GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
08-30-2006, 21:06 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 338776 Status: Offline Thanks Meter: 0 | Ok, now another question: I have a igo.db with all the Velox and ZTL as personal POI and it's about 890K...Igo now take about 1 minuts to start....I noticed that more this file is big and more it takes...it's not too much 1 minuts to read 890kb?? I have the same file on "Viamichelin" and it taske just few seconds... As I read of people that have and igo.db of more then 9MB I wonder how much they will take to make the program start??? |
08-30-2006, 21:17 | #2 (permalink) | |
Major Poster Join Date: Aug 2006
Member: 329973 Status: Offline Thanks Meter: 0 | Quote:
Sorry mate....will try to find this myself...cos mine start within a few sec...so I don't have the problem actually Quek | |
08-30-2006, 22:50 | #3 (permalink) |
Junior Member Join Date: Jan 2005 Age: 42
Member: 106863 Status: Offline Thanks Meter: 1 | iGO FBL and FFK files I have two version, one is for Europe and has inside a lot of countries and Romania and other countries are little dimension, Italy is a normal dimension of file, I suppose that is enough detailed. But some countries like Romania is only 7 Mbyte (I see cities that have low definition and little streets). I have also single countries like Romania, Hungary and Slovakia that are much better detailed and are about 25 Mbyte. The problem is that I need the first installation and the second for some countries and I don't know if I can only have to put the second maps in the same directory. I think that it need the second version of iGO that comes with these countries. But in this way I have to put out europe (with Italy). Also the map files are different the first are fbl files and the second are ffk files ROMANIA.ffk dim. 24.071 Kb Map of Romania (very detailed) Romania.fbl dim. 7.144 kb Map of Romania (included in the europe maps) so what to do ? Sullivan |
09-01-2006, 14:25 | #4 (permalink) |
Crazy Poster Join Date: Aug 2006
Member: 331335 Status: Offline Thanks Meter: 0 | Quek I have installed you duo version. Everything worked fine until I switched to landscape mode and then I got Mio Map V3 and now I can't switch back to Igo. I did not create any shortcuts or anything like that. Just installed iGO and that's what happened. I have Miomap.exe in the root directory of my SD caard but it does not matter if I click on it or iGO.exe I always get the Mio Map screen. When I try to change to portrait mode, it just cliks but won't change back. Any ideas? Steve |
09-01-2006, 16:25 | #5 (permalink) |
Member: 329973 Status: Offline Thanks Meter: 0 | [quote=Steve672;1960797]Quek I have installed you duo version. Everything worked fine until I switched to landscape mode and then I got Mio Map V3 and now I can't switch back to Igo. I did not create any shortcuts or anything like that. Just installed iGO and that's what happened. I have Miomap.exe in the root directory of my SD caard but it does not matter if I click on it or iGO.exe I always get the Mio Map screen. When I try to change to portrait mode, it just cliks but won't change back. Any ideas? Steve[/quote That's funny, I always have IGO, I can have only Mio if I tap on the Miomap.exe.You should try a soft reset and see what happen. Let me know about this regards |
09-02-2006, 15:05 | #6 (permalink) |
Member: 331335 Status: Offline Thanks Meter: 0 | quek OK. I did a soft reset and now I can switch between portrait and landscape with no problems. Tho only issues are: 1. It reverts to Miomap in landscape mode and iGO in portrait mode. 2. On the bottom of my screen when I tap on the little arow in the right left corner I have the option of adding a speed camera whereas in the past I had the option of adding a marker. I can no longer add a marker. Strange. Any ideas about either of the above? cheers |
09-02-2006, 17:05 | #7 (permalink) | ||
You can only add speed cam on the MIOMAP version. Just tap on any screen and you see a red dot and tap on ADD VIA...there you get a marker Regards | ||
09-02-2006, 17:08 | #8 (permalink) | |
regards quek | |
09-05-2006, 02:20 | #10 (permalink) |
Member: 331335 Status: Offline Thanks Meter: 0 | quek In the landscape mode I am always in Miomap even though I don't even have mio.exe on my sd card. I even tried a soft reset hoping it would erase it from memory. Any thougts? Steve |
09-05-2006, 16:24 | #11 (permalink) | |
I might have posted one without the Mio before. If you son't have let me know...just used the same license regards quek | |
02-10-2007, 17:47 | #13 (permalink) |
Freak Poster Join Date: May 2004 Location: Poland, Poznan Age: 38
Member: 66993 Status: Offline Thanks Meter: 12 | Hi! Can anyone give me new link to map of Bulgaria? Beacuse link from firsts pages dont working :/ Ok I found it. Last edited by haller; 02-11-2007 at 21:18. |
Igo europe v1.1 torrent!!!! | biladz | iOS Application, games & media area | 0 | 12-10-2009 15:28 |
IGO MYway 2006 | pepin@ | GPS devices , Navigators & Maps | 0 | 05-29-2009 08:47 |
iGo 2006 europe for simbyan ??? | DJ_Andy | Nokia Multimedia | 1 | 02-07-2008 13:33 |
iGO Europe 2006 POI shut down problem | Signor Al | HTC & PDA WM( With Touchscreen) | 1 | 03-06-2007 20:29 |
iGo 2006 EUROPE + Israel Licensing problem | Jeuk | HTC & PDA WM( With Touchscreen) | 3 | 03-06-2007 10:49 |
