Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 07-19-2018, 20:08   #1 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 29
Exclamation help remove frp MI MIX 2S
I would like to know if this model is supported to remove frp
Old 07-22-2018, 00:03   #2 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 29
I will be answered at least tell me if this model is not supported
Old 07-24-2018, 16:04   #3 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 29
some answer mrt team
Old 07-24-2018, 16:16   #4 (permalink)
Member: 2821424
Thanks Meter: 70
Not support now.
从我的 iPhone 发送,使用 Tapatalk
Old 07-24-2018, 19:23   #5 (permalink)
Member: 69366
Thanks Meter: 39
recently, more and more often such answers from support and closed topic
Old 08-08-2018, 19:02   #6 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 29
I still have the device in hand maybe I could help
MRT team
Old 09-25-2018, 18:11   #7 (permalink)
Member: 2501288
Thanks Meter: 328
i have same problem mi mix 2s frp
Old 09-26-2018, 04:18   #8 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
You can try like this ( use test point )
Open MRT Dongle - click QC TOOL.
And select boot file from folder of firmware (prof_firehose....)
Connect phone in EDL Mode (9008)
And select Erase FRP and Click Start.
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 10-11-2018, 12:04   #9 (permalink)
Member: 2501288
Thanks Meter: 328
not work
The Following User Says Thank You to Steve-1 For This Useful Post:
Old 10-11-2018, 14:55   #10 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Make sure firehose is correct and try reinstal the driver
Old 10-11-2018, 14:56   #11 (permalink)
Member: 2501288
Thanks Meter: 328
All correct, its not supported.
Page generated in 0.20143 seconds with 8 queries
