08-12-2008, 09:51 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 232075 Status: Offline Thanks Meter: 1 | 5310 Music Xpress doesn't work. I bought 10 new yessim card and there doesn't work. Nokia 5310 Express music I did for : 00101 Patch Coount 1-30 doesn't work Later I did: Normal Mode 27203 (Phones from Meteor Ireland) Patch count 1-30 doesn't work as well Boost mode- phone don't see a simcard. Amoi WS-P1 phone I did: Boost Mode 00101 Patch Count: 30 work OK. Everything I try a both version 2.4.4 2.3 Please let me know how to do it. |
08-12-2008, 14:57 | #2 (permalink) |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | Nokia express music setting: Normal mode 00101 patch count : 1 you can use firmware 2.3 or 2.4 beta 4 , be sure your simcard have network before insert it(put your sim card alone in unlocked phone and serach network manualy and register in it than test with it with yessim in your phone) |
08-12-2008, 22:04 | #3 (permalink) |
Member: 232075 Status: Offline Thanks Meter: 1 | hi I have 7 cards (vodafon IRL x 3, O2 IRL x 2, Idea PL, 3 IRL) and for 2 Vodafone doesn't work - 1 Vodafone is OK, 1 O2 doesn't work and 1 is OK, Idea is OK, 3 IRL doesn't work. setting: Normal Mode 00101 patch count: 1 What I can to do?? |
09-04-2008, 10:33 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | i had the same probem with 5310 but now solved with this Frimware version : Firmware V :2.4 Beta4 (c) MCC-MNC : 001-01 Mode : Normal Mode. IMSI Patch Count : 1 |
09-05-2008, 08:15 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | for 6120c use same setings and worked fine ! Frimware version : Firmware V :2.4 Beta4 (c) MCC-MNC : 001-01 Mode : Normal Mode. IMSI Patch Count : 1 |
09-17-2008, 23:37 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | 5310 and 5610 really working perfectly with that preset, 5 pieces tested on all 5 brazilian ops with no problem. and yessim does not loose network after some hours/days. |
10-02-2008, 11:33 | #10 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | set this for mony pcs 5310 worked fine Frimware version : Firmware V :2.4 Beta4 (c) MCC-MNC : 001-01 Mode : Normal Mode. IMSI Patch Count : 1 |
The Following User Says Thank You to delchoni For This Useful Post: |
10-24-2008, 16:17 | #15 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | Read what´s written in it. If have nothing written, than you have to know how to distinguish the sim cards of your country or call the carrier. |
Want Dead Nokia Music Xpress 5310. | kamesh_3117 | Sell ur Old and Used Stuff | 1 | 12-18-2009 05:01 |
5610 rm-242 Music Xpress doesn't work. | rafauz | YESSIM | 1 | 11-14-2008 12:33 |
5310 china Xpress Music---what cable? | topnoyze | PadFinder box | 1 | 08-20-2008 10:05 |
