sktamrkar | 05-05-2013 04:43 | 7210c Sim Lock Problem Code:
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Writing Simlock...
Handling as SL1/SL2 Simlock Data Simlock NOT ACCEPTED !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key ACCEPTED OK !
Writing WMDRM PD Data...
WMDRM PD Data ACCEPTED OK !
Processing FLASHBUS Part...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1E50000BAF727E562ED8A093973F032A9B623041
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Writing PSN...
Writing HWID...
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
SX4 Authorization / SD Repair Procedure Started....
Failed to obtain Phone Unique Data, Will use Server and Original Card
MCU Version V 07.23
MCU Date 17-07-09
Product RM-436 (Nokia 7210 Supernova)
Manufacturer (c) Nokia
IMEI 355231034021453
Mastercode 3574331657
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Cyclone Server (2.0.0.100), Cyclone Box Team 2008-2012 - Ready.
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 12 bytes, Status: OK
[1,2] Written, Length: 70 bytes, Status: OK
[1,3] Written, Length: 70 bytes, Status: OK
[1,4] Written, Length: 70 bytes, Status: OK
[1,6] Written, Length: 276 bytes, Status: OK
[1,7] Written, Length: 276 bytes, Status: OK
[1,8] Written, Length: 276 bytes, Status: OK
[1,10] Written, Length: 384 bytes, Status: OK
[1,11] Written, Length: 384 bytes, Status: OK
[1,12] Written, Length: 384 bytes, Status: OK
[1,14] Written, Length: 384 bytes, Status: OK
[1,15] Written, Length: 384 bytes, Status: OK
[1,16] Written, Length: 384 bytes, Status: OK
[1,17] Written, Length: 32 bytes, Status: OK
[1,19] Written, Length: 16 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 24, Record written NOT OK: 0
Disconnected from Cyclone Server
[4,1] Written, Length: 800 bytes, Status: OK
[4,3] Written, Length: 10 bytes, Status: OK
[4,4] Written, Length: 8 bytes, Status: OK
[4,5] Written, Length: 8 bytes, Status: OK
[4,6] Written, Length: 8 bytes, Status: OK
[4,9] Written, Length: 5 bytes, Status: OK
[4,18] Written, Length: 80 bytes, Status: OK
[4,19] Written, Length: 4 bytes, Status: OK
[4,28] Written, Length: 2 bytes, Status: OK
[8,0] Written, Length: 2 bytes, Status: OK
[8,1] Written, Length: 16 bytes, Status: OK
[8,2] Written, Length: 16 bytes, Status: OK
[8,3] Written, Length: 128 bytes, Status: OK
[8,4] Written, Length: 128 bytes, Status: OK
[8,8] Written, Length: 8 bytes, Status: OK
[8,9] Written, Length: 8 bytes, Status: OK
[8,10] Written, Length: 24 bytes, Status: OK
[11,0] Written, Length: 4 bytes, Status: OK
[11,1] Written, Length: 4 bytes, Status: OK
[11,2] Written, Length: 4 bytes, Status: OK
[11,3] Written, Length: 4 bytes, Status: OK
[11,4] Written, Length: 1 bytes, Status: OK
[11,5] Written, Length: 6 bytes, Status: OK
[11,6] Written, Length: 2 bytes, Status: OK
[11,7] Written, Length: 1 bytes, Status: OK
[11,8] Written, Length: 1 bytes, Status: OK
[11,9] Written, Length: 1 bytes, Status: OK
[11,10] Written, Length: 1 bytes, Status: OK
[11,11] Written, Length: 1 bytes, Status: OK
[11,12] Written, Length: 1 bytes, Status: OK
[11,13] Written, Length: 1 bytes, Status: OK
[11,14] Written, Length: 2 bytes, Status: OK
[11,15] Written, Length: 2 bytes, Status: OK
[11,16] Written, Length: 2 bytes, Status: OK
[11,17] Written, Length: 2 bytes, Status: OK
[11,18] Written, Length: 16 bytes, Status: OK
[11,19] Written, Length: 32 bytes, Status: OK
[11,20] Written, Length: 32 bytes, Status: OK
[11,21] Written, Length: 2 bytes, Status: OK
[11,22] Written, Length: 2 bytes, Status: OK
[11,23] Written, Length: 2 bytes, Status: OK
[11,24] Written, Length: 2 bytes, Status: OK
[11,25] Written, Length: 2 bytes, Status: OK
[11,26] Written, Length: 2 bytes, Status: OK
[11,27] Written, Length: 2 bytes, Status: OK
[11,28] Written, Length: 2 bytes, Status: OK
[11,29] Written, Length: 2 bytes, Status: OK
[11,30] Written, Length: 2 bytes, Status: OK
[11,31] Written, Length: 2 bytes, Status: OK
[11,32] Written, Length: 2 bytes, Status: OK
[11,33] Written, Length: 2 bytes, Status: OK
[11,34] Written, Length: 2 bytes, Status: OK
[11,35] Written, Length: 2 bytes, Status: OK
[11,36] Written, Length: 2 bytes, Status: OK
[11,37] Written, Length: 2 bytes, Status: OK
[11,38] Written, Length: 2 bytes, Status: OK
[11,39] Written, Length: 2 bytes, Status: OK
[11,40] Written, Length: 2 bytes, Status: OK
[11,41] Written, Length: 2 bytes, Status: OK
[11,42] Written, Length: 2 bytes, Status: OK
[11,43] Written, Length: 2 bytes, Status: OK
[11,44] Written, Length: 2 bytes, Status: OK
[11,45] Written, Length: 2 bytes, Status: OK
[11,46] Written, Length: 2 bytes, Status: OK
[11,47] Written, Length: 2 bytes, Status: OK
[11,48] Written, Length: 2 bytes, Status: OK
[11,49] Written, Length: 2 bytes, Status: OK
[11,50] Written, Length: 2 bytes, Status: OK
[11,51] Written, Length: 2 bytes, Status: OK
[11,52] Written, Length: 2 bytes, Status: OK
[11,53] Written, Length: 2 bytes, Status: OK
[11,54] Written, Length: 2 bytes, Status: OK
[11,55] Written, Length: 2 bytes, Status: OK
[11,56] Written, Length: 2 bytes, Status: OK
[11,57] Written, Length: 2 bytes, Status: OK
[11,58] Written, Length: 2 bytes, Status: OK
[11,59] Written, Length: 2 bytes, Status: OK
[11,60] Written, Length: 2 bytes, Status: OK
[11,61] Written, Length: 2 bytes, Status: OK
[11,62] Written, Length: 2 bytes, Status: OK
[11,63] Written, Length: 2 bytes, Status: OK
[11,64] Written, Length: 2 bytes, Status: OK
[11,65] Written, Length: 2 bytes, Status: OK
[11,66] Written, Length: 4 bytes, Status: OK
[11,67] Written, Length: 1 bytes, Status: OK
[11,68] Written, Length: 4 bytes, Status: OK
[11,69] Written, Length: 4 bytes, Status: OK
[11,70] Written, Length: 4 bytes, Status: OK
[11,71] Written, Length: 4 bytes, Status: OK
[11,72] Written, Length: 16 bytes, Status: OK
[11,73] Written, Length: 4 bytes, Status: OK
[11,74] Written, Length: 2 bytes, Status: OK
[31,4] Written, Length: 14 bytes, Status: OK
[54,0] Written, Length: 2 bytes, Status: OK
[88,0] Written, Length: 36 bytes, Status: OK
[96,0] Written, Length: 2 bytes, Status: OK
[120,0] Written, Length: 944 bytes, Status: OK
[120,1] Written, Length: 80 bytes, Status: OK
[120,2] Written, Length: 20 bytes, Status: OK
[120,3] Written, Length: 112 bytes, Status: OK
[193,2] Written, Length: 8 bytes, Status: OK
[193,3] Written, Length: 32 bytes, Status: OK
[193,4] Written, Length: 32 bytes, Status: OK
[193,9] Written, Length: 64 bytes, Status: OK
[218,0] Written, Length: 2 bytes, Status: OK
[239,0] Written, Length: 2 bytes, Status: OK
[239,1] Written, Length: 3057 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19
[308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,5] Written, Length: 10 bytes, Status: Not accepted, Code: 19
[308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,8] Written, Length: 1 bytes, Status: Not accepted, Code: 19
[308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19
[322,0] Written, Length: 1 bytes, Status: OK
[341,0] Written, Length: 1 bytes, Status: OK
[341,3] Written, Length: 4 bytes, Status: OK
[341,4] Written, Length: 4414 bytes, Status: OK
[354,0] Written, Length: 3 bytes, Status: OK
[355,1] Written, Length: 2028 bytes, Status: OK
[356,0] Written, Length: 2 bytes, Status: OK
[362,0] Written, Length: 1 bytes, Status: OK
[362,1] Written, Length: 120 bytes, Status: OK
Write PM Finished, Record written OK: 140, Record written NOT OK: 9
Started Phone Security Analysis...
MCU Version V 07.23
MCU Date 17-07-09
Reading Security Block...
PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK
-- SIMLOCK PROBLEM --
Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED!
To repair simlock area, Select Unlock method : "RPL CALCULATION",
And then click DIRECT UNLOCK. SL Area will be re-formatted. -- SIMLOCK PROBLEM --
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"1E50000BAF727E562ED8A093973F032A9B623041.C0006FC5" Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
Checking ECC KEYS...
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
BB5 Unlock Started...
MCU Version V 07.23
MCU Date 17-07-09
Warning: Failed to read SP Info, Assuming defaults
Simlock Server
Simlock Key C0F0540300465203
Simlock Profile 6E000000F0324300
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK! Writing Simlock...
BB5 Unlock Failed -> Simlock NOT ACCEPTED ! Maybe is SL3 phone? |
