalia (ROUTABLE) 8.10 - Roads: 31193km, Points of Interest: 2111, Coverage: Moderately detailed
Tunisia, Libya, Algeria 8.10 - Roads: 25528km, Points of Interest: 559, Coverage: Sparse
Morocco, Western Sahara 8.10 - Roads: 18272km, Points of Interest: 846, Coverage: Moderately detailed
Western Africa 8.10 - Roads: 42917km, Points of Interest: 1166, Coverage: Overlander routes.[/SIZE]
[URL="http://www.filefactory.com/file/ahec69b/n/T4A_rar"]Download[/URL][/LIST][LIST][*][SIZE=3]Garmin Tunisia v11 Topo & Road Map[/SIZE] - MapID: 223
Free topographic map of [B]Tunisia[/B]
[URL="http://rapidshare.com/files/192955712/Jenas_Tunisia_v11_Topo___Road_Map.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Nigeria Streetmaps, Topo & Rec v3[/SIZE] - MapID: 1418
Commercial topographic map of [B]Nigeria[/B]
[SIZE=1]The map provides contour lines of 100m and more than 135.000km of road data including street level data for Lagos and Abuja.[/SIZE]
[URL="http://filefactory.com/file/age32bh/n/Nigeria_rar"]Download (Torrent)[/URL][/LIST]
[SIZE=5]ASIA[/SIZE]
[LIST][*][SIZE=3]Rotweiler's All Cambodia[/SIZE] Version 2.0
Streetmap of [B]Cambodia[/B]
[URL="http://www.filefactory.com/file/agh8ba9/n/Cambodia_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Rotweiler's Laos Routable[/SIZE] Version 1.0
Streetmap of [B]Laos[/B]
[URL="http://www.filefactory.com/file/agh8be8/n/laos_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Rotweiler's Vietnam Routable[/SIZE] Version 12.6
Streetmap of [B]Vietnam[/B]
[URL="http://www.filefactory.com/file/agh8b3g/n/vietnam_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Laos and Vietnam[/SIZE] (2009 –R4)
Free streetmap of [B]Laos[/B] and [B]Vietnam[/B]
[SIZE=1]The mapset was originally created from publically available sources and was from thereon enhanced by 1sec tracklogs.[/SIZE]
Source: [URL="http://www.asiagps.org/"]asiaGPS[/URL]
[URL="http://rapidshare.com/files/234439953/Laos_Vietnam_2009_R4.rar"]Download[/URL][/LIST][LIST][*][SIZE=3]GM-MalSing v3.05[/SIZE] - MapID: 5062 RgnID: 1
Streetmap of [B]Malaysia[/B] and [B]Singapore[/B]
Source: [URL="http://www.malsingmaps.com/portal/"]www.malsingmaps.com/[/URL]
[URL="http://rapidshare.com/files/258184512/MSM-MySinGv3.05.rar.html"]Download[/URL]
[URL="http://www.filesend.net/download.php?f=9d2b7271756a877424a4b27a81235f47"]Mirror 1[/URL]
[URL="http://www.megaupload.com/?d=RX9CDJVK"]Mirror 2[/URL][/LIST][LIST][*][SIZE=3][COLOR=YELLOW]Free Malaysia & Singapore GPS Map[/COLOR][/SIZE][COLOR=YELLOW] (MFM-090914)[/COLOR]
Free Streetmap of [B]Malaysia[/B] and [B]Singapore[/B]
Source: [URL="http://www.malfreemaps.com/"]www. malfreemaps.com/[/URL]
[URL="http://mfm.opensourcehub.com/maps/Garmin/MFM-Garmin-090914.exe"]Download[/URL]
[URL="http://rapidshare.com/files/279622565/_file_MFM-Garmin-090914.exe"]Mirror[/URL][/LIST][LIST][*][SIZE=3]GM-Borneo v3.06[/SIZE] - MapID: 5061 RgnID: 1
Streetmap of [B]Borneo[/B]
[URL="http://rapidshare.com/files/258589602/MSM-Borneov3.06G.rar.html"]Download[/URL]
[URL="http://www.**********.com/1906856905/MSM-Borneov3.06G.rar"]Mirror 1[/URL]
[URL="http://www.megaupload.com/?d=WPGIZ5IZ"]Mirror 2[/URL][/LIST][LIST][*][SIZE=3]Indonesia v1.61[/SIZE]
Free streetmap of [B]Indonesia[/B]
[SIZE=1]The map covers entire Indonesia, incl. [B]Bali[/B][/SIZE]
Source: [URL="http://www.navigasi.net"]navigasi.net[/URL]
[URL="http://www.megaupload.com/?d=R4VGIACB"]Download, Part 1[/URL] [URL="http://www.megaupload.com/?d=J09HR8NK"]Part 2[/URL][/LIST]
[LIST][*][SIZE=3]Indian Ocean Islands Streetmaps Version 1: Mauritius[/SIZE] - MapID: 1148
Commercial streetmap of [B]Mauritius[/B]
[SIZE=1]Provides 5.700km of road and street network for Mauritius and its various resorts, cities and towns with street level detail for Port Louis and other towns.[/SIZE]
[URL="http://rapidshare.com/files/111082046/Indian_Ocean_Island_Streetmaps_Mauritius.rar.html"]Download[/URL]
[URL="http://thepiratebay.org/tor/4161337/Garmin_Indian_Ocean_Island_Streetmaps_Mauritius"]Mirror (Torrent)[/URL][/LIST][LIST][*][SIZE=3]HongKong Routable Version 4[/SIZE]
Commercial streetmap of [B] HongKong [/B]
[SIZE=1] This map is fully "navigation-ready". The best, most accurate english-language GPS mapset of Hong Kong available anywhere. The map is also available as a "transparent" mapset so that it can be used with maps of China from other vendors. The October 15 build allows this map to now be used with the most recent versions of MapSource.[/SIZE]
[URL="http://www.filefactory.com/file/agg0d53/n/HongKongT_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Garmin City Navigator Korea v7 (ENG/KOR)[/SIZE] – Mapid: 460 (ENG)/347 (KOR)
Commercial streetmap of [B]Korea[/B]
[SIZE=1] Korea City Navigator provides detailed maps of major metropolitan areas, coverage of rural areas, point of interest and more. In addition, CD has automatic routing, giving you the capability to generate point-to-point routes in MapSourceR and on compatible GarminR units.[/SIZE]
[URL="http://rapidshare.com/files/243778696/460_MS.part1.rar"]Part 1 (ENG)[/URL] [URL="http://rapidshare.com/files/243804572/460_MS.part2.rar"]Part 2 (ENG)[/URL] [URL="http://rapidshare.com/files/243808678/460_MS.part3.rar"]Part 3 (ENG)[/URL] Password: tom1807
[URL="http://rapidshare.com/files/243839086/347_MS.part1.rar"]Part 1 (KOR)[/URL] [URL="http://rapidshare.com/files/243820528/347_MS.part2.rar"]Part 2 (KOR)[/URL] [URL="http://rapidshare.com/files/243845165/347_MS.part3.rar"]Part 3 (KOR)[/URL] Password: tom1807
[URL="http://www.bittorrent.am/torrent/3812828/2//Garmin-Korea-V7.html"]Download (Torrent)[/URL][/LIST][LIST][*][SIZE=3]RoadGuide Philippines[/SIZE]
Free streetmap of [B]Philippines[/B]
[SIZE=1]The map provides general coverage of Luzon, Visayas and Mindanao with street level detail for about 50 cities and towns. It is available in two versions: one for the general public and a much more detailed for contributors.[/SIZE]
Source: [URL="http://roadguide.ph/"]RoadGuide Philippines[/URL]
[URL="http://konkursbeschleuniger.de.p11.hostingprod.com/phroadguide/jklinc_5.08.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Sri Lanka Route[/SIZE]
Free streetmap of [B]Sri Lanka[/B]
[URL="http://www.filefactory.com/file/af7g8af/n/SL-win32_exe"]Download[/URL][/LIST][LIST][*][SIZE=3]City Navigator Taiwan v8.51 English[/SIZE] - MapID: 287
Commercial streetmap of [B]Taiwan[/B]
[URL="http://www.garmin.com/tw/download/TWN_CN_851/ENG/TWCN851_ENG.exe"]Download[/URL][/LIST][LIST][*][SIZE=3]Western Samoa[/SIZE] (Aug. 2008)
Free streetmap of [B]Western Samoa[/B] ([U]not[/U] American Samoa!)
Source: [URL]http://rcmaps.googlepages.com/samoa_maps[/URL]
[URL="http://rcmaps.googlepages.com/SamoaAutoRoutingTopoMaps2008R3.zip"]Download[/URL][/LIST]
[SIZE=5]OCEANIA[/SIZE]
[LIST][*][SIZE=3]City Navigator Australia & New Zealand NT 2010.10[/SIZE] - MapID:2006
Commercial streetmap of [B]Australia[/B] & [B]New Zealand[/B]
[SIZE=1]These highly detailed maps of Australia & New Zealand, provide turn by turn directions on your compatible Garmin GPS. Coverage includes cities, national roads and rural roads throughout Australia and New Zealand. [URL="https://buy.garmin.com/shop/shop.do?pID=36360#coverageTab"]Coverage[/URL][/SIZE]
[URL="http://filefactory.com/file/ahh286c/n/MSCNAusNZNT2010_10_rar"]Download[/URL]
[URL="http://linksave.in/12904688614a766d39e6e84"]Rapidshare protected by Linksave - Password: tom1807 [/URL][/LIST]
[LIST][*][SIZE=3][COLOR=YELLOW]New Zealand Open GPS Maps Project[/COLOR][/SIZE][COLOR=YELLOW] – 2009-09-11[/COLOR]
Free streetmap of [B]New Zealand[/B]
[SIZE=1] The project is based around purchased LINZ | CORAX data, and added to by the regional mappers. New or changed roads are added via extracts from LINZ and / or GPS track logs. The maps have a rich set of POI that is fed from the Zenbu project - another open source project. ESRI shape files can be extracted from the maps for use in other mapping applications. [/SIZE]
[URL="http://www.nzopengps.org/public/Latest%20Global%20Indexing%20Mapsets/20090911_FREE_OpenGPS_NZ_Maps_Setup.exe"]Download[/URL][/LIST]
[SIZE=5]WORLD[/SIZE]
[LIST][*][SIZE=3]WorldMap 4.06[/SIZE]
[SIZE=1]WorldMap provides basic worldwide map detail, including areas where no other detailed maps are available. These general maps display political boundaries, coastlines, cities and towns, major interstates and highways, lakes and rivers, and urban areas and railroads. WorldMap also includes U.S. Interstate Exits information, including fuel and service stations, restaurants, hotels, campsites, hospitals and banks. [B]WorldMap is generally recommended only if no other detailed maps are available for the area of interest.[/SIZE]
[URL="http://rapidshare.com/files/128803223/Garmin_Mapsource_World_Map_4.06.zip.html"]Download[/URL][/LIST]
Thanks to [URL="http://forum.gsmhosting.com/vbb/member.php?u=958380"]meisterfrank[/URL] for the new layout and all the map info.....[/QUOTE]
