07-10-2008, 17:51 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: www.unlockbylogs.com Age: 38
Member: 192997 Status: Offline Sonork: 100.1574661 Thanks Meter: 7 | Blackberry 8800...initialization failed have got a Blackberry 8800...says initialization failed i tried abt 10 yessims for now ...any advise? the phone has no chances left for code..i dont knw if that makes any difference? regards, XtremeGG |
07-10-2008, 18:28 | #2 (permalink) |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | hi, all most blackberry are supported, did you set MCC-MNC to phone operator ? sincerly we don't try in blackberry with counter code over but you can make small test, if you can run your phone with original card and run without problem than yessim must work aswell |
07-10-2008, 22:44 | #3 (permalink) |
Member: 192997 Status: Offline Sonork: 100.1574661 Thanks Meter: 7 | hi...thx for your response...it's on Orange UK...i tried the orange sim on its own..and worked well..but with YesSim..it didn work i haven't got the reader unfortunately frm my reseller...so havent tried settin the MCC-MNC ...will try that wen i get a reader handy XtremeGG |
07-11-2008, 04:20 | #4 (permalink) | |
Freak Poster Join Date: Jun 2008
Member: 799206 Status: Offline Sonork: 100.67372 Thanks Meter: 276 | Quote:
Pls give us feed back when you have successfully update your card | |
07-12-2008, 05:07 | #7 (permalink) |
Member: 799206 Status: Offline Sonork: 100.67372 Thanks Meter: 276 | Please Report when phone is ok. Report problem is good when u have successfull result would be great if you can post as well. Black berry settings are : * Boost Mode * MCCMNC from phone rovider * Pacth count can start with 30 but will probably need be set to 1. Once operation if fine pls turn off radio and go back to normal mode. If operation is ok you will have Stable Network. Kindly report Positive and Negative. We are working on new updates to make YESSIM all perfect but we need feed back |
07-12-2008, 23:28 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | not working in my country with 32k simcard, just workin with 64k 128k , not workin also with 32k cards from network :51001,51010, 51021 but with 51011 workin well even we used 32k cards. Regards |
07-14-2008, 15:45 | #11 (permalink) |
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | No must work just verify if phone operator is Orange UK or Orange Fr or Orange Sp, try all and post result also be sure Mode : Bosst mode and patch count 30 Regards, |
07-14-2008, 17:05 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | i will try again but in messages i have one welcoming to Orange UK, so thats why i know it is from there, anyway, will try and post results, regards1 |
07-15-2008, 02:08 | #13 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | ask from customer, where is from, otherwise try to both mcc setting Orange UK or Orange Fr or Orange Sp Mostly bb from Orange UK and FR thanks |
08-05-2008, 05:03 | #14 (permalink) |
No Life Poster Join Date: May 2004 Location: Peru Age: 54
Member: 67240 Status: Offline Thanks Meter: 45 | I have one Yessim working fine with one BB AT&T, I use the same setting for 2 sims I have to sell but allways get same message at phone: initialization failed. I am using the same setting, why that error???? |
Blackberry unlocked.... But, Initialization failed. SOLUTION HERE !!! | -luigi- | FuriousGold | 17 | 01-24-2010 22:20 |
blackberry 8320 initialized failed. | nnamdi maduike | BlackBerry (RIM) | 0 | 12-13-2009 21:41 |
Blackberry Initialization failed Solution | gujjar_brothers | BlackBerry (RIM) | 5 | 02-08-2009 12:37 |
BB Initialization Failed (8100) | nellyfang | BlackBerry (RIM) | 12 | 01-25-2009 03:04 |
BB 7230 initialization failed | 22gsm | FuriousGold | 0 | 06-23-2007 00:08 |
