Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 11-03-2009, 17:10   #1831 (permalink)
Member: 385577
Thanks Meter: 656
Let us all share our maps !
Requirements for maps to be included in the list:
1) All maps must be MapSource versions - not gmapsupp.img;
2) The map must be routable, and may not be prepared from a gmapsupp.img map;
3) New / Other maps to be included in the list must be in a better resolution than the existing maps.
If you have a map, or have knowledge of a map that meets these requirements, please post the link here. Thank you!
If you find this post useful, please say thank you.....
What is the advantage of using MapSource?
I think the MapSource program is pretty much a 'must have'. In addition to the ability to load maps, the MapSource software has a lot of other capabilities, for example:
  • Maybe you are lucky. Maybe you can have up till 6 maps on your phone at the same time eg. gmapbmap.img (Basemap), gmapprom.img (internal map, used when you have US or EU maps), gmapprom1.img (internal map, used when you have both US and EU maps), gmapsupp.img (Supplemental maps, will be overwritten when you add new maps), gmapsup2.img and gmapoem.img (For OEM Company). But with MapSource you can have many more! (The maximum amount of map-tiles for your unit is the limiting factor.) You just merge more maps together so they will appear as one file (gmapsupp.img) on your device
  • See all the cities, selected map details and POIs on your computer;
  • Set up routes and find out distances. Helps you get an overall picture;
  • Create and transfer waypoints to your device;
  • View and edit .GPX (POI) files;
  • Backup your waypoints from your device to a database (*.gdb) file on your computer;
  • Find the lat/long positions of waypoints;
  • Add description comments to your favourites/waypoints, like addresses and phone numbers;
  • Interact seamlessly with Google Earth
How to ...
Prepare your Garmin-device, Mobile, PDA
  • Nüvi, StreetPilot, etc.
    Download the webupdater to update your device: http://www8.garmin.com/software/WebU...indows_242.exe
  • Garmin Mobile PC
    Download the software here: http://www8.garmin.com/software/Garm...lePC_50060.exe
  • Phones, PDA, etc.
    1. Install Garmin Mobile XT Free Basemap: http://www8.garmin.com/software/Garm...emap_4xxxx.exe
    2. Install Garmin Mobile XT Support Files: http://www8.garmin.com/software/Garm...iles_4xxxx.exe
    3. Install the software for your phone, eg. Garmin Mobile XT for Symbian S60 3rd Edition. If your phone uses a different OS find the correct Garmin software here.
    4. Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card.
    5. Start the application.
    6. Select settings for text language, voice, unit and for Garmin Online.
    7. Exit the application.
    8. Open the file called GarminDevice.xml. It is located in the Garmin folder.
    9. Look for <Id>XXXXXXXXXX</Id>.
    10. Use the Keygenerator to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL.txt) using Notepad. The file should be saved in the Garmin folder. As default Notepad will save your file as a text file! You have to choose “save as” and change the file name from .txt to ALL FILES.
    More info here. (Thank you Fugglefeet)
    If you - after following the previous steps - start the application get a screen with 1) Purchase & Go!, 2) Begin Free Trial, 3) Enter Product Key, and 4) Connect to a Garmin GPS, then you have done something wrong! Did you save the file as "just" sw.unl? Did you save it into the garmin folder? Try to use your phones filemanager to locate the file and check it is called sw.unl only.
    If your phone, after unlocking, is looking for a Bluetooth GPS and not the internal GPS go to TOOL > SETTING > SYSTEM > REMOTE GPS. Choose USE BUILT IN GPS > ENABLE it then click DONE.
Install MapSource
  1. Download MapSource version 6.13.7
    It isn't compatible with the newest maps (2009 NT) from Garmin but it's the last MapSource version that provides you with the Unlock Wizard and also newer versions have compatibility issues with some free maps.
  2. For a clean and fresh setup without any prior installation of MapSource
    1. Extract the content of MapSource_6137.exe (the file you downloaded in step 1) using WinRAR;
    2. From the extracted files, run MAIN.msi;
    3. Now run Setup.exe.
    If you don't follow these steps exactly as listed, MapSource will abort the setup-process with an "Previous MapSource not found" error message.
  3. Open Windows Explorer and navigate to the directory where MapSource is located. (Probably C:\Garmin)
  4. Rename MapSource.exe into MapSource_6-13-7.exe
    If you want to have a localized version of MapSource you need to rename the corresponding .DLL too: In the same directory you'll find a lot of MapSourceXXX.dll files where XXX represents a language-code. (e.g. MapSourceRUS.dll = Russian, MapSourceDEU.dll = German, MapSourceESP.dll = Spanish, etc.). Pick the .DLL representing your language and rename it to MapSource_6-13-7XXX.dll (XXX being the language code) so you end up with e.g. MapSource_6-13-7RUS.DLL. Done.
  5. The MapSource-installer has created shortcuts on your Desktop and in the Start-menu. You'll have to adjust them so that they
    • represent the MapSource version (renaming them from MapSource > Mapsource 6.13.7) and
    • point to the correct file (Properties > Link target)
    It's just a piece of cake to do that...
  6. Now download MapSource 6.15.7 from Garmin and
  7. install it. (Since you already have a installed version of MapSource you don't have to all the unpacking from above. Just run the .EXE)
  8. There is a patched version of MapSource 6.15.7, allowing you to save map-sets (.IMG) not only to SD-cards and Garmin-devices but to any of your local drives. If you want it, download it from here.
  9. Follow the above steps 3. - 5. accordingly to rename the file(s).
    Congratulations, you have two simultaneous installations of MapSource and can now enjoy all the features.
Install maps
  1. Download the map you want;
  2. Install the map using the file called something with XXXXXX_ENU.msi - Not the Setup.exe - This will install the map only (this applies to "real" Garmin maps only – with other maps the file might just be called setup.exe);
  3. Unlock the map:
    • Get a key generator which you can find here;
    • Enter your GPS ID number and enter your MapID (scroll down to “custom maps”) in the key generator, and you have the unlock-code.
    • Launch MapSource;
    • In MapSource, click Utilities > Manage Map Products;
    • Select the Unlock Regions tab, and click Add;
    • Enter your 25-character unlock code and then a comment, if desired. Click OK.
    For more info read the MapSource user guide
If you would like to have more maps, e.g. Garmin City Navigator Europe NT 2009 and Garmin City Navigator North America NT 2009 you can combine the maps and transfer them to your GPS.
Try it!
Use Basemaps
  • What is a Basemap?
    A Basemap is a map with limited detail and precision.
  • Limited? So, what it is good for?
    It serves two purposes:
    1. It gives you the possibility to navigate where none of you regular maps provides coverage.
    2. When you zoom out on your device it would take lots of processor power - and therefore time - to draw all the details of your regular map. Hence in such moments your device uses the Basemap.
  • Isn't my device factory equipped with a Basemap?
    Yes, it is. Garmin sells their equipment with one of two preinstalled Basemaps: Americas lite or Atlantic lite.
  • So why should I want different Basemap?
    The two pre-installed Basemaps are limited to their region. They don't provide you with world-wide coverage.
  • But there is a WorldMap from Garmin. Why not use it instead?
    It has no autorouting.
  • You convinced me. What shall I do?
    Follow these steps:
    1. Download the World-Wide routable Basemap v3.01 from the Garmin Website. (Here you can learn about the coverage.)
    2. Don't run the .EXE! Instead open it with - for example - WinRAR (Right-click).
    3. Navigate within the archive to the worldwide directory and extract the GMAPBMAP.IMG file to some place on your computer.
    4. Copy it into the garmin directory on your device.
  • But this will delete my existing Basemap?! Shouldn't I save or keep it?
    Yes, that would forever delete your pre-installed Basemap. If you want to save or keep it you should either
    • copy the original file to your computer, a CD or a DVD for possible use in the future. (Backups are always a very good idea! and you should take the chance to make a backup of your entire device) or you
    • could rename the original Basemap to gmapoem.img and keep it parallel to the new basemap. Your device will handle the rest.
  • The file I downloaded says iQue 3600. Can i really use it for my device?
    Yes, you can. The only devices you possibly wouldn't use it for are the new Garmin units with 3D terrain. But these are factory supplied with the Worldwide Autoroute DEM Basemap. (If you accidentally deleted it, you can download a copy here.)
Use POI Loader
POI Loader is a free program from Garmin for your computer that lets you upload customized points of interest (POIs) to your compatible Garmin device. With the help of POI Loader, you can update your compatible Garmin GPS with the latest restaurants, safety camera locations, tourist destinations, etc. More info about poi here, and about POI Loader here
Map list
Recent changes are marked in yellow.
EUROPE
  • Adria TOPO 2.10 - HR - MapID: 928
    Commercial topographic map of Bosnia and Herzegovina, Croatia (original map scale 1:25.000)
    Download
  • Adria TOPO 2.11 - SLO - MapID: 844
    Commercial topographic map of Slovenia (original map scale 1:25.000)
    Download
  • SCG Route 2.1 - MapID: 929
    Commercial streetmap of Montenegro, Serbia
    Download
  • Topo Czech 3.0 PRO - MapID: 1705
    Commercial topographic map of the Czech Republic (original map scale 1:10.000; effective scale 1:25.000)
    The map supports automatic route calculation on road and street network and terrain shading in PC. The Topo map includes: cities, towns, road & street network, railroads, lakes, rivers, forests, elevation contour lines, trails.
    Part 1 Part 2 Part 3 Part 4 Part 5
  • Cyprus Map v10 – No installer
    Free streetmap of Cyprus
    Source: Cymps
    Download
  • Eesti Teejuht 21.11
    Commercial streetmap of Estonia - No installer
    Very detailed map with many topographic features but no contour lines.
    Download
  • NaviGuide Hungary 5.3 NT - MapID: 709
    Commercial streetmap of Hungary
    Source: Garmin.hu
    Lakes, rivers, cities, motorways, national and regional thoroughfares, and local roads, plus street level maps for 3051 cities. Also contains nautical chart data for Lake Balaton, with depth contours, spot soundings, navaids with view range and coverage and port plans.
    Download
  • Routeable TOPO map of Iceland 2009 NT - MapID: 1471
    Commercial topographic map of Iceland
    Source: Garmin.is
    Download
  • Roads of Latvia v1.1.1 - MapID: 1677
    Commercial street map of Latvia
    Roads of Latvia is a new map product of Latvia created in partnership with http://www.kurtuesi.lv/ project. The product contains more than 75000 km wide road network including all motorways, county, residential roads as well as most unpaved roads. Detailed street level coverage available for 41 out of 77 cities in Latvia at the moment, but all 77 cities will be available in the next big update expected in January. The map also contains forests, lakes, rivers, railway lines, terrain height above sea level with Digital Elevation Model in TOPO version of the map. More than 6500 POI?s included with the map. Both products are available as preloaded on microSD/SD memory cards and are in NT format.
    Download
  • Latvia TOPO v1.1.1 - MapID: 1681
    Commercial topograpical map of Latvia
    Download
  • Lietuvos Topo 1.082 - MapID: 857
    Commercial topographic map of Lithuania
    Source: Garmin
    The map provides 75.000km of highways, county and residential roads with street level detailed maps of all settlements in Lithuania. Other objects includes lakes, rivers & canals (110.000km), railway lines, Kauno marios, Kuršių marios.
    Download
  • Moldova 14.04.2009 - MapID: 1964
    Commercial streetmap of Moldovia
    Source: Skynet
    Download
  • GPMapa 2009.2 NT - MapID: 1764
    Commercial streetmap of Poland
    Source: GPMapa
    Version GPMapa 2009.2 includes over 2,3 millions of address points, 3069 detailed city and town plans, including 2686 plans provided with addresses and 277 plans bearing only names of the streets, 407 993 km of roads, including 308 039 km of asphalt roads. 167 965 points of interests (POI), including photoradars and "Black Points". 44 cities inclusive if the building outlines (Augustów, Bartoszyce, Białystok, Brodnica, Bydgoszcz, Bytom, Chełmno, Częstochowa, Elbląg, Gdańsk, Gdynia, Giżycko, Gorzów Wielkopolski, Iława, Katowice, Kętrzyn, Kielce, Kościerzyna, Kraków, Krosno Odrzańskie, Lublin, Łódź, Mrągowo, Myślenice, Olkusz, Olsztyn, Ostróda, Poznań, Pruszcz Gdański, Radom, Reda, Rzeszów, Sopot, Starogard Gdański, Szczecin, Szczytno, Tarnów, Tczew, Warszawa, Wieliczka, Wrocław, Września, Zabrze, Zielona Góra). Information about speed limits on selected national roads and 70 villages.
    Download, part 1 part 2 part 3
    Mirror
  • R.O.A.D. 2008 v3.01 - MapID: 1189
    Commercial streetmap of Romania (original map scale 1:100.000).
    Covers all the cities, lakes and marshes of Romania, the Danube Delta and the shore of the Black Sea, all the large and middle size rivers, aprox. 75% of the small intermittent rivers and canals; european, national and state roads, highways A1 and A2; contour lines distanced 40 meters apart, railways, ******* runways, bathymetry data in a few selected areas in the Black Sea. Detailed maps reference scale 1:5000 or higher Detailed cities: Bucuresti, Suceava, Iasi, Oradea, Cluj-Napoca, Turda, Huedin, Timisoara, Arad, Targu Mures, Campulung Moldovenesc and Brasov (with street level information, city limits, industry, parks, forests, gardens, orchards and POIs) plus Danube Delta Dunarii (wetlands, canals, lakes, flats, toponames).
    Download Part1 Part2 Part3
    Mirror (Torrent)
  • Garmin Romania Road 2009.10 3.02 (update of ROAD 2008 3.01)
    Install Romania Road 2008 first, then update with Romania Road 2009.10.
    Download
  • Slovakia Roads v6 - MapID: 1315
    Commercial streetmap of Slovakia
    Source: Garmin.sk
    Download
  • Navcity Turkey 2009.06 - MapID: 848
    Commercial streetmap of Turkey
    The Basarsoft NavCITY Turkey 2009.02 contains current routing Detailcards of 81 turkish cities (Istanbul, Ankara, Izmir, Adana, Antalya, Bursa, Samsun, Konya, Kayseri, Denizli, Diyarbakir...) and all Cities of the South-Westcoast from Alanya to Ayvalik with 786.199 km of streets and 318.071 Points of Interest. Coverage map
    Download
    Mirror
  • Aeroscan Ukraine 4.03 - English - MapID: 934
    Commercial streetmap of Ukraine
    Source: Garmin.com.ua
    Detailed map of the Ukraine and metropolitan maps of Kiev and about 80 other Ukrainian cities and towns. In some cities house numbers are provided. Includes business and residential streets, rivers, lakes and shoreline details.
    Download (Torrent) – English v/4.03
  • Aeroscan Ukraine 4.13 - Ukrainian - MapID: 933
    Download – Ukrainian v/4.13
  • Aeroscan Ukraine 3D - MapID: 933
    Commercial street map of Ukraine
  • CarteBlanche Ukraine 3.60 - MapID: 575
    Source: GPSMap
    The map covers European, national, regional and local roads and provides detailed city maps of about 40 settlements including all regional centres as well as some other important cities. The remaining settlements are provided in the form of points and contours. It also shows railways, rivers, streams, lakes, parks, and forests.
    Download
    Mirror
  • NavLux Ukraine Navigator (30.09.2009) - MapID: 1174
    Source: Luxena Software Company
    Detailed map of the Ukraine with 250.000 km roads, 30.108 settlements and contours of buildings with address information.
  • NavLux Ukraine Navigator (30.09.2009) – 3D - MapID: 1174
    Download – password: 4pda.ru
  • European POIs
    • SpeedCams 20-05-2009 - Fix camera
      Download
      Speedcam covering A, AND, B, BIH, BR, CH, CZ, D, DK, E, F, FIN, FL, GB, GR, H, I, IRL, IS, L, LT, N, NL, P, PL, RO, RUS, S, SK, SLO and UA. Furthermore Swedish Road Toll & Austria Road Toll.
      This one really works (with the right speed limit), and these alerts will sound and become visible once, as you approach the POI location. If you remain under the user specified speed, you will get no more alerts. However, if you exceed that specified speed, a beep will sound every second to remind you of the alert, until either you slow down below the set speed or pass the POI. All use is at your own risk.
      To install just copy the 6 files into /garmin/POI/ on your device.
      Based on data from POI Plaza, Poi.cz, Poigps.com, gratispoi.dk and Speedcam****
RUSSIA
  • Roads of Russia v4.03 (translit.) - MapID: 1120
    Commercial map of Russia
    The map presents entire Russia with a map scale of 1:100.000 (some regions 1:200.000). Maps of Oblast (Federal district) capitals are based on a scale of 1:10.000 with street level detail while maps of regional centres are based on a 1:25.000 scale and provide partial street level details. Other settlements are presented as points in the geographic centre of the settlement. (RU)
    Download (Torrent)
    Mirror Part1 Part2 Part3 Part4 Part5 Part6
NORTH AMERICA
  • MetroGuide Canada v4
    Commercial streetmap of Canada
    Provides detailed maps and points of interest throughout Canada using DMTI Spatial map data for all provinces in Canada, including provincial highways, controlled access highways and local roads. Coverage map
    Out of the box the product supports routing within MapSource but not on devices.
    Download (Torrent)
  • MetroGold
    With MetroGold you can make your GPS capable of autorouting with MetroGuide maps.
    MetroGold will upgrade your MetroGuide Europe or North America to have this functionality. You can upload up to 2GB of modified maps to your GPS.
    Download (Torrent)
  • Dominican Republic and Haiti v2.5
    Commercial streetmap of Dominican Republic and Haiti
    Source: La-Hispaniola
    Download
  • City Navigator Mexico NT 2010 - MapID: 403
    Commercial streetmap of Mexico
    Coverage includes major metropolitan areas as well as major and intertown roads in Mexico. Coverage map
    Download
  • Mexico GPS Atlas v5.1 - MapID: 12080
    Source: BiciMapas
    The map covers more than 517.000km of highways, roads, streets, unpaved roads and trails all over the country. More than 280,000 towns and rural locations, providing street details with auto routing for over 2150 settlements. Address search with house number in the downtown area of Mexico City (Miguel Hidalgo, Cuajimalpa, Cuauhtemoc and Benito Juarez sectors), Naucalpan in State of Mexico, Ajijic and Chapala in Jalisco, Palenque in Chiapas, Empalme in Sonora, Valladolid in Yucatán and Ciudad Canatlan in Durango. International and state boundaries, lakes, rivers, national parks. Generally featuring 100m countour lines the Baja Peninsula shows 50 meters and selected regions of outdoor activity even 20m resulution.
    Download
SOUTH AMERICA
  • City Navigator Brazil NT 2010 - MapID: 404
    Commercial streetmap of Brazil
    Coverage includes major road coverage throughout Brazil and detailed coverage for Minas Gerais, Rio de Janeiro and Săo Paulo. Contains over 500.000 points of interest. Coverage
MIDDLE EAST
  • City Navigator Middle East NT 2010.20 - MapID: 2009
    Commercial streetmap of Bahrain, Kuwait, Oman, Select cities in Saudi Arabia, Qatar, United Arab Emirates and Select cities in ******..
    Coverage of the map depends on the region: Full coverage is provided for Bahrain, Kuwait, Oman, Qatar and United Arab Emirates while in ****** and Saudi Arabia only the major urban areas and intertown roads are covered.
  • Israel rute v.158 - MapID: 2009
    Commercial streetmap of Israel - No installer
    Download
AFRICA
  • East Africa Street Maps v1 - MapID: 1095
    Commercial streetmap of Kenya, Tanzania and Uganda
    The map provides 92.000km of tar and gravel road network between the three countries and a comprehensive street level detail for all cities and selected towns in the East Africa region including Nairobi, Dar Es Salaam, Arusha, Moshe and Kampala.
    Download
    Mirror (Torrent)
  • Southern Africa Streetmaps v/ 2 - MapID: 1692
    Commercial streetmap of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe.
    Source: Garmap
    Contains more than 750.000km road data across the nine countries and street level data for more than 1700 cities, towns and villages in South Africa and other major cities in the south african region. It also provides routable roads and tracks for 55 game reserves and parks in Botswana, Malawi, South Africa and Zambia.
    Download
    Mirror
  • Southern Africa Streetmaps, DEM 2009 - MapID: 1218
    Commercial topographic of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe.
    Download (Torrent)
  • Southern Africa Streetmaps (Topo & Rec), 2009 - MapID: 1215
    Commercial topographic map of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe
    The map provides the same information as the normal Southern Africa Streetmaps plus 20m contour lines, rivers and forests for the nine southern African countries and farm boundaries and names for South Africa and Namibia.
    Download (Torrent)
  • Tracks4Africa
    Commercial streetmaps of Africa
    RSA Western Cape, Northern Cape (ROUTABLE) 8.10 - Roads: 54129km, Points of Interest: 12943, Coverage: Detailed
    RSA Eastern Cape, KZN, Free State (ROUTABLE) 8.10 - Roads: 57353km, Points of Interest: 10684, Coverage: Detailed
    RSA Gauteng, North West, Limpopo, M****langa 8.10 - Roads: 66010km, Points of Interest: 10417, Coverage: Detailed
    Lesotho (ROUTABLE) 8.10 - Roads: 3429km, Points of Interest: 555, Coverage: Detailed
    Swaziland (ROUTABLE) 8.10 - Roads: 5354km, Points of Interest: 1086, Coverage: Detailed
    Namibia, Angola (ROUTABLE) 8.10 - Roads: 65971km, Points of Interest: 7999, Coverage: Detailed
    Botswana (ROUTABLE) 8.10 - Roads: 30263km, Points of Interest: 3321, Coverage: Detailed
    Zambia, Zimbabwe (ROUTABLE) 8.10 - Roads: 30565km, Points of Interest: 2919, Coverage: Detailed
    Mozambique, Malawi (ROUTABLE) 8.10 - Roads: 31604km, Points of Interest: 3291, Coverage: Detailed
    Kenya, Tanzania, Uganda (ROUTABLE) 8.10 - Roads: 53647km, Points of Interest: 6811, Coverage: Detailed
    Ethiopia, Sudan, Egypt, Somalia (ROUTABLE) 8.10 - Roads: 31193km, Points of Interest: 2111, Coverage: Moderately detailed
    Tunisia, Libya, Algeria 8.10 - Roads: 25528km, Points of Interest: 559, Coverage: Sparse
    Morocco, Western Sahara 8.10 - Roads: 18272km, Points of Interest: 846, Coverage: Moderately detailed
    Western Africa 8.10 - Roads: 42917km, Points of Interest: 1166, Coverage: Overlander routes.
    Download
    Mirror
  • Garmin Tunisia v11 Topo & Road Map - MapID: 223
    Free topographic map of Tunisia
    Download
  • Nigeria Streetmaps, Topo & Rec v3 - MapID: 1418
    Commercial topographic map of Nigeria
    The map provides contour lines of 100m and more than 135.000km of road data including street level data for Lagos and Abuja.
    Download (Torrent)
ASIA
  • Rotweiler's All Cambodia Version 2.0
    Streetmap of Cambodia
    Download
  • Rotweiler's Laos Routable Version 1.0
    Streetmap of Laos
    Download
  • Rotweiler's Vietnam Routable Version 12.6
    Streetmap of Vietnam
    Download
  • Laos and Vietnam (2009 - R4)
    Free streetmap of Laos and Vietnam
    The mapset was originally created from publically available sources and was from thereon enhanced by 1sec tracklogs.
    Source: asiaGPS
    Download
  • Indonesia v1.63
    Free streetmap of Indonesia
    The map covers entire Indonesia, incl. Bali
    Source: navigasi.net
    Download
  • Indian Ocean Islands Streetmaps Version 1: Mauritius - MapID: 1148
    Commercial streetmap of Mauritius
    Provides 5.700km of road and street network for Mauritius and its various resorts, cities and towns with street level detail for Port Louis and other towns.
    Download
    Mirror (Torrent)
  • HongKong Routable Version 4
    Commercial streetmap of HongKong
    This map is fully "navigation-ready". The best, most accurate english-language GPS mapset of Hong Kong available anywhere. The map is also available as a "transparent" mapset so that it can be used with maps of China from other vendors. The October 15 build allows this map to now be used with the most recent versions of MapSource.
    Download
  • Garmin City Navigator Korea v7 (ENG/KOR) – Mapid: 460 (ENG)/347 (KOR)
    Commercial streetmap of Korea
    Korea City Navigator provides detailed maps of major metropolitan areas, coverage of rural areas, point of interest and more. In addition, CD has automatic routing, giving you the capability to generate point-to-point routes in MapSourceR and on compatible GarminR units.
    Part 1 (ENG) Part 2 (ENG) Part 3 (ENG) Password: tom1807
    Part 1 (KOR) Part 2 (KOR) Part 3 (KOR) Password: tom1807
    Download (Torrent)
  • RoadGuide Philippines
    Free streetmap of Philippines
    The map provides general coverage of Luzon, Visayas and Mindanao with street level detail for about 50 cities and towns. It is available in two versions: one for the general public and a much more detailed for contributors.
    Source: RoadGuide Philippines
    Download
  • Sri Lanka Route
    Free streetmap of Sri Lanka
    Download
  • City Navigator Taiwan v8.51 English - MapID: 287
    Commercial streetmap of Taiwan
    Download
OCEANIA
  • City Navigator Australia & New Zealand NT 2010.10 - MapID:2006
    Commercial streetmap of Australia & New Zealand
    These highly detailed maps of Australia & New Zealand, provide turn by turn directions on your compatible Garmin GPS. Coverage includes cities, national roads and rural roads throughout Australia and New Zealand. Coverage
    Download
    Rapidshare protected by Linksave - Password: tom1807
  • Shonkymaps v/3.51
    Free topographical map of Australia
    Source: Shonkymaps
    Shonkymaps are a set of unofficial Garmin compatible topographic maps that cover the whole of Australia. The author was not satisfied with the Garmin base map that came with the Garmin gps, and at the time there were no other topographic products either official or unofficial. He created his own set of downloadable topographic maps as a hobby / labour of love. The data is the 250k scale set from Geoscience Australia (http://www.ga.gov.au) and is licensed for non-commercial use. The author makes these maps available to other Garmin users as a favour on the understanding that the user abides by the copyright agreement and there is no support other than that provided by other users on the http://www.gpsaustralia.net forum. If the maps work for you and are useful for your requirements then great. If they don't work, and break your garmin then you have been warned.
    Download
  • New Zealand Open GPS Maps Project – 2009-10-31
    Free streetmap of New Zealand
    The project is based around purchased LINZ | CORAX data, and added to by the regional mappers. New or changed roads are added via extracts from LINZ and / or GPS track logs. The maps have a rich set of POI that is fed from the Zenbu project - another open source project. ESRI shape files can be extracted from the maps for use in other mapping applications.
    Download
WORLD
  • WorldMap 4.06
    WorldMap provides basic worldwide map detail, including areas where no other detailed maps are available. These general maps display political boundaries, coastlines, cities and towns, major interstates and highways, lakes and rivers, and urban areas and railroads. WorldMap also includes U.S. Interstate Exits information, including fuel and service stations, restaurants, hotels, campsites, hospitals and banks. [B]WorldMap is generally recommended only if no other detailed maps are available for the area of interest.
    Download
Thanks to meisterfrank for the new layout and all the map info.....
The Following 4 Users Say Thank You to mike2111 For This Useful Post:
Old 11-03-2009, 17:44   #1832 (permalink)
Crazy Poster
Member: 1065523
Thanks Meter: 8
Originally Posted by wavee_27 View Post
could u post map for india please
Garmin City Navigator India 2009 NT Q4 - http://rapidshare.com/files/274858022/ga_in09_q4.rar
Old 11-03-2009, 21:19   #1833 (permalink)
Member: 922633
Iran/ Persia
Is there any map for Persia.................Iran? I am planning a moto trip there and I am looking for a map!
Old 11-03-2009, 22:51   #1834 (permalink)
Member: 1153124
Sonork: bor99
Originally Posted by giuseppe66 View Post
Ciao
may someone post 3D buildings and lane assistant for Europe 2010.20 but no with rapidshare because I've not a premiun account. If possible with other that can download with the same IP addres. Very thanks
Ciao
Hola alguien sabe si al garmin zumo 500 deluxe, se le pueden poner los 3d buildings.ccf edificios en 3d gracias y es que si, que porfavor me indiquen como se hace. ya tengo descargado el archivo pero no se como hacerlo.
Old 11-04-2009, 08:23   #1835 (permalink)
Member: 927233
Thanks Meter: 27
No es posible por zumo 500. 3d building es por nuvi 765 .ciao
Old 11-04-2009, 17:30   #1836 (permalink)
Member: 1012282
Thanks Meter: 29
IWN Iran Routable Map v2.3.5 ShareFreePDA
http://www.filefactory.com/file/ahh3192/n/IWN_Iran_Routable_Map_v2_3_5_Unlocked_By_farshid_rar
mirror:
http://www25.zippyshare.com/v/22265813/file.html
Old 11-04-2009, 17:52   #1837 (permalink)
Member: 1012282
Thanks Meter: 29
another map:
http://www.rapidspread.com/file.jsp?id=dqpfi9fzga
Old 11-05-2009, 07:02   #1838 (permalink)
Registered User
Member: 838212
Thanks Meter: 158
Smile Adria topo 2.20
NEW ADRIA TOPO 2.20 MAP ID: 928
http://navigo-sistem.hr/upload/AdriaTOPO_2.20_HR.exe
The Following User Says Thank You to tesicvlado For This Useful Post:
Old 11-06-2009, 02:58   #1839 (permalink)
Member: 1046865
Thanks Meter: 11
New Thaland TSM v10 Available
A new no pain .img map for Thailand (English and Thai) is now available.
google gpsunderground.com or noeman.org
Old 11-07-2009, 07:44   #1840 (permalink)
Member: 944132
Thanks Meter: 45
GARMIN KEYGEN v1.5 - 5dig. MapID
http://rapidshare.com/files/303497723/Jenas_Unlock_Generator_1_5_FID5DIGIT.exe
Old 11-09-2009, 15:04   #1841 (permalink)
Registered User
Member: 838212
Thanks Meter: 158
Smile Garmin Pakistan Map
Garmin Pakistan Map v2.0 Update 29.10.2009-MAPSOURCE
Overview: Routable maps of Pakistan
Street level detail of 11 major cities: Karachi, Islamabad, Lahore, Sialkot, Gujranwala, Narowal, Peshawar, Wah, Abbottabad, Manshera, & Gilgit
Search roads, street numbers and POIs
Customized map display for roads
Map is unlocked
http://rapidshare.com/files/299174048/PKmaps_setup.exe
Old 11-09-2009, 16:31   #1842 (permalink)
Member: 995612
Map source version Garmin Russia ,anyone?
Thanx
Old 11-09-2009, 22:51   #1843 (permalink)
Member: 823441
Map source version Bangladesh, anyone?
Thanks
Old 11-09-2009, 23:25   #1844 (permalink)
Member: 1152339
Thanks Meter: 13
GPMapa 2009 TOPO (v.3.03) - commercial TOPO & streetmap of Poland:
http://rapidshare.com/files/30212062...V303.part1.rar
http://rapidshare.com/files/30213654...V303.part2.rar
Regards
maffi_pl
Old 11-09-2009, 23:34   #1845 (permalink)
Member: 1152339
Thanks Meter: 13
Originally Posted by Pio46 View Post
[/LIST]Hi Mike,
could you please explaine how to install - aplicate those above?!!?
Hoping to hear from you ASAP,
Regards
Pio46
Devices, that support map extras:
3D buildings
Garmin Nüvi series
765T, 775T
865T
Garmin Zümo series
660
Lane assistant (junction view)
Garmin Nüvi series
755T, 765T, 775T, 785T, 855, 865T, 885T
1340, 1340T, 1350T, 1370T, 1390T, 1490T
Garmin Mobile XT & Garmin Mobile PC do not support City Navigator Extras.
How to:
3D buildings - unrar downloaded files - you get gmap3d.img file; transfer it to your Garmin device, to the \Garmin directory
Lane Assistant - unrar downloaded files - you get ***.jcv file; transfer it to your Garmin device, to the \Garmin\JCV directory
Regrds
maffi_pl
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/
Posted By For Type Date
What is GARMIN XT V5 MIDDLE EAST? This thread Refback 06-29-2013 08:06
malaysia map for garmin xt carrotboy88 GPS devices , Navigators & Maps 1 01-19-2012 08:18
Garmin XT Canada Map jati_grewal GPS devices , Navigators & Maps 2 07-18-2009 13:10
maps for garmin xt billyprepo GPS devices , Navigators & Maps 1 03-11-2009 10:33
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
Garmin XT Canada Maps 2009 s3lekta Nokia Multimedia 0 09-21-2008 19:45
Page generated in 0.63933 seconds with 10 queries
