12-18-2008, 15:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | 2610b 7.04a dct4++ not unlock see log Genie Universal Serial Number: ****** Genie Universal Hardware version: 01.06 Genie Universal Device Build: 00.00.00.146 Searching DCT4 Loaders... ->DCT4 Loaders Dir('Flash')......Found. -->113 file(s) found. -->Loaders version: v. 7.16.22.27399 for ---------------------------------------------- Reading Phone Info....Error! Restarting Phone...Done. Phone Version: V 07.04a 26-08-08 RH-86 (c) Nokia. Phone IMEI sent to network: 011664/00/152264 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! please update genie-universal thank you |
12-18-2008, 16:27 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Hi, Can you try on flashing this phone with phoenix first? Just to check if the cable working or not. It might be cable resistor on BSI(3.3k) and 68k(BSI to GND) miss use. looks more that the phone can't be booting up and not the version problem. Best Regards Alan Tan |
12-18-2008, 16:32 | #3 (permalink) | |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
You use easy flash cable and GENIE CLIP NOT SUPPORT THIS TYPE OD CABLE ONLY FBUS WORK !! !! !! | |
12-18-2008, 17:35 | #6 (permalink) | |
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
12-18-2008, 21:37 | #8 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | fbus cable no work either, new mcu, soon more nokia dct4+ will be like this, please update, tnx. ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 07.04a 26-08-08 RH-86 (c) Nokia. Phone IMEI sent to network: 011664/00/152264 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! |
12-19-2008, 01:32 | #9 (permalink) | |
Member: 7220 Status: Offline Thanks Meter: 1,592 | Quote:
Hi, As we can see that the phones doesn't boot well. Mainly this is the cause of WRONG Resistor used on BSI. (3.3k resistor required) and BSI to GND (68k resistor required). Check your cable now. Best Regards Alan Tan | |
12-19-2008, 18:01 | #10 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | cable ok see log, its new mcu version, please update, tnx v6.80 works but 7.04a not, both 2610b nokia. Reading Genie Universal device...Done. Genie Universal Serial Number: ****** Genie Universal Hardware version: 01.06 Genie Universal Device Build: 00.00.00.146 Searching DCT4 Loaders... ->DCT4 Loaders Dir('Flash')......Found. -->113 file(s) found. -->Loaders version: v. 7.16.22.27399 for ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 07.04a 26-08-08 RH-86 (c) Nokia. Phone IMEI sent to network: 011664/00/152264 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 06.80 18-10-07 RH-87 (c) Nokia. Phone IMEI sent to network: 011673/00/195939 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Sending bootloader: u3_2nd.fia Asic: 0x3040 Dev0: 0x00012C7E Base: 0x01000000, Sector Size: 0x11 Sending Algorithm: u3_amd.fia UEM Rev: 0x53 Sending CBUS Loader...Done. Loader Running. Genie Plus for DCT4 Version 00.01.02.55 IMEI in UEM: 01167300195939 Searching free space...Done. Boot rom registter...Done. Searching RSA key...Done. Building application...Done. Patching bootrom register...Done. Sending RSA key...Done. Sending emulator file...Done. Restarting Phone...Done. Uploading SP Locks...Done. Phone Version: V 06.80 18-10-07 RH-87 (c) Nokia. Phone IMEI: 0116730019593900 SimLock Server: SIMLOCK SERVER Configuration Key: 0010100000000000 MCC+MNC: 00101 ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 07.04a 26-08-08 RH-86 (c) Nokia. Phone IMEI sent to network: 011664/00/152264 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! |
12-21-2008, 05:08 | #15 (permalink) |
Member: 7220 Status: Offline Thanks Meter: 1,592 | Can you try on flashing with latest phoenix? : http://forum.gsmhosting.com/vbb/showthread.php?t=645807 Place flashing logs please. Also do not forget about VPP as well. Best Regards Alan Tan |
2610b 7.04a Unlock Problem! | Shahzad. | Universalbox | 11 | 09-17-2009 09:28 |
2610b 7.04a not supported till now with UB...why??? | tan2x81 | Universalbox | 1 | 09-14-2009 15:10 |
2610b to at%t is not supported see log | juceca21 | Genie Universal | 0 | 08-19-2009 17:03 |
2610b 7.04a unlock done by UB.... | gabz2008 | Universalbox | 42 | 06-24-2009 06:42 |
