07-27-2008, 02:30 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008
Member: 764475 Status: Offline Sonork: 100.1574238 Thanks Meter: 189 | iphone 3G Reading SN CLIP..OK. Yessim SN : AC0000C1 Frimware version : Yessim Firmware V:2.4 Beta (c) MCC-MNC : 001-01 Mode : Boost Mode. IMSI Patch Count : 30 work tested by me |
07-28-2008, 05:21 | #4 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 799206 Status: Offline Sonork: 100.67372 Thanks Meter: 276 | Yes will be 100% ok. But will depends which hardware version you have. If V1 you might have to make small modification on hard ware. Iam uplaoding now all tutorials and videos |
07-28-2008, 22:39 | #5 (permalink) |
Junior Member Join Date: Jul 2008
Member: 823643 Status: Offline Sonork: iphonero Thanks Meter: 0 | Hadware modification for iphone3g V1 and Movistar (Spain) carrier What do you mean for "you will have to modify hardware"? Which hardware? And, how can I know whether my iphone 3g is V1 or not? Thank you in advance! |
07-29-2008, 02:21 | #6 (permalink) |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | kindly follow instruction in this url : http://www.yessim.com/hard_mod.php |
07-29-2008, 19:24 | #7 (permalink) |
Member: 823643 Status: Offline Sonork: iphonero Thanks Meter: 0 | Ok! so V1 refers to the yessim sim, not to the iphone. For a moment I thought I had to modify the hardware of the iphone I have recently bought a yessim for my iphone 3g. It was last saturday (july 26). Am I concerned about this hardware modification? I bought it once yessim had already announced the sim could unlock iphone 3G. I can't believe I will need to make this hardware modification on this BRAND NEW sim. Probably yessim hasn't even shipped it yet! What if this modification causes the sim to stop working? the images don't clarify the precise positions for the holes. Moreover the text specify that the new holes must have the same disposition as the 3 hole you already have on the Upper copper pad. Surprisingly, the image a different disposition. I don't feel comfortable modifying a brand new component I have just bought and wandering if it didn't work from the very beginning or is the case that I broke it when making those ugly holes. |
07-29-2008, 19:39 | #8 (permalink) |
Member: 823643 Status: Offline Sonork: iphonero Thanks Meter: 0 | One additional comment: Yessim support clearly refers to v1, but I'm not sure if yessim.com indicated the "v2" for sims bought last saturday (as is the case now). Moreover, the tutorial refers to both v1 and v2. Some help from you guys? |
07-29-2008, 21:17 | #9 (permalink) |
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | tutoriel refer to v1 , for know what hardware version you can chek with simple multimetre continuity between up pad and down pad, or just with your eyes if pad have no hole it's V1, if exist no need done any modification if not you must make it, is so easy to make just follow guide, but if you bought last saturday i think you have new hardware i will check tomorro and told you, this modification will not cause yessim not working if you make it like in tutoriel, plz kindly contact if you get any problem we will resolve |
07-29-2008, 23:01 | #10 (permalink) | |
Junior Member Join Date: Jul 2008 Location: Rotterdam, NL
Member: 825542 Status: Offline Thanks Meter: 0 | On the YESSIM website it says: Quote:
In other words: It's not possible to insert the YESSIM card directly into your Iphone 3g, you have to modify the card first? | |
07-30-2008, 01:13 | #11 (permalink) | |
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | Quote:
if not have cable just contact your resseler for set your yessim for iphone | |
The Following User Says Thank You to PADERF For This Useful Post: |
07-30-2008, 11:04 | #12 (permalink) |
Member: 825542 Status: Offline Thanks Meter: 0 | thanks for the explanation! That was the only thing that wasn't clear to me. I'm gonna order one right away and let you know if it worked with my AT&T locked US iphone 3g. |
07-31-2008, 01:04 | #13 (permalink) | |
Member: 823643 Status: Offline Sonork: iphonero Thanks Meter: 0 | Quote:
08-01-2008, 08:34 | #14 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Porto, Portugal Age: 46
Member: 3783 Status: Offline Thanks Meter: 128 | U guys need to turn off the 3g network in order to work properly Also my settings for iphone Normal mode Imsi patch=1 also set the network for optimus portugal 26803 all working fine without 3g |
08-01-2008, 11:44 | #15 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Japan Age: 42
Member: 150697 Status: Offline Thanks Meter: 7 | best settings, with furiousim/yessim: pc 1 boost mccmnc (set to same as locked phone: ie: rogers canada iphone, set mccmnc to 30272) firmware 2.4 v1 or v2 OK... v1 DOES NOT require modification for iphone 3g. |
Worldwide: BB5 dongle for UFS + Iphone 3G Yessim + Iphone 3G Universal sim! | GsmServer sales | Main Sales Section | 0 | 11-17-2008 18:44 |
Charger Cable for iPhone / iPhone 3G / iPhone 3G Bluetooth | IPMART | ipmart WebShop | 0 | 09-24-2008 11:30 |
iPhone 3G Accessories by iLLuminatik ..... iPhone 3G.. iPhone 3G.. iPhone 3G.. | miliky | Main Sales Section | 0 | 08-15-2008 10:35 |
