GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
06-14-2005, 06:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 41
Member: 78673 Status: Offline Thanks Meter: 1,253 | Upgrading, Modifying Pocket PC's What do we Need? 1.ActiveSync4 2.Windows Mobile 2003 Rom-Editor 3.Patch 4.WM2005 OS What to Install first? 1.Install the ActiveSync4 first, 2.Then install the Windows Mobile 2003 Rom-Editor NOTE: Your PC's Windows must be Windows XP SP2. Procedure: 1.Open the "patch1.exe" Photo 2.Click "browse" Photo 3.Select "NK.nbf" Photo 4.Click "Patch" (if the patch return an error .. it means the rom is already been patch) Photo 5.Open "NK.nbf" Photo 6.With Windows Mobile 2003-Rom editor Photo 7.Click the "Operator" scroll down bar Photo 8.Select the Appropriate Operator (if you dont know the operator id...just use modified himaupgradeut_noid.exe) Photo 9.Save the ROM Image and Exit Photo 10.Put the Himalaya to Bootloader Mode Photo 11.Connect the Himalaya directly to USB port and Open the "HimaUpgradeUt.exe" Photo 12.Click ''next" Photo 13.Click "Upgrade" Photo 14.SitBack and Relax while waiting! Photo 15.All Job Done! 16.Now, Without Connecting the Himalaya to PC, delete the old Partnership Photo 17.Connect the Himalaya to PC to Sync... Photo 18.And the Last step is to Hard Reset your Himalaya(Device) Follow the Procudure on the Picture. Photo Files To be Download: Windows Mobile 2005-Nk.nbf_Rom File (22.5 MB) ActiveSync 4 (5.6 MB) Windows Mobile 2003 Rom-Editor (2.5 MB) Last edited by HuBMOBILE; 06-14-2005 at 09:02. |
06-22-2005, 12:48 | #2 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | Upgrading From Win2003 to Win2003SE Himalaya Upgrade From Win2003 to Win2003SE We currently only have 3 versions of WM2003SE, each with it's shortcomings: Version 2.20.xxCHS is in Chinese and although it's currently being translated into English, there's still a way to go! So let's focus on the two remaining versions, both in English: Version 2.02.t1WWE Pro's: Stable with no hangs/delays on reboot, utilizes HandsFree Profile Con's: Lacks ClearType implementation and Media Player 10 Version 2.06.00WWE Pro's: ClearType implemented and Utilizes Headset Profile Con's: Hangs/delays on reboot and no Media Player 10 The good news is that it's possible to obtain the "best of both worlds" by merging the two operating systems. By first flashing your ROM with 2.02.t1WWE and creating an ActiveSync backup, it's possible to then flash with 2.06.00WWE and restore from the backup. The end result is surprising - ActiveSync merges the two operating systems! There are no delays/hangs on reboot and ClearType looks great. It's also possible to re-enable Handsfree Profile through a simple registry patch. What do we Need? 1.ActiveSync4 2.Windows Mobile 2003 Rom-Editor 3.WM2003SE OS (Version 2.06.00WWE) 4.Setup 5.ROM_Backup 6.Backup (No need to flash with 2.02.t1WWE, this backup is ready to restore over 2.06.00WWE!) NOTE: It is supplied as is. Use it at your own risk!!! TIP: First backup your data and settings using either ActiveSync, SDBackup or XBackup - then download the attached ROM_Backup.zip - extract and follow the instructions in the ROM backup folder. To install the merged WM2003SE: 1. Download the attached Setup.exe 2. Insert your O2 XDA II into it's USB cradle and confirm that a successful USB connection has been made with your PC 3. Run Setup.exe and follow the onscreen prompts. Details: The ROM image is version: 2.06.00WWE (ver 4.21.1088 build 14132) The Radio image is version: 1.18.00 The Extended ROM image is a variance of version 2.06.100a (Sin.Merged.v2.0) 4. Extract the contents of "WM2003SE_20600WWE.zip" into the same folder on your PC, Insert your XDA II into it's USB cradle (confirm that a successful USB connection has been made) and run HimaUpgradeUt.exe to start the installation. 5.And follow the steps on the screen. 6.Now after the upgrade is done, here's a file i've found on the internet that is very useful b'coz you don't need to flash with 2.02.t1WWE, this backup is ready to restore over 2.06.00WWE! Few tweaks were made to it prior to backup: Created "Start Menu" folders: Business, Communications, Games, Graphics, MultiMedia & System Turned Off incoming IR Beam for GPS compatibility Mapped Camera Button Set Word Completion to 4 words after 1 letter (no caps or spaces) Set Voice Recording to 44,100 Hz, 16 Bit, Stereo Changed Phone Ring to Vibrate & Ring, set to Terrestrial & Keypad Tones Turned on Screen Taps Enabled Today "New Menu" Turned on Microphone AGC Set Screen & Power Off to 2mins Removed merged BT Registry to allow choices later via patch. 7. To restore this backup, Flash your XDA II with 2.06.00WWE. After installation, don't change any of the following default settings: time zone (GMT-8 Pacific US), device name (Pocket_PC) or regional settings (United States), instead setup an ActiveSync partnership (not Guest) and untick all items such as Calendar, Contacts etc... so no items will by Synced. Restore by opening ActiveSync, then clicking "Tools=>Backup/Restore" - browse to the downloaded "Backup.zip" and extract the file "Backup.stg", select it with ActiveSync and then switch to the restore tab, finally clicking "Restore Now". ***Provided that the device name & regional settings match the above, ActiveSync restore will merge the 2 versions and prompt you to restart your O2 XDA II.*** 8.You now have a merged operating system but still need to add at least the basic functionality of MMS, Camera etc... Each cab file below can be copied to your XDA II's memory/SD card and executed individually, however it would be far easier to bundle everything into the one installation routine. As most of you know, your XDA II has a hidden partition called the Extended ROM, which (without tweaking) is limited to a capacity of 16MB. Using an Extended Rom unlocking tool, it's possible to manually copy each cab file and associated system file into the Extended ROM using "File Explorer". Start by downloading the attached "ExtRom_tools.cab" and copy to your XDA II's memory (Either via ActiveSync or SD Card if you have a Reader). Then execute it by browsing to it with "File Explorer", your Extended ROM will be revealed once you reboot after installation is complete. You'll notice 4 new icons in your "System" folder. Run "ExtROM Unlock" to allow files to be written and removed. NOTE: If all are downloaded and placed into Extended ROM, the total Memory will be 16MB. Each will place their shortcuts in the approprite category and where possible, settings are pre-configured. 9.Now that you've copied your selection of "cab files". "exe files" & "txt files" to your "Extended ROM" and also configured your "Config.txt" to reflect any file name changes, plus edited your "AutoConfig.txt" to suit your Carrier's files - it's time to install it all! a. Some Cab files are notorious for self-deleting once run, for that reason I suggest that you lock your Extended ROM by clicking on "Start Menu->System->ExtROM Lock". b. Using "File Explorer", execute "AutoRun.exe" in your Extended ROM, then sit back & watch it all come alive! c. Your XDA II will reboot automatically once installation is complete. Your Carrier Settings won't be installed until much later, Don't Panic! 10.The following process is quite straight forward. It involves installing Sprite Backup, copying 2 links to startup and 1 batch file to windows. Then running Sprite Backup to create a Self-Restoring backup file. Here's How: 1. Download the attached "Sprite_Backup.cab" and install on your XDA II, then reboot. 2. Download and extract Windows_Batch.zip and copy it's contents: cleanup.bat" to your XDA II's "Windows" folder "z_ac" to your XDA II's "Windows/Startup" folder "z_cu" to your XDA II's "Windows/Startup" folder NOTE: Don't Reboot! 3. Run Sprite Backup and under "Options->Backup Options->General Backup Options", ensure that everything but "Encrypt Backup" is ticked, then press "OK" 4. Browse to the location the backup will be stored to (SD or Main memory) by selecting ... and name the file: ExtROM, then press "OK" (bottom right of screen) - Now press "Backup", then sit back & wait! 11. Congratulations, you should now have a backup of a merged OS that will easily fit into the Extended ROM (compression). Here's how to Automate it: 1. Run "Start Menu->System->ExtROM Unlock" 2. Use Explorer to browse and delete the contents of the Extended ROM except for the following file: "AutoRun.exe" 3. Copy the ExtROM.exe file that Sprite Backup created to your Extended ROM. 4. Copy each of the attached files to your extended ROM: Config.txt Optus_AU_GPRS.cab Optus_AU_MMS.cab Telstra_AU_Favourites.exe Telstra_AU_GPRS.cab Telstra_AU_MMS.cab Vodafone_AU_GPRS.cab Vodafone_AU_GPRS.exe Vodafone_AU_MMS.cab If your using your own Carrier files (the ones that match up with AutoConfig.txt), be sure to include those instead. 5. Lock your Extended ROM using "Start menu->System->ExtROM Lock" 12. And the Last step is to Hard Reset your Himalaya(Device) Follow the Procudure on the Picture. Last edited by HuBMOBILE; 06-23-2005 at 20:54. |
06-23-2005, 20:59 | #6 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | Thanx to all For the Support... Specially to our Moderator, Thank you very much for adding this Thread to the Sticky Section... Hope to do much better in Future with your Support Dudes... Regards |
The Following User Says Thank You to HuBMOBILE For This Useful Post: |
06-24-2005, 18:58 | #7 (permalink) |
Freak Poster Join Date: Apr 2005 Location: saudia arabia Age: 45
Member: 132838 Status: Offline Thanks Meter: 49 | hi what i do hi man thankssssssssssssssssssss for that post wm2005 updates,. i have some problems ,.,.,. i dont have download accelator permenum account i cant download from ur given link plz man post them here ,.,.or give some another link man ,.,,. i will wait for ur post ,.,.,.thanksssssssssss ,.,.,. @hubmobile |
06-24-2005, 19:00 | #8 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | @alimazhar Disable your Download Acclerator if your using any, coz Rapidshare doesn't supports it for the Free Accounts..Let the Windows default Downloader manage the downloads when your downloading from Rapidshare.... |
06-25-2005, 23:27 | #9 (permalink) |
Member: 132838 Status: Offline Thanks Meter: 49 | wooooooooooooo @hubmobile thankssssssssssssssssss man u r some thing i download all the reqiured things ,.,.,.,.,. man keep it up ,. forum needs guy like u ,.,.,. one thing man can i upgrade my i mate jam with this ????? and what happen if i upgrade it any new features??? keep it man ,.,.. |
06-25-2005, 23:38 | #10 (permalink) |
Member: 132838 Status: Offline Thanks Meter: 49 | problem again ????? the patch.exe did not patch nk.nbf file what i do now,.,.,.,.??? it say ,.,. sorry,file can not be patched. wait for ur reply thanksssssssssssssss |
06-26-2005, 02:18 | #11 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 4270 Status: Offline Thanks Meter: 13 | Hi great work, u the man truely. Firstly, i would like to verify if this will work on other PDA, except the o2 xda 2 could u verify if the patch gives me the error sorry, you cannot patch this file. is that still acceptable ? you said if it gives u an error its ok, but in the pic it gave some other error so i wanted to make sure. also 8.Select the Appropriate Operator (if you dont know the operator id...just use modified himaupgradeut_noid.exe) where can i find himaupgradeut_noid.exe cause my provider is not listed. reo Last edited by reo; 06-26-2005 at 02:34. |
06-26-2005, 16:39 | #12 (permalink) |
Member: 132838 Status: Offline Thanks Meter: 49 | 64MB to 128MB Internal RAM Upgrade DO U HEARD?????? iMate JAM/XDA Mini Series 64MB to 128MB Internal RAM Upgrade Description: Upgrade your iMate JAM/XDA Mini series internal RAM from 64MB to 128MB with our upgrade service. During the upgrade process we remove the existing 64MB and install 128MB. This memory upgrade does NOT require our proprietary driver and is fully recognized by the OS (121.39MB Available). This unit uses low voltage hi-speed BGA memory, so stacking is not available and 128MB will be the maximum capacity. CHEAK THE SITE : http://www.pocketpctechs.com/detail....JAM-064-128RAM it is NOT FREE ,.,. 200$ DO SOME THING GOOD GUYES ,.,.,.,. NEED THAT UPGRADE,.,.,. |
06-26-2005, 17:15 | #13 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | @alimazhar Its Really a Good Thing but We can't do anything Still, Maybe by the Time it gets old any cracked version will be Released soon...All we have to do is Wait... |
06-26-2005, 17:22 | #14 (permalink) | |
Member: 132838 Status: Offline Thanks Meter: 49 | Some One Solve This Quote:
SOME ONE SOLVE THIS PLS ,.,., | |
Upgrading ,modifing Hp Ipaq Pocket Pc Here | rajan nishchal | HTC & PDA WM( With Touchscreen) | 24 | 10-19-2010 12:57 |
how to read my pocket pc's sms through my pc | welchvahe | HTC & PDA WM( With Touchscreen) | 2 | 07-14-2009 08:05 |
any ways to upgrade pocket pc wm2002 to wm 2003 | doctormab | HTC & PDA WM( With Touchscreen) | 4 | 03-01-2007 09:13 |
HOW TO USE YPUR POCKET PC'S WiFi? | harryx | HTC & PDA WM( With Touchscreen) | 2 | 03-27-2006 22:23 |
Problem ROM Upgrade (i-mate) Pocket PC? | amanaf | HTC & PDA WM( With Touchscreen) | 2 | 11-08-2005 11:05 |
