Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > CPF-box Products > CPF-BOX Ⅱ
Old 11-14-2010, 09:10   #1 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Sonork: / Skype id: Parashsky
Thanks Meter: 1,755
Tell me any CPF-BOX problem
Tell me any CPF-BOX problem or help, i try to give solution.just post ur problem and w8.
Me all time here...
Br,
parash
Old 11-14-2010, 19:08   #2 (permalink)
Member: 1310144
Thanks Meter: 15
My CPF-BOX the voltage is excessively low Can't find pin out.
Is Voltage testing...
When circuit 1(6) set VCC, the voltage is excessively low, the value is 1.69v
When circuit 2(8) set VCC, the voltage is excessively low, the value is 1.09v
When circuit 3(10) set VCC, the voltage is excessively low, the value is 1.69v
When circuit 4(12) set VCC, the voltage is excessively low, the value is 1.16v
When circuit 5(14) set VCC, the voltage is excessively low, the value is 1.69v
When circuit 6(16) set VCC, the voltage is excessively low, the value is 1.17v
When circuit 7(18) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 8(20) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 9(21) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 10(4) set VCC, the voltage is excessively low, the value is 1.11v
When circuit 11(5) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 12(9) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 13(11) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 14(13) set VCC, the voltage is excessively low, the value is 1.09v
When circuit 15(15) set VCC, the voltage is excessively low, the value is 1.69v
When circuit 16(17) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 17(19) set VCC, the voltage is excessively low, the value is 1.74v
When circuit 18(22) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 19(3) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 20(7) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 21(2) set VCC, the voltage is excessively low, the value is 1.70v
When circuit 22(1) set VCC, the voltage is excessively low, the value is 1.10v
When circuit 23(24) set VCC, the voltage is excessively low, the value is 1.69v
When circuit 24(23) set VCC, the voltage is excessively low, the value is 1.09v
* The voltage test finished.
Please give me the solution.
Thanks.
Old 11-15-2010, 03:28   #3 (permalink)
nishue's Avatar
Member: 576633
Thanks Meter: 392
wen i connect my box its allwes display this !
Last update of program file: 11/11/2010 Last update of configuration file: 2010-11-11
Connection success, but no found Port 232BM,retry.
Version: V3.1 Connected Port:COM7 Normal Port:COM1 Fast Port:COM7(2303)
* Connection success,welcome cpf-box 2.
but software work fine, why this err ?
(but no found Port 232BM,retry.)
Old 11-15-2010, 04:55   #4 (permalink)
Member: 715924
Sonork: 100.1662616
Thanks Meter: 83
usb detection fail
please help me my box can not detect charge pin or usb. thats reason i can not flash spd cpu phone.............thanks
Old 11-15-2010, 05:09   #5 (permalink)
Crazy Poster
Member: 1025467
Sonork: ajay
Thanks Meter: 19
how to write 2 imei with cpf.........?
Old 11-15-2010, 13:15   #6 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
Thanks.
Check adopter and usb cabel
The Following User Says Thank You to FasGsm For This Useful Post:
Old 11-15-2010, 13:16   #7 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
install ft232 driver.
Old 11-15-2010, 13:17   #8 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
already posted
http://forum.gsmhosting.com/vbb/6383414-post6.html
Old 11-15-2010, 21:29   #9 (permalink)
Member: 1310144
Thanks Meter: 15
same problem after change adapter and usb cabe.
Old 11-16-2010, 06:07   #10 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
do system recovery with out attaching any cable with ur box
http://forum.gsmhosting.com/vbb/5847705-post1.html
try on another pc if still same then check ur box hardware.
Old 11-17-2010, 14:52   #11 (permalink)
Crazy Poster
Member: 817550
Thanks Meter: 3
Thanks.
hi. my box vcc low voltage. Please give me the solution.
Old 11-17-2010, 15:03   #12 (permalink)
Crazy Poster
Member: 817550
Thanks Meter: 3
problem
Version: V3.1 Connected Port:COM7 Normal Port:Fast Port:COM7(2303)
normal port : ???
vcc voltage low
please repair guide
Old 11-17-2010, 15:51   #13 (permalink)
Member: 608376
Thanks Meter: 18
my box rx tx not taking
Old 11-17-2010, 16:31   #14 (permalink)
xseven's Avatar
Member: 649553
Thanks Meter: 45
how to use detect usb for spd??
Old 11-28-2010, 22:24   #15 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Thanks Meter: 1,755
chek ur cable rx,tx line.
Br,
Parash
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.25536 seconds with 9 queries
