11-12-2012, 21:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Jamaica
Member: 383592 Status: Offline Thanks Meter: 88 | C2 no loader for log reading. Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V 10.50 07-01-11 RM-722 (c) Nokia Read imei...Done. IMEI number: xxxxxxxxxxxxxxx Read Permanent memory: section 120, key 0...Done. Data: 80000000000000003026100076705775... Read Permanent memory: section 120, key 1...Done. Data: 61156836658670CF7B51FC1977D51CC7... Read Permanent memory: section 120, key 2...Done. Data: B0A91536AD81F2C1028BDD22CBF86EF2... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. ---------------------------------------------------------------------- Please disconnect the USB cable... Now power off the phone... Reconnect the USB cable... Now quickly press the Power On button... ---------------------------------------------------------------------- Init connection...Done. Requesting ROM info...Done. RAP3 ID: 1A70020334155940FC53B8AC65C127382F2B56E5 RootKey Hash: 7B045400E1752022F9EB80B0DEA9C65D RAP3 CPU ID: 020C192102044100 PubRom CRC: 67E82268 PrvRom CRC: F29CEA60 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Users\Carl vs Georgia\Documents\nokia\loaders\special\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapuv21_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rapuv11_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. No suitable loader was found. |
