Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-05-2011, 08:20   #1 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
CYCLONE V1.12 Bug on DCT4/WD2
CYCLONE V1.12 Bug on DCT4 Checkbus/Flashing/Unlocking/Etc.
6600
Check Flashing bus
Booting UPP...
UPP ID: 0082 [HW_UPP_WD2_v2_5]
Flashbus Write baud set to 100Kbits
w2_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2
PLL Factor: 4
FlashChip[0]: 0x002088BE @ 0x00000000, ST, SectorSize: 64kB, Ext: 0000FF42
FlashChip[1]: 0x002088BE @ 0x02000000, ST, SectorSize: 64kB, Ext: 0000FF42
FlashChip[2]: 0x002088BE @ 0x04000000, ST, SectorSize: 64kB, Ext: 0000FF42
FlashChip[3]: 0x002088BE @ 0x06000000, ST, SectorSize: 64kB, Ext: 0000FF42
Signature: C60000EA750100EA780100EA7B0100EA
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 4Kbits
w2_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088BE (64Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,02V
Flash Loading Failed -> Loader is not ready
Failed to Check DCT4 Flashing Bus -> Problem with sending Flash Loader
3100
Unlocking
Booting UPP...
UPP ID: 1120 [HW_UPP8M_v2]
Searching for CBUS Loader: UEM
u_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM
u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,04V
MSID-Crypted: 843A789BE3FBB54677A2B0FA29
MSID-Plain: 3E4EBAE9008B9579A9000000
FAID-Crypted: 184BD88A3D90E0D9C5A9601E
CBUS Loader Spawned OK!
UEM IMEI: 350697400427281
Done, Repowering...
Programming data for IMEI: 350697400427281
Found FLASH Data Rebuild Block
Found UEM Data Rebuild Block
Booting UPP...
Flashbus Read baud set to 0Kbits
DCT4 ALGORITHM
Programming FLASH data...
FLASH data Programmed OK
Programming UEM data...
UEM data Programmed OK
Terminating flash session
Write UEM finished
MCU Version V 05.02
MCU Date 14-01-04
Product RH-19 (Nokia 3100/3120 CABLE 6100)
Manufacturer (c) NMP.
IMEI 350697400427281
Mastercode 2436474064
Proceeding with RSA Unlock...
Setting Local Mode...
Local mode Set
Warning: Failed to read SP Info, Assuming defaults
Asic 2
HW Signature 8A15E561968BB935
Simlock Server SIMLOCKLIB VERSION 2.28
Simlock Key E0BDF01374C5CEBB
Simlock Profile FD5749589E8D1135
Simlock Aux 00025555
Simlock IMEI 00553506974004272800
Simlock Key Cnt 3
Simlock FBUS Cnt 14
Asking card to sign HW Signature...
Signed OK (7C43453CB204E2F00759B5C2ADC065E0FE264328)
Calculating SP...
Writing SP...
Failed to Unlock DCT4 Plus -> Possible cause: Other error (0x01)
I tried to Flash/unlock etc. in HWK all Process are Perfect
But when i tried in CYCLONE v1.12 all Process are Failed
i use Tx2 Adaptor and Same cable
I think their a bugs in Cyclone v1.12
I hope that Cyclone team fix this in next update
Ferhel
Old 04-05-2011, 08:24   #2 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
I Also update my Box Firmware to 1.58
Nothing Happened i encounter Same Problem
Old 04-05-2011, 08:29   #3 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
wd2 and old dct4 not supported in unlock
thats why you have ufs w/ hwk
Old 04-05-2011, 08:41   #4 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
ya when cyclone said this is not included in there software
Old 04-05-2011, 08:53   #5 (permalink)
Member: 1432587
Sonork: 1601146
Smile CYCLONE V1.12 Bug on DCT4/WD2
Yes cyclone some bugs on wd2 mobile.i faced problem unlocking nokia 7610.............i request u to plez add wd2 unlock option .thansk in advnce.i hope cyclone team mebers will do this for cyclone customers
Old 04-05-2011, 17:40   #6 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
is that true Cyclone not Support WD2/DCT4 for Flashing and Unlocking
Need Response from Cyclone Team
Old 04-06-2011, 14:19   #7 (permalink)
Member: 1432587
Sonork: 1601146
Plez reply cyclone members.any idea to clear this bug
Old 04-06-2011, 14:29   #8 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
I think there are too busy to Sl3 new Hashes
Old 04-06-2011, 14:31   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,129
There is bugs on WD2 , Use other boxes to flash WD2
and cyclone not support to unlock old DCT4 series
Old 04-06-2011, 16:24   #10 (permalink)
Member: 1432587
Sonork: 1601146
wHICH BOX IS BEST FOR UINLOCKING DCT4 OLD AND WD2 MOBILES
Old 04-07-2011, 08:37   #11 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,129
which box is best for uinlocking dct4 old and wd2 mobiles
jaf,ufs .
Old 04-08-2011, 19:50   #12 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
also check this wd2 7610 bus check problem,,loaders ,
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.00v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 1.29v PASSED
VBAT Voltage 5.02v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting UPP...
UPP ID: 1081 [HW_UPP_WD2_v3_1]
w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2
PLL Factor: 4
FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121
FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121
FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121
w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.04V
now with excuse ,ufs logs
with same cable ,same mobile
1st Boot: Ok, WD2, UPP: 1081 [] [2.1.0.1]
2nd Boot: w3_2nd.fia, Ver: 4.76.0
Fl0: 0x00000000-0x01FFFFFF,00ECDDFE,Sam K8S5615ETA
Fl1: 0x02000000-0x03FFFFFF,00ECEEFE,Sam K8S5615ETB
Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB
Algorithm: w3_amd_b.fia, Ver: 4.76.0
Rebooting Mobile
plz karwos and syroya,,fix this bug,,
we hope ,fix will very soon,,,,,,,,,,,,thx
Old 04-08-2011, 20:14   #13 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
The first time i bought this cyclone box, the reason, this box is very complete to support nok phone,
without using another, this box help much....
So, no other reason, why it is not supported again.......
Every update much better than before, not be the worst update....
Btw,
waiting for next update
br
aswancamel
Old 04-12-2011, 01:53   #14 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 280
Dtc4 wd2
Btw,
br
aswancamel
Hi bro.
I agree with you once I bouth cyclone I throw many boxs more than 5 years jaf ufs3 and 8 clone hwk becose cyclone is completly nokia supporter.
use another box to flash and unlock dtc4 and wd2 is not an answer and not from you ser MR3 its' not smart solution
we are now grow up we are not a childs excuse me ser MR3 I preffer downgrad only for bb5 not for us.
So we nned unlock dtc4 wd2 even dtc3 why not!!!!
Also I preffer unlock bb5+ by server with imei althow expenseve so as to alive market
REGARDS
Old 04-15-2011, 01:22   #15 (permalink)
audymar's Avatar
Member: 1219937
Thanks Meter: 35
same here i cannot flash 5300 same error
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm146__07.20.mcusw
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.22431 seconds with 9 queries
