05-07-2011, 18:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Indonesia-D.K.I Jaya
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | don't use usb port in super doctor 3 After using usb port in your box to connect the other phone, my box not connect anymore. I have tried the other pc.....same problem. If your box sounds like.....(Kletek...kletek) when I try to connect box. if it sounds like that your box not working anymore. Here is the step : 1. Remove driver...upgrade firmware v.153 (conjunction error) 2. Conjuction box error....I try to fix : unplug box, red cable and black are joined and then plug box then thick oxygen upgrade.....still error. What's wrong is it ???? I have returned that box...I have a new sp3. I do same...my box was killed . In my opinion....don't try to use usb pOrt in super doctor 3 if you don't want your box died. Sorry mtk team if I am wrong.... Note : kletek...kletek like sounds abnormally |
05-07-2011, 19:17 | #2 (permalink) | |
Freak Poster Join Date: May 2008 Location: PONOROGO-INDONESIA IS MY LIVE
Member: 774884 Status: Offline Thanks Meter: 52 | Quote:
ANY SOLUTION BOX EROR OR UPDATE FRIMWARE EROR BECAUSE DOWNGRADE FRIMWARE 1.51 IS OK FOR SCAN PINOUT BUT SOFTWARE EROR RESICTRIC....WHY???? SORY MY ENGGLIS IS BAD AND WHAT IS KLETEK KLETEK BROO | |
05-08-2011, 04:32 | #4 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | If you get "Conjuction Error" while updating your box, means you have some problem with your box firmware. To fix this. you need to upgrade the firmware by using "Emmergency UpGrade" feature. Disconnect MTK BOX-3 Box from USB, connect the main cable to MTK BOX-3. Now short the "+" and "-" wires of the main cable Connect computer with USB to MTK BOX-3. Open the latest Box firmware Updater software for MTK BOX-3. Press "ScanPort", Select your MTK BOX-3 comm port number, tick the "Exigency UpGrade" and press "UpGrade-BOX" BR, VIJAY-GSM Last edited by VIJAY2U2; 05-08-2011 at 08:00. |
05-08-2011, 13:51 | #5 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | I have read when i tick Exigency UpGrade. I have followed that instruction, but the problem not solved maybe 10-15 times do something like that Have you tried to use usb port in spd3 box 3 to connect the other phone ??? I'm sure if do like that, your box isn't connect anymore Sorry if i am disrespectful BR: toto Last edited by VIJAY2U2; 05-09-2011 at 04:58. |
05-08-2011, 14:16 | #6 (permalink) | |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
hi, wat is the condition of the now???????? Finding pin via cable or not???????????? As far as i know sd3 usb port is not 4 pinfinding CORRECT ME if i m wrong | |
05-08-2011, 18:32 | #7 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | I use usb port for another job.....not looking for pinfinding, sir Sometimes I use usb port into the box that I have to connect phone....e.g : back up my blackberry data, pc sync for my nokia phone with using usb port at the box (saras box, spiderman box, mcn and many box which have usb port. I usually use it, all box what I have is not problem if the usb port is used. But spd3 box has a problem...when I use the usb port. My box suddenly died. Not connect anymore.... I'm sorry sir if I was wrong BR :::::: |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
