06-09-2018, 13:25 | #917 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | OPPo A71 succes remove patteran with MRT dongle here is logs:- >>>Try connect to mobile...Success CPU_SN: 0xA0C6B90A MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile IMEI Info...Success org imei:867762030688839 >>>>Erasing Userdata... Corresponding operation completed!!! BR. USMAN SOFTWARE |
06-11-2018, 12:13 | #918 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V9 done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x33676A34 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x0185482000 Size:0x0D0A379E00 >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x33676A34 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Eraseing Block frp ADD:0x0168180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to wsmobile For This Useful Post: |
06-11-2018, 12:42 | #919 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | OPPO F1 PLUS (X9009) remove user lock done with great mrt dongle OPPO F1 PLUS (X9009) remove user lock done with great mrt dongle [IMG][/IMG] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM19 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524331344D Flash Name: Samsung_Unknow Flash symbol: RC14MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM37 >>> Device driver identification: MediaTek DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00D8000000 Size(HEX):0x0DB67FBE00 Corresponding operation completed!!! Thanks MRT team |
The Following User Says Thank You to pintu_das For This Useful Post: |
06-13-2018, 08:43 | #920 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | MI 4 LTE ACCOUNT REMOVED IN 13 SECONDS This set not have Bootload lock Unlock it need into fastboot(vol down and power key) Connect usb to computer,and click unlock account after connect the mobile please make sure driver has install!!! this set support unlock account by one click!!! *************************************** Connecting Mobile Phone... please connect your phone as fastboot... Clear Mobile data... Creating filesystem with parameters: Size: 13610496000 Block size: 4096 Blocks per group: 32768 Inodes per group: 8160 Inode size: 256 Journal blocks: 32768 Label: Blocks: 3322875 Block groups: 102 ed block group size: 815 Created filesystem with 11/832320 inodes and 93165/3322875 blocks Creating filesystem with parameters: Size: 402653184 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Journal blocks: 1536 Label: Blocks: 98304 Block groups: 3 Reserved block group size: 23 Created filesystem with 11/24576 inodes and 3131/98304 blocks target reported max download size of 805306368 bytes erasing 'userdata'... [ 3.961s] sending 'userdata' (137282 KB)... OKAY [ 4.354s] writing 'userdata'... OKAY [ 3.127s] erasing 'cache'... OKAY [ 0.016s] sending 'cache' (8336 KB)... OKAY [ 0.324s] writing 'cache'... OKAY [ 0.195s] Clear Mobile account data... ******** Did you mean to fastboot format this partition? erasing 'persist'... OKAY [ 0.013s] finished. total time: 0.013s reboot mobile set... rebooting... finished. total time: 0.001s |
06-13-2018, 18:31 | #921 (permalink) |
Freak Poster Join Date: Apr 2015 Location: maroc Age: 38
Member: 2373850 Status: Offline Sonork: himo Thanks Meter: 60 | format unlock oppo f7 done MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100444836444D Flash Name: Samsung_Unknow Flash symbol: DH6DMB >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
06-14-2018, 03:19 | #922 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: cold place
Member: 1316900 Status: Offline Sonork: none Thanks Meter: 30 | SLA-TL10 frp done >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: SLA-TL10 Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:242afc1c0e8178c8 >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:243e5cb91a8866cd Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:25c1d3a2e9061378 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) Erase success , the device will reboot and factory reset OKAY [ 0.016s] finished. total time: 0.016s >>>>Rebooting Mobile Phone |
06-14-2018, 03:19 | #923 (permalink) |
06-14-2018, 12:19 | #924 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | A71-QLM done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xDB014DF5 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile IMEI Info...Success org imei:868498038708274 >>>>Erasing Userdata... Corresponding operation completed!!! |
06-20-2018, 12:44 | #925 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO X21A done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x3481B8E5 MSM_ID: 0x0008C0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>ีิฺวะปปตฝถมะดฤฃสฝSuccess Flasy type: UFS CPU ภเะอ: MSM8996 >>>>read mobile GPT data...Success ีิฺวๅณสึป๚ห๘สพ... วๅณอ๊ณษบ๓ปแตผึยสึป๚ตฤำรปงสพถชสง... ธ๑สฝปฏตุึท:ADD:0x0190800000 Size:0x1B8E3FBE00 >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
06-28-2018, 09:02 | #926 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Vivo y71 pd1731f done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x2C81D769 MSM_ID: 0x000560E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>read mobile GPT data...Success Eraseing Block frp ADD:0x014A180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
07-02-2018, 09:24 | #928 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Mad 10 Lite FRP Done Thank,s MRT Team Last edited by VC_INDIA; 07-02-2018 at 09:29. Reason: Fix Image Link |
The Following 2 Users Say Thank You to rafi_5217705 For This Useful Post: |
