[Shadab_M] | 06-12-2010 17:25 | Quote:
Originally Posted by lamran
(Post 5948797)
hi cyclone team
i dowwnload files from navifirm because internet facilities are very poor in my country and speed very low
butt i get this errorr Code:
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0870011263ED8D56FA486FD70113CD41E78329F7
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC240000008A31, Samsung, NOR
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC2400 (Samsung), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
CMT NPC Not Found
CMT CCC Not Found
CMT HWC Not Found
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm495__07.91.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm495__07.91.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 4.968s
Writing all blocks...
Writing CMT NOLO Certificate...
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm495__07.91.m now phoone is dead
please guys help me revive this phone | As you say, phone was just working fine. I assume that its IMEI was OK too.
Now, as in log, Cyclone does not detect any Certificate even NPC in phone. And you are getting this error.
IMHO, please open the phone (if out of warranty) and reheat RAP, your phone should turn on.
You might need to flash it again as previous flashing was unsuccessful.
Br,
Shadab Ahmad |
