6303c failed to boot CMT All checked Nokia 6303c have errors like below. Code: Local mode set Cables are efficient and work with other boxes. Is it an application error? box firmware Code: Box Firmware: Cyclone Nokia/Blackberry Application v01.64, (Jun 30 2011 15:31:22, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 |
Are you working with tx2 yellow adapter? |
Of course. Other models such as 6700 work properly. |
It should be cable fault, you want to read hash ? If yes try via usb |
I want to downgrade SW. I checked on several types of cables , UFC UniFBUS V2 also. I can read phone info and pm. |
Mbus line must be stable, i tested many 6303 phone with cyclone new update there is nothing wrong, When you use ufc2 have you plug ground line to battery terminal |
