03-07-2011, 16:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Cyclone DEMOLITION! XGold1 Unlock/RPL, XGold2 Flash/RPL, W7 64bit, New log2cod, more. What's new ? ===================== Installer v1.11 07.03.2011 =====================
Download Links http://www.**********/CycloneBoxInstaller.exe http://www.siroya.org/downloads/CycloneBoxInstaller.exe http://www.***************/downloads/...xInstaller.exe ps1. yes, germany support server HDD is physsicly crashed.. it will be back in few days.. hope with noncorrupted content. ps2. be prepared for more standalone&HOT things these days ps3. new drivers included in this package are ONLY compatible with this new version. Don't try using them on older builds and vice versa ! IMPORTANT: You must update your box drivers to work with the new software version. To do this, after you installed the last exe, go in control panel/system/device manager and update your drivers looking for them in the folder c:\Program files\Cyclone box\Drivers. Once done, please, update your box firmware using the new software version. Failing doing this step will mean getting this error Code: Box Maintenance procedure started at 16:24:27 Box Open Error -> Security problem #5 Box Maintenance Error -> No connection was established, or box is not in needed mode Also notice that when you update the Box Firmware can get this "error" Code: Updating Security Area... Security Area Updated, Took: 0.109s Updating Main Firmware... Main Firmware Updated, Took: 15.859s Updating COM Emulator Firmware... COM Emulator Firmware Updated, Took: 1.297s Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Firmware: Cyclone Nokia Application v01.53, (Mar 7 2011 00:52:52, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41 Cyclone Server Send Command Error -> Code: 500, Not allowed to Upgrade Bootloader Failed to Upgrade Bootloader -> Server Transaction Failed Secure Bootloader Update Skipped, Not allowed or not needed Disconnected from Cyclone Server Box Maintenance finished successfully Best Regards, Cyclone Team Last edited by moulnisky; 03-09-2011 at 00:30. |
The Following 118 Users Say Thank You to SiRoYa For This Useful Post: |
03-07-2011, 16:09 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Good job sir! First tests C1-01 XGold2 flashed Quote:
The Following 42 Users Say Thank You to karwos For This Useful Post: |
03-07-2011, 16:11 | #4 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | 1616 XGold1 "Read LOG2Cod", it saves 3 files: PM - actual dumped PM from flash chip LOG - log file for processing by LOG2COD (unlock) RPL - RPL for Simlock/Imei repair/initialization Quote:
The Following 23 Users Say Thank You to karwos For This Useful Post: |
03-07-2011, 16:13 | #6 (permalink) | |||
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Resetting bad code counter First Quote:
The Following 20 Users Say Thank You to karwos For This Useful Post: |
03-07-2011, 16:14 | #9 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | XGold1 Unlock/RPL supported mobiles: 1616, 1280, 1208, 1209, 1800, C1-00, and others... so we can unlock without BF this phones? br, fingusio |
The Following User Says Thank You to fingusio For This Useful Post: |
03-07-2011, 16:18 | #15 (permalink) |
Freak Poster Join Date: Jun 2006 Location: niğde
Member: 302046 Status: Offline Thanks Meter: 37 | Box Open Error -> Security problem #5 Initialization has failed -> No connection was established, or box is not in needed mode problem box? |
The Following User Says Thank You to maktel51 For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
