6300 can't repair FFFFFFFFFFFFFFF Hi all here is log, i tryed with ufs and jaf, also with all bbking versions 18/11/2008 18:58:13 UFS box version: 208 18/11/2008 18:58:13 UFS box SN: xxxx 18/11/2008 18:58:25 Searching for phone ... 18/11/2008 18:58:28 Phone found on FBUS interface 18/11/2008 18:58:28 Reading phone info ... 18/11/2008 18:58:28 Type: RM-217 18/11/2008 18:58:28 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 18/11/2008 18:58:28 IMEI: 352042027070933 18/11/2008 18:58:29 SP LOCK status: 18/11/2008 18:58:29 Config Key: FFFFFFFFFFFFFFFF 18/11/2008 18:58:29 Block 1: CLOSED Type 5 Data: 00101F 18/11/2008 18:58:29 Key counter: 0/3 18/11/2008 18:58:29 Cable counter: 0/10 18/11/2008 18:58:29 Read Phone Info OK 18/11/2008 18:58:29 Operation time: 00:20. 18/11/2008 18:58:29 Successfully done. 18/11/2008 18:58:44 UFS box version: 208 18/11/2008 18:58:44 UFS box SN: 5515 18/11/2008 18:58:56 Searching for phone ... 18/11/2008 18:58:58 Phone found on FBUS interface 18/11/2008 18:58:58 Reading phone info ... 18/11/2008 18:58:58 Type: RM-217 18/11/2008 18:58:59 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 18/11/2008 18:58:59 IMEI: 352042027070933 18/11/2008 18:58:59 SP LOCK status: 18/11/2008 18:58:59 Config Key: FFFFFFFFFFFFFFFF 18/11/2008 18:58:59 Block 1: CLOSED Type 5 Data: 00101F 18/11/2008 18:58:59 Key counter: 0/3 18/11/2008 18:58:59 Cable counter: 0/10 18/11/2008 18:58:59 Read Phone Info OK 18/11/2008 18:58:59 Searching for phone ... 18/11/2008 18:59:02 Phone found on FBUS interface 18/11/2008 18:59:02 Reading phone info ... 18/11/2008 18:59:03 Reading PM Field 308 Subfield 1 with length 8192 bytes 18/11/2008 18:59:18 Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__18_11_2008__18_59_18.bin 18/11/2008 18:59:18 PM308 backup OK 18/11/2008 18:59:18 Searching for UFS box ... 18/11/2008 18:59:18 UFS box detected 18/11/2008 18:59:22 UFS box version: 208 18/11/2008 18:59:22 UFS box SN: xxxx 18/11/2008 18:59:22 UFS box UFSBOX_BB5_FLASH_bb5challenge ... 18/11/2008 18:59:36 0x11130153 18/11/2008 18:59:36 ERROR! 18/11/2008 18:59:36 Operation time: 00:56. 18/11/2008 18:59:36 Done with error(s). |
hi friend Use Jaf Flasher as interface and try to repaire SL again. Jaf more stable. Best Regards. |
any other solution? br |
can u pls tell which version r u using of bb5 king to repair sl zone have u tried with the last version ??? Nokia_BB5KING_v105.zip |
Good luck! |
please try to make check,backup crt via jaf program if u can make these features then your cable 100 % else problem from cable . use another cable and try to unlock it again. Best Regards. |
JAF box ATmega firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__19_11_2008__19_04_33.bin PM308 backup OK Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B0 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... Error. 0x10130103 ERROR! Operation time: 00:29. Done with error(s). Thread phone exit. |
Its looks your cable is faulty. i know you will write here that my cable is working well, open your cable and put right resistor and post the result. BR kashif Khan |
it was a cable problem, i phone sucsesfully repaired with universal fbus cable :) JAF box ATmega firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__25_11_2008__19_06_30.bin PM308 backup OK Searching for JAF box ... JAF box detected JAF box ATmega firmware version: 1B0 Initialize JAF box ... JAF box JAFBOX_BB5_FLASH_bb5challenge ... ASIC ID: 000000010000022600010006010C192101001101 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F bb5king SW v1.07 Sending loader... Rap3Gv3 selected. BB5_FLASH_CMTbootload JAF CMT Boot Ready Hello ok ok Get card info ... Verify card OK Get card info ... Verify card OK Hello ok Hello ok PM send. Test call... cpsr - 0x0000001F p15_1 - 0x0005307F p15_2 - 0x0005117F p15_3 - 0x0005317F esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 Normal BB5 found - 0x0002B400 LR - FFFF3688, param - 0x03, size - 0x00 UpdSLock - 0x00000001 ret - 0x01, <tmp_buff2> - 0x23 PM_308 CRC - 0x00090131 Reciving PM Hello ok PM buff recived After unlock. JAF box ATmega firmware version: 1B0 Searching for phone ... Phone found on FBUS interface Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Operation time: 01:08. Successfully done. Thread phone exit. 25/11/2008 19:07:43 JAF box ATmega firmware version: 1B0 25/11/2008 19:07:57 Searching for phone ... 25/11/2008 19:07:57 Phone found on FBUS interface 25/11/2008 19:07:57 Reading phone info ... 25/11/2008 19:07:57 Type: RM-217 25/11/2008 19:07:57 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 25/11/2008 19:07:57 IMEI: 352042027070933 25/11/2008 19:07:58 SP LOCK status: 25/11/2008 19:07:58 Config Key: 2440700000000000 25/11/2008 19:07:58 Block 1: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 2: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 3: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 4: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 5: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 6: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Block 7: OPEN Type 5 Data: FFFFFF 25/11/2008 19:07:58 Key counter: 0/3 25/11/2008 19:07:58 Cable counter: 0/10 25/11/2008 19:07:58 Read Phone Info OK 25/11/2008 19:07:58 Operation time: 00:16. 25/11/2008 19:07:58 Successfully done. thank u ;) br |
Just press the thanx button |
