10-23-2017, 03:22 | #601 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware InfoF4016 >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x4501004446343031 Flash Name: Sandisk_Unknow Flash symbol: DF4016 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM13 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM13 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A40000 Size(HEX):0x0000100000 Corresponding operation completed!!! mobistar zumbo j2 frp Last edited by .::ARD::.; 10-23-2017 at 03:33. Reason: Show image |
10-23-2017, 07:07 | #602 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | G6-U10 successfull flash >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: Invalid command Mobile Set BL Lock state:nvalid comman Trying First Way for Get the Unlock code Read Mobile Dynamic unlock code Fail Trying Second Way for Get the Unlock code Read Mobile Dynamic unlock code Second way Fail >>>>search android fastboot devices... >>>>Get android fastboot devices... Writeing Block crc...Fail FAILCommand not allowed Writeing Block oemsbl_verlist...Fail FAILCommand not allowed Writeing Block amss_verlist...Fail FAILCommand not allowed Writeing Block gpt...Fail FAILCommand not allowed Writeing Block rpm...Fail FAILCommand not allowed Writeing Block tz...Fail FAILCommand not allowed Writeing Block sbl1...Fail FAILCommand not allowed Writeing Block modem...Fail FAILCommand not allowed Writeing Block sdi...Fail FAILCommand not allowed Writeing Block modemst1...Fail FAILCommand not allowed Writeing Block modemst2...Fail FAILCommand not allowed Writeing Block fsg...Fail FAILCommand not allowed Writeing Block aboot...Fail FAILCommand not allowed Writeing Block recovery...Success Writeing Block userdata...Success Writeing Block cache...Fail FAILCommand not allowed Writeing Block persist...Fail FAILCommand not allowed Writeing Block boot...Success updating temp file form flash file... Writeing Block system... tip:software is runing,maybe it will take 2~5 Minute target reported max download size of 536870912 bytes erasing 'system'... OKAY [ 2.093s] sending sparse 'system' (522934 KB)... OKAY [ 22.810s] writing 'system'... OKAY [ 53.615s] sending sparse 'system' (494595 KB)... OKAY [ 21.597s] stem'... OKAY [ 55.348s] finished. total time: 155.464s updating temp file form flash file... Writeing Block cust... tip:software is runing,maybe it will take 2~5 Minute target reported max download size of 536870912 bytes sending 'cust' (233853 KB)... OKAY [ 9.289s] writing 'cust'... FAILED (remote: Command not allowed) finished. total time: 9.292s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.005s 重要提醒: 如果刷机定第一屏重启... 手机不要插充电器及数据线,长按音量上加开机进模式, 进模式后点出厂设置即可 |
The Following User Says Thank You to GsmKotla For This Useful Post: |
10-23-2017, 08:15 | #603 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] 1)MRT qualcom unlock 2)select oppo A33 then START option wait for finish |
10-23-2017, 09:08 | #604 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | MI MAX MICLOUD REMOVED BY GREAT MRT DONGLE credited to Aan wisnu |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
10-23-2017, 11:06 | #605 (permalink) |
Freak Poster Join Date: May 2007 Location: BetaMax Tester
Member: 516470 Status: Offline Thanks Meter: 70 | Mi5 Mi account removed >>>Try connect to mobile...Success CPU_SN: 0x23166D4B MSM_ID: 0x009470E1 >>>Try connect to mobile...Success >>> Initialization Mobile ...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: UFS CPU Type: MSM8996 >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0002000000 Size: 0x0002000000 >>>>Flashing Mobile data...Success Corresponding operation completed!!! |
The Following User Says Thank You to J_M For This Useful Post: |
10-23-2017, 12:51 | #606 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM30 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:JHBG4a >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: JHBG4a >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM18 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM18 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A00000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
10-23-2017, 16:22 | #607 (permalink) |
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | RENO 4 MIDO MICLOUD REMOVED BY MRT DONGLE |
10-25-2017, 04:50 | #613 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 245 | CoolPad E503 MT6735 Remove Google Account not the first in the world but simple in doing Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM71 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:NQ2J96 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x13014E51324A3936 Flash Name: UNKNOWN Flash symbol: NQ2J96 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM51 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM51 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x001AF80000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
The Following User Says Thank You to wutangclan33 For This Useful Post: |
10-25-2017, 06:17 | #615 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | Redmi 4X remove mi account done via test point >>>Try connect to mobile...Success CPU_SN: 0xAE50C2B8 MSM_ID: 0x0006B0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
The Following 2 Users Say Thank You to kjava For This Useful Post: |
