Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 09-28-2017, 05:59   #556 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
The Following 3 Users Say Thank You to .::ARD::. For This Useful Post:
Old 09-28-2017, 06:38   #557 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
I have NO BURDEN OR SHAME to announce this, and said FIRST IN THE WORLD!!!
because this is the ORIGINAL FEATURE of our team
AFTER THIS ... FACING FRP LOCK, NO DOUBT !!!
MRT DONGLE IN MY HAND!!
DONE !!!
Old 09-28-2017, 09:49   #558 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
The Following 8 Users Say Thank You to .::ARD::. For This Useful Post:
Old 09-28-2017, 11:23   #559 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Story of Success MRT Product [ Read/Write/Format/Unlock...etc ]
Old 09-28-2017, 11:51   #560 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
Oppo F1s PL Remove Done Just A Single Click
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM15
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6755
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CB00
>>> Initialization Mobile ...Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000E8F800000 -> 59640M
Flash ID: 0x150100524331344D
Flash Name: Samsung_Unknow
Flash symbol: RC14MB
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM16
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
>>>>Formating Mobile USER Data...
ADD(HEX):0x00E1000000 Size(HEX):0x0DAD7FBE00
Corresponding operation completed!!!
The Following 2 Users Say Thank You to VC_INDIA For This Useful Post:
Old 09-28-2017, 13:17   #561 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 245
success remove micloud xiaomi redmi note 4x
if the sensor and relogin micloud account does not work then the solution must be rewritten persist only
The Following User Says Thank You to wutangclan33 For This Useful Post:
Old 09-28-2017, 14:21   #562 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
Vivo V1 Pl Remove Done
Searching Android Mobile...
Get the Android Deivers
Mobile Info: INFO Device style: PD1502F_EX_A_2.5.24
Try Unlock Bootload with algorithm 1
algorithm 1 Info: FAILunknown command or device is lock
Try Unlock Bootload with algorithm 2
algorithm 2 Info: OKAY rebooting bootloader
Eraseing Block userdata
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8112
Inode size: 256
Journal blocks: 32768
Label:
Blocks: 2853883
Block groups: 88
d block group size: 703
Created filesystem with 11/713856 inodes and 84613/2853883 blocks
Block size: 4096
Inodes per group: 6400
Inode size: 256
Journal blocks: 1200
Label:
Blocks: 76800
Block groups: 3
Reserved block group size: 23
Created filesystem with 11/19200 inodes and 2459/76800 blocks
< waiting for device >
target reported max download size of 1992294400 bytes
sing 'userdata'...
OKAY [ 11.943s]
sending 'userdata' (136710 KB)...
OKAY [ 4.337s]
writing 'userdata'...
OKAY [ 3.715s]
erasing 'cache'...
OKAY [ 0.137s]
sending 'cache' (6544 KB)...
OKAY [ 0.216s]
writing 'cache'...
OKAY [ 0.184s]
hed. total time: 20.533s
rebooting...
finished. total time: 0.000s
Old 10-01-2017, 00:07   #563 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
Huawei Y6 II CAM-L21 frp unlock done
>>>>search android fastboot devices...
>>>>Get android fastboot devices...
    Mobile Name: CAM-L21
    Mobile Set BL Lock state:FB LockState: LOCKED
    Trying First Way for Get the Unlock code
    Dynamic unlock code:1a4441b1dc373988    Connecting To Service...
    Bootloader Temporary  Unlock Done
    tip:Bootloader Temporary after reboot will lock again
>>>>Clear Frp Block
    OKAY [  0.091s]
    finished. total time: 0.091s
>>>>Rebooting Mobile Phone
    rebooting...
    finished. total time: 0.025s
The Following 2 Users Say Thank You to SVH For This Useful Post:
Old 10-02-2017, 13:40   #564 (permalink)
Member: 1616754
Thanks Meter: 245
Everything is fine
format and remove FRP done by MRT dongle
I do not know the other can or not
because I directly execute with MRT, just few seconds
NB: Thanks to Ident De Zet for mz_init file, your amazing bro
Format Device
Remove FRP Device
Old 10-02-2017, 20:24   #565 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Oppo A57 One click unlock MRT Dongle
Old 10-03-2017, 06:18   #566 (permalink)
iOS_Shakil's Avatar
Member: 2441719
Sonork: uninstall
Thanks Meter: 2,073
Redmi Note 3 Mi Account Remove Done By MRT Dongle
Thanks Team For Hard Work​
The Following User Says Thank You to iOS_Shakil For This Useful Post:
Old 10-04-2017, 13:18   #567 (permalink)
applestorebd's Avatar
Member: 1659078
Sonork: Mahidi Munna
Thanks Meter: 199
Arrow Vibo 1609 Imei Repair Done
Get Mobile Port is: COM17COM17
MediaTek PreLoader USB VCOM (Android)
Set Port To COM17Success
Into Meta Mode...Success
Switch Moile to Repair IMEI Port...
Get Mobile Port is: COM39COM39
MediaTek USB VCOM (Android)
>>> Into META Repair IMEI Mode...Success
reading the relevant parameters of the phone information...
CPU_TYPE:mt6750,S01
Bulid_Time:Mon May 8 22:10:27 CST 2017
Base_Ver:alps-mp-m0.mp7-V2.10_bbk6750.66.m
Soft_Ver:MRA58K release-keys
Software Has be change to IMEI algorithm 2...
Original_IMEI 1:863715038748033
New_IMEI 1: 357804165303313
Original_IMEI 2:863715038748025
New_IMEI 2: 357804165303314
Old 10-05-2017, 12:02   #568 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 345
HUAWEI SCL-U31 FRp done
Mobile Name: HUAWEI SCL-U31
Mobile Set BL Lock state:B LockState: LOCKE
Dynamic unlock code:006f635a6c8efe58
>>>>Clear Frp Block
(bootloader) Erase success , the device will reboot and factory reset
OKAY [ 0.121s]
finished. total time: 0.121s
rebooting...
finished. total time: 0.011s
The Following User Says Thank You to GsmKotla For This Useful Post:
Old 10-05-2017, 14:25   #569 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Unlock meizu note lock
Unlock meizu note1 cloud with MRT
File Type: jpg 3BBDCB02-076B-4B0C-930E-3FC199ED2F45.jpg (190.3 KB, 19 views)
The Following 2 Users Say Thank You to desmond2727 For This Useful Post:
Old 10-05-2017, 14:33   #570 (permalink)
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Unlock Remi2014910 micloud done
Unlock redmi201491 micloud done with MRT
File Type: jpg 6A164A67-4A9B-4EDD-9672-2F084105322F.jpg (169.7 KB, 20 views)
File Type: jpg F4E94059-2DBD-4C44-9903-119C1BE3BC86.jpg (194.8 KB, 20 views)
File Type: jpg 30DCEA68-B5BB-4835-94A0-BFFA0C609346.jpg (305.6 KB, 25 views)
The Following User Says Thank You to desmond2727 For This Useful Post:
Page generated in 0.69372 seconds with 9 queries
