05-24-2009, 07:36 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | Cpf team c1000+ read ok but write error need your help Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download finished. CPU Type: 6600E0F4 NAND: Flash ID: 00AD0076 Flash Size: 0X04200000 (66M) Flash Type: [Hyundai] HY27XS08121A/M Flash read finished. Used time: 355.0s Data has been saved in G:\CPF\FLASH FILE\spd\C1000+\c1000+1.bin,file size is 66M. Is searching the password, please wait... [Privacy lock] 1234 Found finished. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Please send the backup flash file to www.phones-china.com or [email protected], we can add forum coins to you.thanks in advance. The files is full, can be write the entire flash. It is unable flash which identify, can not support the operation temporarily, please relate with the factory. Error, try again. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. It is unable flash which identify, can not support the operation temporarily, please relate with the factory. Error, try again. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. It is unable flash which identify, can not support the operation temporarily, please relate with the factory. Error, try again. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. It is unable flash which identify, can not support the operation temporarily, please relate with the factory. Error, try again. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download success. Flash erasing... 91 Error, try again. >>If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. phone work good but hung with sim also i had same problem on f200+ with same cpu dead after flash .. |
05-24-2009, 11:13 | #4 (permalink) |
No Life Poster Join Date: May 2006 Age: 38
Member: 283725 Status: Offline Sonork: 100.1584053 Thanks Meter: 1,927 | |
05-25-2009, 06:45 | #6 (permalink) | |
Member: 281857 Status: Offline Thanks Meter: 214 | Quote:
If does not have the COM to choose, please the reset cable pinouts, or unload phone's battery and load phone's battery again. If read/write 6600R,select 'Boot C recommended(6600R)'. If read/write 6800,select 'Boot E recommended(6800)'. Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download finished. CPU Type: 6600E0F4 NAND: Flash ID: 00AD0076 Flash Size: 0X04200000 (66M) Flash Type: [Hyundai] HY27XS08121A/M IMEI :332190700972670 Read lock finished,no found Lock. Used time: 32.2s If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. The files is full, can be write the entire flash. Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download success. Flash write finished Used time: 6.2s IMEI is writen into phone. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Waiting for phone's response,press the Power on the phone.. User Terminate. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Waiting for phone's response,press the Power on the phone.. User Terminate. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download success. Flash erasing... 91 Error, try again. >>If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. | |
05-25-2009, 08:27 | #7 (permalink) |
Member: 281857 Status: Offline Thanks Meter: 214 | i think problem in flash file ... please check it for me i upload it here http://rapidshare.com/files/236955471/C1000_.rar.html |
05-26-2009, 13:43 | #12 (permalink) | |
No Life Poster Join Date: Jan 2005
Member: 104066 Status: Offline Thanks Meter: 62 | Quote:
CPF BOX II don't support some new nand flash chip now more than 6 mounth don't lose u time Last edited by nzeiga; 05-26-2009 at 13:49. | |
06-03-2009, 16:36 | #14 (permalink) |
Member: 281857 Status: Offline Thanks Meter: 214 | is this cpu also not supported Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download finished. CPU Type: 6600E0F4 NAND: Flash ID: 00AD0076 Flash Size: 0X04200000 (66M) Flash Type: [Hyundai] HY27XS08121A/M IMEI :358718010273121 Read lock finished,no found Lock. Used time: 31.1s If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Boot: Boot download finished. If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. Wait for connect... Waiting for phone's response,press the Power on the phone... CPU version: Spreadtrum Boot Block version 2.0 Boot download success. Flash erasing... 91 Error, try again. >>If prepares once more read-write phone, please unload the power supply clip or phone's battery, load again. |
06-04-2009, 04:58 | #15 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Chinese phones flasher Age: 41
Member: 602191 Status: Offline Sonork: 100.1577310 Thanks Meter: 3,112 | Quote:
hello sir,this is a NAND flash.and CPF do it have some bug now.but we will fix it. | |
The Following 2 Users Say Thank You to phones-china For This Useful Post: |
Need your help | murtaza_k | Nokia Base Band 5 ( BB-5 ) | 3 | 03-29-2010 20:09 |
2626 erase ok but writing error | bhardwajparesh | Nokia Hardware & Hardware Repair | 3 | 11-24-2009 15:59 |
mini ıphone flash read ok but backup write error | ****Nihat**** | SpiderMan | 8 | 11-23-2009 15:49 |
HELP!Nec n22i read flash ok but write error!WHY? | OCTOPUS d.o.o. | Redbox | 0 | 09-08-2004 15:50 |
