05-09-2017, 04:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: asdfsdf
Member: 2439634 Status: Offline Sonork: logimon999 Thanks Meter: 188 | meizu M571c removed code [ SOLVED ] other no one box cannot remove? MRT team good luck thanks teacher Zhulianqi Zhulianqi Zhulianqi Zhulianqi many many thanks |
05-09-2017, 06:22 | #3 (permalink) |
Member: 2439634 Status: Offline Sonork: logimon999 Thanks Meter: 188 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM44 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:R821MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100523832314D Flash Name: Samsung_KMR820001M_B609 Flash symbol: R821MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM45 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM45 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x00A4000000 Size(HEX):0x02FED80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to logimon999 For This Useful Post: |
05-09-2017, 06:42 | #4 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Good! Also post what are the steps ! Sharing with other friends maybe useful |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
05-09-2017, 08:01 | #5 (permalink) |
Member: 2439634 Status: Offline Sonork: logimon999 Thanks Meter: 188 | 1. power off phone 2. run mrt v1.78 3. meizu option note2 cdma tick, remove password tick and FACTORY MOBILE tick 4. start button 5. volume up down button together press and connect usb Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM44 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:R821MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100523832314D Flash Name: Samsung_KMR820001M_B609 Flash symbol: R821MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM45 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM45 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x00A4000000 Size(HEX):0x02FED80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! and successfully removed passcode Thanks teacher Zhulianqi |
