5130c Contact Service How to fix 5130c Contact Service How to fix @Moulnisky Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "1350010A05B77D561693BF5129B4C77475D7CE60.C0000651 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! Can't Read SP Info How can i solve this problem |
is about impossible to fix the simlock in this model without a nokia RPL. :( BR Alex |
that is not supported by now,., |
simlock failed????then no solution now.wait for sl3 unlock .for next updation......... |
today i repair 5130c with cyclonbox first i read info MCU Version V 05.61 MCU Date 10-12-08 Product RM-436 Manufacturer (c) Nokia IMEI 355231031665617 Mastercode 66337611 IMEI Spare 3A55320113666501 IMEI SV 3355320113666521F6000000 PPM V 05.61, 10-12-08, RM-436, (c) Nokia , MB CNT Content: mb, V 05.61, 10-12-08, RM-436, (c) Nokia , PSN KMH904339 Module Code 0203868 Basic Product Code 0563951 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 3004 RFIC 06540601 DSP ICPR72_08w47 LCD SHARP BT 2222-143C Failed to read info -> Failed to read SP info 2nd check self test Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Failed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 29, Tests passed: 27, Tests not passed: 2 3rd select bb5 secuirty tab and select rpl calculation (standalone,free) BB5 Unlock Started... MCU Version V 05.61 MCU Date 10-12-08 Product RM-436 Manufacturer (c) Nokia IMEI 355231031665617 Mastercode 66337611 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK and saved to "RM-436_355231031665617_2262010_14639 PM.SecurityBlock.PM" "27C000189D397F56DCD6DC245200FBC794726796.C0000B32 " Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V 05.61 MCU Date 10-12-08 Product RM-436 Manufacturer (c) Nokia IMEI 355231031665617 Mastercode 66337611 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 3.625s phone done thanx all cyclone box team |
Ohh.simlock repair today u.this true.................?????/set is 5130c???/ |
not is one 7210c (RM-436), no 5130c |
there not 5130c no one on word can fix it expt nokia rpl RM-436 not 5130c |
hi my friend just rpl.... |
