Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
Old 05-22-2009, 18:16   #1 (permalink)
Member: 209047
Thanks Meter: 7
Exclamation Cant Unlock/Unfreeze Sgh t919 need help!!
here is log from srs
Booting phone in testmode
1:11:35 PM- BOOT DONE.
1:11:35 PM - GETTING DATA FROM PHONE
1:11:35 PM - MSL SERIAL:R4VQB74033
1:11:36 PM - FIRMWARE: UVHI5 (September 2008)
1:11:36 PM - UNIQUEKEY:80240000514269
1:11:36 PM - IMEI:xxxxxxxxxxxxxx
1:11:37 PM - PHONE SEED:6DCF461EDE107B25A96A3F8A6B48F707
1:11:37 PM - SENDING DATA TO SERVER.. PLEASE WAIT..
1:11:49 PM - MSL2 Bypass Code: 646107..
1:11:57 PM - AKSEED CALCULATION: FAILED!
1:11:57 PM - Try to reset your phone with *2767*3855#
1:11:57 PM - and then try Direct Unlock again.
Failed.. cannot bypass MSL
I have reset 3 times same error...
how do u unlock/unfreeze this phone on srs?
Old 05-22-2009, 20:23   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
get 3G logger from
http://www.unlocksamsungonline.nl/in...EN&page=logger
and send me the ASK file, i give you the RPL for unlocking the phone
we're working on a second method for phones that failed on akseed
The Following User Says Thank You to ssa For This Useful Post:
Old 05-22-2009, 23:57   #3 (permalink)
Member: 209047
Thanks Meter: 7
Booting Phone
- Boot done.
- Getting Data from phone
- MSL Serial: R4VQB74033
- Firmware: T919UVHI5
- Phone Imei: xxxxxxxxxxxxxxx
- RPL file detected, Starting Unlock
- Sending RPL data to phone
- Switch to modemport
- Reset Phonecode and Simlock
- Restart Phone
- Unlock and Unfreeze phone done.
Bless
Old 06-09-2009, 23:11   #4 (permalink)
Member: 1049445
I got the same problem when unlocking A867... I downloaded the logger and here's what i got:
Booting Phone
- Boot done.
- MSL Serial: xxxxxxxxxx
- Firmware: xxxxxxxxxx
- RPL file NOT detected, creating ASK file
- Getting platform data...... and it just hangs there.. does it normally take that long??
or is something wrong??
EDIT:.. never mind.. i had the wrong ports up...
heres the ASK file...
http://www.filefactory.com/file/ag53...3020787994_ask
Old 06-11-2009, 01:18   #5 (permalink)
Member: 850827
Thanks Meter: 2
can you give me qualcomm drivers for this phone it dosent instal the qxdm drivers and the computer asks drivers for qualcomm cdma technologies msm
Old 06-11-2009, 05:22   #6 (permalink)
Salami1_1's Avatar
Member: 3941
Thanks Meter: 636
@ Skeptic
You have to buy a login first. And then send the .ask file to your reseller with the .ask file and the log of your unlock attempt using the normal software.
Likely you dont need the logger as you had wrong port setup the direct unlock will work now also..
@Xaliax Qualcomm drivers are included in the SRS installer they are installed to:
c:\program files\Samsung Remote Client\drivers\qxdm
Best regards,
Old 06-11-2009, 08:24   #7 (permalink)
Member: 1049445
Okay... here's the full story...
I do have a login.. with 3 credits..
I tried direct unlock.. with the correct ports ( in my case 6 for diag and 5 for modem ) and got the AKSEED Calculation error.
I then downloaded logger and ran it.. with the wrong port setup ( it was still on default 3 and 3.. ) and it was hanging as stated earlier..
I then changed the ports, and was able to save the ASK file..
When u say send the ASK file to the reseller... are u referring to UnlockSamsungOnline.com?? because I'm kind of confused.
so just to be clear.. Direct unlock with the correct ports does NOT work...
I do get the AKSEED Calculation error. Tried resetting phone using code to no avail.
Any help is greatly appreciated.. thanks
Old 06-11-2009, 10:40   #8 (permalink)
Salami1_1's Avatar
Member: 3941
Thanks Meter: 636
Hi,
Ah yeah the akseed calculation error is known to us we are working on that problem.
In that case please send the .ask file to the website where you bought the login (unlocksamsungonline.com / unlocksamsungonline.nl / allgsmserver / mobile2mobile etc) + your SRS username and the story you just typed here then it will solved for you.
Best regards,
(p.s. check if your .ask file is exactly 24kb if not then something went wrong creating it)
Old 06-11-2009, 11:44   #9 (permalink)
Member: 850827
Thanks Meter: 2
Ive used the drivers on the qxdm folder and it dosent accept it
Old 06-11-2009, 12:00   #10 (permalink)
Salami1_1's Avatar
Member: 3941
Thanks Meter: 636
the qxdm drivers work for every Samsung qualcomm model as long as the phone is in qualcomm mode.
So make sure phone is in qualcomm mode then when you connect the phone Windows should pop-up with new hardware found and point the the QXDM drivers.
The phone has to say 'qualcomm mode configures. pls reconnect the cable'. Also connect the USB cable in a USB port at the BACK of your computer. We have seen on several occasions this actually makes a difference probably because low power output on front usb ports.
Some other points:
- Make sure you are logged in on Windows with administrator rights to install the drivers
- Check your Device manager perhaps you have some other drivers installed which conflict
- If you have ANY 3G modem software / drivers installed uninstall them. They 100% conflict!
Old 06-11-2009, 16:13   #11 (permalink)
Member: 850827
Thanks Meter: 2
I dont have any drivers installed. Phone is in qualcomm mode and it still dosent take drivers. Nither vendor or hardware id apears for that phone on the drivers.
Old 06-12-2009, 00:57   #12 (permalink)
Member: 850827
Thanks Meter: 2
help. I think ive lost my money then
Old 06-12-2009, 07:48   #13 (permalink)
Salami1_1's Avatar
Member: 3941
Thanks Meter: 636
Man stop whining that you lost your money, we are still helping you aren't we.
Try these drivers: http://www.unlocksamsungonline.com/f...rs_07(new).zip
If these don't work either contact me privately and we will make appointment for remote desktop help so we can have a look. We have unlocked this model on our server hundreds of times so I'm pretty sure you're just doing something wrong or there is something on your computer that is conflicting.
Best regards,
Old 06-22-2009, 13:58   #14 (permalink)
Member: 1058694
Links to download qxdm drivers are not working
All already try the links on your site and they are not working. Please, send me a good link. Thanks
Old 06-23-2009, 05:24   #15 (permalink)
Salami1_1's Avatar
Member: 3941
Thanks Meter: 636
Go to:
http://www.unlocksamsungonline.com/samsungdownloads.php and download the files you need or copy the link in your browser.
Links on the site itself work fine.
How to unlock/unfreeze sgh a877 ? VODAFONES UST Pro II 7 08-06-2011 00:15
How to unlock/unfreeze sgh a877 ? VODAFONES UST Pro II 1 07-14-2010 05:59
How to unlock samsung sgh-t919 behold rajan nishchal Easy-Unlocker 3 02-17-2009 20:07
Cant unlock one MYC-2 Need help dominik Phone Unlocking Codes & Maps 2 03-23-2004 17:05
Page generated in 0.24962 seconds with 9 queries
