Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Hardware Repair
Old 12-24-2015, 10:42   #1 (permalink)
Member: 2077582
Thanks Meter: 16
How To Hard UnBricked LG G3 (All Variants) (Fix Qhsusb bulk _ Qualcomm-9008)
After Read This Tutorial You Will Able To Fix These Situations.
NO BOOT , NO RECOVERY , NO DOWNLOAD MODE , NO POWER
1 : Shows "LGE AndroidNet USB port"
"LGE AndroidNet USB Modem"
2 : Only Shows "Qualcomm HS-USB QDLoader 9008"
Now Start Fixing
If You Are On Situation "1" You To Need To Change "LGE AndroidNet USB port" To "Qualcomm 9008"
1- open the phone
2- On MotherBoard Remove The Cover Of "eMMC"
3- short cut the pins in the photo you provided "without the battery" After Connect The "USB Data Cable"
After This Your Phone Shows "Unknown Device" In Device Manager So Install Qualcomn Driver Which Provided Below.
Reassemble Your Phone
And Connect With PC With Out Battary
Now Fixing "Qualcomm HS-USB QDLoader 9008"
Prerequisites:
AQcomm Drivers
BBoardDiag v2.99a
C) Choose correct TOT File For Your model Here
Directory Listing of //Xda/LG G3/Stock/
D) Make sure you have Visual C++
Redistributable Installed
https://drive.google.com/file/d/0BwW...FweER1MUU/view
1) Install Qualcomn Drivers
2) Extract Rar Of BoardDiag v2.99a And Run It
3) Extract Zip Of ToT file Which You Download For Your Phone Make Sure You Download Correct ToT File For Your Phone
4) Now See These Picture
1:Put ToT
2:Set Directory (where ToT File Will Extract)
3:Click On Extract Button
After Extract ToT You Will Get Files Like This
Then
1)Chosse "Chipset" For G3 Choose B2
2)Select Correct COM Port Which Shows in Device Manager i.e, (COM12)
3)Select Source Of file Where ToT file Extraced
4)Tick Into "AP Test" And "EMMC TEST"
5)Click On Start
After Both Test Passed
Choose Restore Option And
Restore These Files One by One In this sequence
Note: Don't Change the Sequence
1)Boot
2)Aboot
3)BackupGpt
4)Boot
5)dbi
6)laf
7)PrimaryGpt
8)Recovery
9)rpm
10)tz
11)sbl1
Finished
After Complete Disconnect Phone And Insert Battary
If Your Phone Boot Up You Have Sucess
Then Boot Into Download Mode And Flash ToT File With LG Flash Tool.
IF Get Sucess Then Click Thanks Button
Take Care Of Yours And Your Phone
Special Thanks To This Man For Pictures.
@WillCracker Form XDA Developers.
The Following 14 Users Say Thank You to faisal21 For This Useful Post:
Old 06-21-2016, 10:36   #2 (permalink)
Member: 1219380
Sonork: 100.1660760
Thanks Meter: 3
g3 d858hkn tot
g3 d858hk tot file not in download list...please give proper link..
The Following User Says Thank You to rajeshbabu For This Useful Post:
Old 06-21-2016, 11:01   #3 (permalink)
Member: 941075
Thanks Meter: 51
This metod works, Thanks a lot faisal21.
The Following User Says Thank You to coyote_kv For This Useful Post:
Old 06-24-2016, 18:03   #4 (permalink)
Member: 2298801
Thanks Meter: 2
Hi, i try with my lg g3 and i have qualcomm 9008 port in device manager but result "device was not found in dload trying flash programmer"
Any solution plz
Envoyé de mon LG-F400K en utilisant Tapatalk
The Following 2 Users Say Thank You to polyctro For This Useful Post:
Old 06-24-2016, 21:28   #5 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
ii h ave d380 same issu can u help me out
The Following User Says Thank You to GSMTURBO For This Useful Post:
Old 07-05-2016, 16:02   #6 (permalink)
uttam's Avatar
Member: 223135
Sonork: 100.1592685
Thanks Meter: 177
100% Working dear.......... Thanks A Lot......
The Following User Says Thank You to uttam For This Useful Post:
Old 07-05-2016, 18:20   #7 (permalink)
Member: 2282504
Thanks Meter: 50
umbrick lg ls770
Hi. I have a lg ls770 and after him VZ8 downgrade to vz7 not turned on. in device manager registers as RELINK HS-USB QDLoader 9008. alguin can help me to relive it? Thank you
The Following User Says Thank You to ltindi32 For This Useful Post:
Old 08-12-2016, 20:06   #8 (permalink)
Member: 728309
AP Chipset W3 W5 (MSM8210) Boot Partition info folder?????
The Following User Says Thank You to TOMASRAM For This Useful Post:
Old 09-08-2016, 11:23   #9 (permalink)
Member: 2622161
Difference
Can you tell me please, if is any difference between your scheme and scheme which can you usually find on the internet? Unfortunatelly, i cant post an url. Thanks
The Following User Says Thank You to Gabzda For This Useful Post:
Old 09-08-2016, 15:36   #10 (permalink)
Member: 1707450
Link problem
Hi, can you reupload file because links are not functional..
The Following User Says Thank You to djokos For This Useful Post:
Old 09-08-2016, 15:49   #11 (permalink)
AgicAga's Avatar
Member: 866455
Sonork: SAMSUNG CPID ONLINE
Thanks Meter: 579
Link problem
https://drive.google.com/file/d/0B4K...V3TGZiT2c/view
The Following 2 Users Say Thank You to AgicAga For This Useful Post:
Old 09-08-2016, 19:03   #12 (permalink)
Member: 2622326
i have been following this guide, without succes, BoardDiag part seems right the screen turns on (LG Life's Good powered by android screen)
Test again AP and EMMC passed
after first try connecting to the PC screen goes off (still recognizes QLoad)
but i get errors while on the LG Flash Tool
the program says the following
Download FAIL!! (8sec)
"PID: NULL
IMEI: NULL
[12:55:30] CrossDL [] to [D855]. SWversion[]
00000064
Error: [12:55:30] CrossDL [] to [D855]. SWversion[]"
I'm currently on a D855P 16GB Variant
the brick happened while browsing images on Google Chrome i was running Android 6.0 with Root via KingoRoot and TWRP 2.7
at first TWRP was accesible but not able to boot any partition (all of them said 0MB)
Tried Flashing a .KDZ file, the Flashtool said Device disconnected every two seconds
don`t know what to do now. any help is very well received
The Following User Says Thank You to CirKraT For This Useful Post:
Old 10-01-2016, 00:19   #13 (permalink)
Member: 2395555
Sonork: 100.1681674
Thanks Meter: 33
Asslam O Alaikom.....
Superb Work....
My LG d855 is Alive...
Thanks Alot....100000000000000% Woking Method
The Following 2 Users Say Thank You to kingaamir1 For This Useful Post:
Old 10-04-2016, 20:44   #14 (permalink)
Member: 660780
Just do all in windows XP
JUST XP
The Following User Says Thank You to comdoost For This Useful Post:
Old 10-12-2016, 20:45   #15 (permalink)
Member: 1942305
Thanks Meter: 4
i need your help.
My Device: LG G3 D855 16GB
The device does not turn on, the only thing that appears is because when I connect the device to a PC, I see a driver installed:
I downloaded the software BoardDiag 2.9
I downloaded the files to the appropriate TOT
I extracted the files by instructors on site.
I opened the program and I followed the guide and it seems to me an error
Download mode is enabled Mode,
I quickly disconnects from the computer and reconnect the computer and then the moment I am unable to do a test and the results are:
AP CHECK START = PASS
EMMC TEST START
FAILED TO OPEN PARTITION FROM EMMC
TEST ABORTED !!
I tried a lot of tutorials but I can not, it always seems the device is in Download Mode
What can I do more?
Please your help,
The Following User Says Thank You to kur10 For This Useful Post:
Page generated in 0.25497 seconds with 8 queries
