10-14-2017, 06:21 | #586 (permalink) |
Major Poster Join Date: Mar 2014 Location: Philippines
Member: 2141040 Status: Offline Thanks Meter: 17 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Thanks team for big update and also to who upload the boot file download boot file https://www.4shared.com/file/P4J5Dyt..._8953_ddr.html |
10-17-2017, 07:15 | #591 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2753981 Status: Offline Thanks Meter: 3 | oppo a37f format unlock done.................... >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x209F2094 MSM_ID: 0x007050E1 CPUĐͺÅ: MSM8916 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ƠưÔÚ¶ÁÈ¡ÊÖ»ú·ÖÇøÊư¾Ư...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E2788000 Size:0x02C1673E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done |
10-18-2017, 13:03 | #592 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Meizu M3 note one click unlock - Done !! |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
10-20-2017, 03:58 | #594 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xB381B889 MSM_ID: 0x0008C0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile IMEI Info...Success org imei:865463038392274 >>>>Erasing Userdata... ËùÓвÙ×÷ÒÑÍê³É Success after fail 1 time |
The Following User Says Thank You to goldenfish125 For This Useful Post: |
10-22-2017, 09:22 | #598 (permalink) | |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | oppo f1s pattern lock and frp remove done oppo f1s pattern lock and frp remove done [IMG][/IMG] Quote:
The Following User Says Thank You to pintu_das For This Useful Post: |
10-22-2017, 18:11 | #599 (permalink) |
Freak Poster Join Date: Jan 2014 Location: algeria
Member: 2116178 Status: Offline Thanks Meter: 38 | Meizu M5 Remove PASSCODE Done Easy.... Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM301 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM366 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x065BBFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to cruse For This Useful Post: |
10-22-2017, 20:49 | #600 (permalink) |
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | OPPO F3 CPH 1609 WRITE IMEI DONE !!!! HAVE A NICE DAY !!!! |
The Following 5 Users Say Thank You to .::ARD::. For This Useful Post: |
