11-07-2009, 13:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 45
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Cyclon Team.please healp.no Flash imge see. |
11-07-2009, 13:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | bro check instol all flash file go to cyclone.exe setting tab paths setting adds folder c\program file \nokia\phoenix\products\ c\program file \common file \nokia\datta packege\prodcts\ add folder brother |
11-07-2009, 22:13 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Cyclone Software use the "VPL" files to retrieve the variants.... if your flash files dont have tthe VPL inside the soft cant see.... Oldest flash files use INI instead VPL thats why you cant see all flashes. |
11-08-2009, 08:23 | #4 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | i have got this result. I have paths selected,but not all flashes are see!!At least for BB5. Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0A, (Nov 6 2009 01:26:23, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C000014D HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D10003F2 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.11v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.83v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products... Found 36 products, Filtering BB5 Products - wait... 36 Products left after filtering. Ready. Retrieving Variants for Product RM-237 - wait... Failed to retrieve BB5 Variants -> Product not found at all! Some critical, unexpected error occured! what can i do sir.please healp. |
11-08-2009, 09:03 | #6 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | All ready install. sir,ihave already install 3110c flashfil...JAF+MX KEY can fil auto select.Look at this sir. Card life counter: 99.99% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.8.0 Changing mode...Done! Fast phone flashing selected. FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\ Searching for default location of ini... Checking path: \Products\RM-237\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-237\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__06.01.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__06.01.ppm_s CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__06.01.image_s APE Variant file: NONE Languages in ppm: English,Bahasa Indonesia,Bahasa Malasia |
11-08-2009, 09:12 | #7 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | bro cyclone box exs opens dct4/wd2/bb5 tab click bb5 tab flash product rm237 selected veriant tab file select flash images tree file adds on cyclone tab |
11-08-2009, 11:04 | #8 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Thanks,sir. But, sir.im a new user in Cyclon.so its realy problem for me.what can i know what is the correct flash image.like MCU,PPM,CNT.is Their any way.could you explain sir? |
11-08-2009, 11:08 | #9 (permalink) | |
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
1 MCU 2 PPM 3 CNT | |
Cyclone Team Please Help | KhalIman | Cyclonebox | 20 | 12-16-2009 02:11 |
cyclone team please help me | cellcarekphb | Cyclonebox | 2 | 07-18-2009 13:29 |
cyclone team .. Please update. urgent need updates .... No more deadlines | residentdenuevo | Cyclonebox | 6 | 06-14-2009 04:54 |
Cyclone team please help me | cellcarekphb | Cyclonebox | 25 | 05-29-2009 14:21 |
cyclone team please help me | akha | Cyclonebox | 8 | 05-04-2009 21:55 |
