05-22-2009, 18:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 209047 Status: Offline Thanks Meter: 7 | Cant Unlock/Unfreeze Sgh t919 need help!! Booting phone in testmode 1:11:35 PM- BOOT DONE. 1:11:35 PM - GETTING DATA FROM PHONE 1:11:35 PM - MSL SERIAL:R4VQB74033 1:11:36 PM - FIRMWARE: UVHI5 (September 2008) 1:11:36 PM - UNIQUEKEY:80240000514269 1:11:36 PM - IMEI:xxxxxxxxxxxxxx 1:11:37 PM - PHONE SEED:6DCF461EDE107B25A96A3F8A6B48F707 1:11:37 PM - SENDING DATA TO SERVER.. PLEASE WAIT.. 1:11:49 PM - MSL2 Bypass Code: 646107.. 1:11:57 PM - AKSEED CALCULATION: FAILED! 1:11:57 PM - Try to reset your phone with *2767*3855# 1:11:57 PM - and then try Direct Unlock again. Failed.. cannot bypass MSL I have reset 3 times same error... how do u unlock/unfreeze this phone on srs? |
05-22-2009, 20:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | get 3G logger from http://www.unlocksamsungonline.nl/in...EN&page=logger and send me the ASK file, i give you the RPL for unlocking the phone we're working on a second method for phones that failed on akseed |
The Following User Says Thank You to ssa For This Useful Post: |
05-22-2009, 23:57 | #3 (permalink) |
Member: 209047 Status: Offline Thanks Meter: 7 | Booting Phone - Boot done. - Getting Data from phone - MSL Serial: R4VQB74033 - Firmware: T919UVHI5 - Phone Imei: xxxxxxxxxxxxxxx - RPL file detected, Starting Unlock - Sending RPL data to phone - Switch to modemport - Reset Phonecode and Simlock - Restart Phone - Unlock and Unfreeze phone done. Bless |
06-09-2009, 23:11 | #4 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1049445 Status: Offline Thanks Meter: 0 | I got the same problem when unlocking A867... I downloaded the logger and here's what i got: Booting Phone - Boot done. - Getting Data from phone - MSL Serial: xxxxxxxxxx - Firmware: xxxxxxxxxx - Phone Imei: xxxxxxxxxxxxxxx - RPL file NOT detected, creating ASK file - Getting platform data...... and it just hangs there.. does it normally take that long?? or is something wrong?? EDIT:.. never mind.. i had the wrong ports up... heres the ASK file... http://www.filefactory.com/file/ag53...3020787994_ask Last edited by sk3ptic; 06-09-2009 at 23:18. |
06-11-2009, 05:22 | #6 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 3941 Status: Offline Thanks Meter: 636 | @ Skeptic You have to buy a login first. And then send the .ask file to your reseller with the .ask file and the log of your unlock attempt using the normal software. Likely you dont need the logger as you had wrong port setup the direct unlock will work now also.. @Xaliax Qualcomm drivers are included in the SRS installer they are installed to: c:\program files\Samsung Remote Client\drivers\qxdm Best regards, |
06-11-2009, 08:24 | #7 (permalink) |
Member: 1049445 Status: Offline Thanks Meter: 0 | Okay... here's the full story... I do have a login.. with 3 credits.. I tried direct unlock.. with the correct ports ( in my case 6 for diag and 5 for modem ) and got the AKSEED Calculation error. I then downloaded logger and ran it.. with the wrong port setup ( it was still on default 3 and 3.. ) and it was hanging as stated earlier.. I then changed the ports, and was able to save the ASK file.. When u say send the ASK file to the reseller... are u referring to UnlockSamsungOnline.com?? because I'm kind of confused. so just to be clear.. Direct unlock with the correct ports does NOT work... I do get the AKSEED Calculation error. Tried resetting phone using code to no avail. Any help is greatly appreciated.. thanks |
06-11-2009, 10:40 | #8 (permalink) |
Member: 3941 Status: Offline Thanks Meter: 636 | Hi, Ah yeah the akseed calculation error is known to us we are working on that problem. In that case please send the .ask file to the website where you bought the login (unlocksamsungonline.com / unlocksamsungonline.nl / allgsmserver / mobile2mobile etc) + your SRS username and the story you just typed here then it will solved for you. Best regards, (p.s. check if your .ask file is exactly 24kb if not then something went wrong creating it) |
06-11-2009, 12:00 | #10 (permalink) |
Member: 3941 Status: Offline Thanks Meter: 636 | the qxdm drivers work for every Samsung qualcomm model as long as the phone is in qualcomm mode. So make sure phone is in qualcomm mode then when you connect the phone Windows should pop-up with new hardware found and point the the QXDM drivers. The phone has to say 'qualcomm mode configures. pls reconnect the cable'. Also connect the USB cable in a USB port at the BACK of your computer. We have seen on several occasions this actually makes a difference probably because low power output on front usb ports. Some other points: - Make sure you are logged in on Windows with administrator rights to install the drivers - Check your Device manager perhaps you have some other drivers installed which conflict - If you have ANY 3G modem software / drivers installed uninstall them. They 100% conflict! |
06-12-2009, 07:48 | #13 (permalink) |
Member: 3941 Status: Offline Thanks Meter: 636 | Man stop whining that you lost your money, we are still helping you aren't we. Try these drivers: http://www.unlocksamsungonline.com/f...rs_07(new).zip If these don't work either contact me privately and we will make appointment for remote desktop help so we can have a look. We have unlocked this model on our server hundreds of times so I'm pretty sure you're just doing something wrong or there is something on your computer that is conflicting. Best regards, |
06-23-2009, 05:24 | #15 (permalink) |
Member: 3941 Status: Offline Thanks Meter: 636 | Go to: http://www.unlocksamsungonline.com/samsungdownloads.php and download the files you need or copy the link in your browser. Links on the site itself work fine. |
How to unlock/unfreeze sgh a877 ? | VODAFONES | UST Pro II | 7 | 08-06-2011 00:15 |
How to unlock/unfreeze sgh a877 ? | VODAFONES | UST Pro II | 1 | 07-14-2010 05:59 |
How to unlock samsung sgh-t919 behold | rajan nishchal | Easy-Unlocker | 3 | 02-17-2009 20:07 |
Cant unlock one MYC-2 Need help | dominik | Phone Unlocking Codes & Maps | 2 | 03-23-2004 17:05 |
