12-26-2009, 20:22 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | need help 5130c i flash with cyclone box via usb ,fbus,,,but same,,all operation done,but when i want to on my mobile its only on nokia logo and then white and go to off,,plz help ,the custumer is on my head ,plzz i think its software problem,, some days ago same problem,with 6120c.,and i find the solution by a blank ppm,,and now 6120c is ok,,so plz tell me about this, Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.13v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 42 products, Filtering BB5 Products - wait... 7 Products left after filtering. Ready. Retrieving Variants for Product RM-495 - wait... 398 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [BB5 BootRom]: Found 1 active devices [Nokia USB Flashing Generic]: Opening Connection [Nokia USB Flashing Generic]: Port opened OK! CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1F00021136F87C560B4C7C614B396E7315885504 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 1 active devices [Nokia BB5 ADL Loader USB Generic]: Opening Connection [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm495__07.91.mcusw (CMT)... rm495__07.91.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Erase taken 98.953s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 66.32s Processing rm495__07.91.ppm_ed (CMT)... rm495__07.91.ppm_ed, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Erase taken 39.578s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 25.31s Processing rm495__07.91.image_ed_si_red (CMT)... rm495__07.91.image_ed_si_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Erase taken 178.406s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 40.547s Restarting CMT... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! |
12-26-2009, 21:08 | #2 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | info Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... MCU Version V 07.91 MCU Date 29-10-09 Product RM-495 Manufacturer (c) Nokia IMEI 353223033893182 Mastercode 774106121 IMEI Spare 3A35220333981308 Product Code HEC736336 ATO 0 PCI 1000 Failed to read info -> Failed to read SP info |
12-26-2009, 21:32 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | The phone was working when comes to you ? Is your phone the same of this thread ? http://forum.gsmhosting.com/vbb/showthread.php?t=889160 If you open multiple threads about the same phone, is dificult to help.... |
12-26-2009, 21:36 | #4 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | yes boss,,only for language changing ,,now again i flash with cyclone f bus,,but same, see logs and self test Flashing successfully finished! Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LCD_TEST Failed ST_LPRF_IF_TEST Failed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Failed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Failed ST_BT_WAKEUP_TEST Failed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 29, Tests passed: 24, Tests not passed: 5 |
12-26-2009, 21:53 | #6 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | dear ,i try every thing ,all version,,but same,try 2 flash with jaf ,too same,,in the last failed imei,, some days a go,i face same problem, with 6120c ,but in forum gsm i got a very usefull solution ,,by writing a blank pmm,and now 6120c is ok, i think may be its too same problem,,but still i don,t not use this ppm for 5130c,,because may be , i will lost my backup,,and security data,,so what u say about this ppm,,,blank pmm |
12-28-2009, 18:45 | #14 (permalink) | |
Registered User Join Date: Nov 2009 Location: RSA
Member: 1166923 Status: Offline Thanks Meter: 77 | Quote:
Those test failure is not normal... It's seem like HW failure. Best regards | |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help 5130c | vijay9270 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-26-2009 11:25 |
need help 5130c | vijay9270 | Nokia Hardware & Hardware Repair | 3 | 12-08-2009 16:02 |
5130c pm w/o 308 need help... | renylpocs | Nokia Base Band 5 ( BB-5 ) | 2 | 08-22-2009 03:32 |
5130c need helpe | nokia-ps | Nokia Hardware & Hardware Repair | 1 | 06-21-2009 18:59 |
