09-21-2009, 00:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | 2660 with imei ??????????????????? Somebody could guide me for reparing this phone? Thanks Best regards Here the litle log: All initialized - Ready to work MCU Version V 03.62 MCU Date 05-07-07 Product RM-292 Manufacturer (c) Nokia IMEI ??????????????? Failed to read info -> '?' is not a valid integer value |
09-21-2009, 00:21 | #2 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hello Again! Here the log with Flashing bus: Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 7.125s Check Flashing Bus finished B.R Edit: Here the READ UEM IMEI Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Searching for CBUS Loader: UEM u3_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V MSID-Crypted: 848FC15A26F0FBB108B4B77C42 MSID-Plain: 2C40BAE900CC2310AA000000 FAID-Crypted: BD515B382F4C78BFAEB85705 CBUS Loader Spawned OK! UEM IMEI: 011357003893006 Done, Repowering... Somebody guide me with the step by step? Thanks! Last edited by 69eyes; 09-21-2009 at 00:29. Reason: Add info |
09-21-2009, 00:37 | #3 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | 1: READ UEM IMEI 2: Calculated RPL with credits 3: Write RPL 4: Error Here the Log: Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,02V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data |
09-21-2009, 00:53 | #4 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | 3 time error write RPL (2 CREDITS CONSUMED) All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 7.125s Check Flashing Bus finished Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Searching for CBUS Loader: UEM u3_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V MSID-Crypted: 848FC15A26F0FBB108B4B77C42 MSID-Plain: 2C40BAE900CC2310AA000000 FAID-Crypted: BD515B382F4C78BFAEB85705 CBUS Loader Spawned OK! UEM IMEI: 011357003893006 Done, Repowering... Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 7.109s Check Flashing Bus finished Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data Last edited by 69eyes; 09-21-2009 at 00:56. Reason: Sorry for the double post |
09-21-2009, 00:53 | #5 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hello again: 3 time error write RPL (2 CREDITS CONSUMED) All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 7.125s Check Flashing Bus finished Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Searching for CBUS Loader: UEM u3_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V MSID-Crypted: 848FC15A26F0FBB108B4B77C42 MSID-Plain: 2C40BAE900CC2310AA000000 FAID-Crypted: BD515B382F4C78BFAEB85705 CBUS Loader Spawned OK! UEM IMEI: 011357003893006 Done, Repowering... Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 7.109s Check Flashing Bus finished Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data Thanks! B.R Last edited by 69eyes; 09-21-2009 at 01:03. |
09-21-2009, 06:34 | #6 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hello again 1: READ UEM IMEI 2: Calculated RPL with credits (ASIC 11 SELECTED) 3: Write RPL 4: Done????.........But..... Phone turn off!! I dont undertstand!!! any suggestions?? Many Thanks All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 03.62 MCU Date 05-07-07 Product RM-292 Manufacturer (c) Nokia IMEI ??????????????? Failed to read info -> '?' is not a valid integer value Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Searching for CBUS Loader: UEM u3_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,02V MSID-Crypted: 848FC15A26F0FBB108B4B77C42 MSID-Plain: 2C40BAE900CC2310AA000000 FAID-Crypted: BD515B382F4C78BFAEB85705 CBUS Loader Spawned OK! UEM IMEI: 011357003893006 Done, Repowering... Programming data for IMEI: 011357003893006 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001327E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00437221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001327E (128Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,02V Programming FLASH data... FLASH data Programmed OK Programming UEM data... UEM data Programmed OK Terminating flash session Write UEM finished MCU Version V 03.62 MCU Date 05-07-07 Product RM-292 Manufacturer (c) Nokia IMEI 011357003893006 Mastercode 334043133 IMEI Spare 0A11530730980300 IMEI SV 0311530730980300F4000000 PPM V 03.62, 05-07-07, RM-292, (c) Nokia, UB PSN 0 PSD 0000000D00000000 LPSN 0 UEM 1328 UPP 12642 RFIC 0500 DSP GDSP_P06w45.v32 LCD SUEZ BT 2222-v77 Asic 11 HW Signature C0B8B9EE67EC2032 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00550113570038930000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF MCU Version V 03.62 MCU Date 05-07-07 Product RM-292 Manufacturer (c) Nokia IMEI 011357003893006 Mastercode 334043133 IMEI Spare 0A11530730980300 IMEI SV 0311530730980300F4000000 PPM V 03.62, 05-07-07, RM-292, (c) Nokia, UB PSN 0 PSD 0000000D00000000 LPSN 0 UEM 1328 UPP 12642 RFIC 0500 DSP GDSP_P06w45.v32 LCD SUEZ BT 2222-v77 Asic 11 HW Signature C0B8B9EE67EC2032 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00550113570038930000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 I dont Understand!! |
Can i repair 3110c with imei 12345610654321 with MX KEY please help | ntothel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 10-10-2010 18:17 |
Please add se j132 to unlock with imei , not work with serial!!!!!! | svchost | Seking Server | 3 | 04-25-2009 17:23 |
Motorola by IMEI - No Test Point / No Cable / Just with IMEI : click-here | gsmfactory | Main Sales Section | 0 | 03-29-2006 20:57 |
LG B1200 with IMEI 44xxxxx not working with generated codes?! | Alinus | LG | 0 | 07-29-2003 12:37 |
