Warning: Crypto block not found m2510 Hy Srs team, i have a problem with one M2510 I try to read codes with sim inside and i have this problem: 10:11:03 - SET TESTMODE DONE 10:11:03 - IMEI: 35302503****** 10:11:04 - FIRMWARE: M2510URIE (September R) 10:11:06 - MSL ADDRESS: RPISB59722 10:11:07 - ADVANCED MSL DETECTED BYPASSING... 10:11:47 - WARNING: CRYPTO BLOCK NOT FOUND 10:11:47 - MSL BYPASS: FAILED The some problem with direct unlock. Can you solve this? B.R. SEBAELPOTRO! sorry for my bad english I speek only spanish |
then we can analyse it btw try also by selecting m2520 as model |
Whit m2520 model the some error crypto block not found This is the dump folder http://www.megaupload.com/?d=J4JJIA7I And the imei is: 35401303314071/1 |
This is the original LOG Booting Trident Phone... 11:53:09 - SET TESTMODE DONE 11:53:10 - IMEI: 35401303314071 11:53:11 - FIRMWARE: M2510VCIE (May 2009) 11:53:13 - MSL ADDRESS: RS5SB33001 11:53:14 - ADVANCED MSL DETECTED BYPASSING... 11:53:54 - WARNING: CRYPTO BLOCK NOT FOUND 11:53:54 - MSL BYPASS: FAILED |
I checked it, and found a strange issue, will make an update for this so you can re-test |
Press in the client ALT+R to relead phone data then shutdown client, and restart, now try again ;) there was some security change in your firmware but hope it will be fine now :D |
This is the best support!!! Very Thanks SRS TEAM!!! Now its all ok! :D:D:D:D:D B.R. SEBAELPOTRO! |
