Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-02-2009, 20:23   #1 (permalink)
Member: 353737
Sonork: 100.1580139
Thanks Meter: 43
Unlock bb5 sucessfully 5610 rm-359,5310 rm-304,6300 rm-217
GOOD UPDATE VERY VERY FAST UNLOCK
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application
Box Serial Number: C000006F
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: D1000434
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.17v PASSED
MCU Voltage 3.26v PASSED
Core Voltage 1.86v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
Manufacturer (c) Nokia
IMEI 356380020506255
Mastercode 1412366456
IMEI Spare 3A65830002052605
IMEI SV 3365830002052665F6000000
PPM V 08.23, 21-11-08, RM-358, (c) Nokia , NTM
CNT Content: n_tmobusa_white_v2 18-Dec-08, V 08.23, 21-11-08, RM-358, (c) Nokia , ,
PSN CNJ217371
Product Code 0565932
Module Code 0203577
Basic Product Code 0561171
PSD 0000000000000000
LPSN 0
RETU 15
TAHVO 22
AHNE 30
HW 1902
RFIC 17141715
DSP ICPR71_08w22
LCD SHARP
BT 2222-143
Simlock Server SIMLOCK SERVER
Simlock Key 3102000000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310160
Simlock[2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310200
Simlock[3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310210
Simlock[4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310220
Simlock[5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310230
Simlock[6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310240
Simlock[7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310250
Simlock[8,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260
Simlock[9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310270
Simlock[10,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310310
Simlock[11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310580
Simlock[12,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310660
Simlock[13,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310800
Simlock[14,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310490
BB5 Unlock Started...
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 2610010E62CD4F500F1612B27C029C2E0A0126DA
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0A0D74E6C8F49779262B4801CC023D50D9468B09
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Writing Security Block...
Writing Simlock Key...
SP Accepted, doing reset to update block...
Booting RAP...
Box VPP disabled
Restoring NPC...
BB5 Unlock Failed -> NPC Restore failed, this is very critical, maybe TX2 issue?
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
IMEI 12345610654321?
BB5 Unlock Failed -> '?' is not a valid integer value
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
No Simlock Structure chosen!
[120,0] Written, Length: 464 bytes, Status: OK
[120,1] Written, Length: 80 bytes, Status: OK
[120,2] Written, Length: 20 bytes, Status: OK
[308,1] Written, Length: 8192 bytes, Status: OK
Write PM Finished, Record written OK: 4, Record written NOT OK: 0
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
Booting RAP...
RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM
Box VPP disabled
APE Subsystem Not Found
Processing 2610010E62CD4F500F1612B27C029C2E0A0126DA.Sx4Bypass .NPC.CMT.crt...
CMT NPC Erased
CMT NPC Written
Write CMT NPC Certificate finished
Restarting MCU...
All files processed OK!
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
Box VPP disabled
Restarting MCU...
Restarting MCU...
Booting RAP...
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 08.23
MCU Date 21-11-08
Product RM-359
Simlock Key 0010100000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: OPENED Type: MCC-MNC Data: 00101F
Unlock finished!
MCU Version V 09.42
MCU Date 07-11-08
Product RM-304
IMEI 352064020105524
Mastercode 477265206
Simlock Key 7161000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 71610F
Security block OK!
Booting RAP...
CMT_PUBLIC_ID: 0D20021160750254B04AABA53674C5771EB04CD4
Box VPP disabled
PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D
Restarting MCU...
Restarting MCU...
Booting RAP...
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 09.42
MCU Date 07-11-08
Product RM-304
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!
MCU Version V 04.70
MCU Date 24-01-07
Product RM-217
Manufacturer (c) Nokia.
IMEI 353933014562313
Mastercode 7745436217
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2140700000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 21407F
Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 21402F
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 1C500110E238005851EEBA36319FCAA89A68020C
CMT_ROM_ID: 191EC665DFAAF68F
FlashChip[0,CMT]: 0x00EC22FE00006921, Samsung, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Version V 04.70
MCU Date 24-01-07
Product RM-217
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[1,2] State: OPENED Type: GID Data: FFFF
Simlock[1,3] State: OPENED Type: GID Data: FFFF
Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[2,2] State: OPENED Type: GID Data: FFFF
Simlock[2,3] State: OPENED Type: GID Data: FFFF
Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[3,2] State: OPENED Type: GID Data: FFFF
Simlock[3,3] State: OPENED Type: GID Data: FFFF
Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[4,2] State: OPENED Type: GID Data: FFFF
Simlock[4,3] State: OPENED Type: GID Data: FFFF
Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[5,2] State: OPENED Type: GID Data: FFFF
Simlock[5,3] State: OPENED Type: GID Data: FFFF
Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[6,2] State: OPENED Type: GID Data: FFFF
Simlock[6,3] State: OPENED Type: GID Data: FFFF
Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock[7,2] State: OPENED Type: GID Data: FFFF
Simlock[7,3] State: OPENED Type: GID Data: FFFF
Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Unlock finished!
The Following User Says Thank You to topcomgsm For This Useful Post:
Old 05-02-2009, 20:42   #2 (permalink)
waji mobiles's Avatar
Member: 326871
Sonork: down2 sky.up 2 the earth
Thanks Meter: 636
Hey thats great !!!!
Old 05-02-2009, 20:53   #3 (permalink)
amralkareem's Avatar
Member: 153397
Sonork: 113032
Thanks Meter: 372
thx for feedback
br
Old 05-02-2009, 22:22   #4 (permalink)
Member: 353737
Sonork: 100.1580139
Thanks Meter: 43
UNLOCK SUCESSFULLY N73 RM-132
Initializing box...
Card is activated
Box is activated
USB Voltage 5.13v PASSED
VBAT Voltage 0.83v PASSED
VBAT Voltage 4.76v PASSED
Box VPP disabled
VPP Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
Box VPP disabled
MCU Version V 05wk47v51.4
MCU Date 29-08-07
Product RM-132
IMEI 354804016023050
Mastercode 7050252652
IMEI Spare 3A45080461200305
IMEI SV 3345080461200355F2000000
PSN CDF999907
Product Code 0544092
Module Code 0202856
Basic Product Code 0545048
PSD 0000001D00000000
RETU 15
TAHVO 22
AHNE 30
HW 7201
RFIC 17211721
DSP scarfe_05wk46v50
Simlock Key 7160601908742000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 71606F
Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 21407F
Simlock[3,1] State: CLOSED Type: MCC-MNC Data: 21402F
Simlock[4,1] State: CLOSED Type: MCC-MNC Data: 74000F
Simlock[5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123
Simlock[6,1] State: CLOSED Type: MCC-MNC Data: 33403F
Simlock[7,1] State: CLOSED Type: MCC-MNC Data: 70403F
Simlock[8,1] State: CLOSED Type: MCC-MNC Data: 71030F
Simlock[9,1] State: CLOSED Type: MCC-MNC Data: 70604F
Simlock[10,1] State: CLOSED Type: MCC-MNC Data: 71402F
Simlock[11,1] State: CLOSED Type: MCC-MNC Data: 72207F
Simlock[12,1] State: CLOSED Type: MCC-MNC Data: 74807F
Simlock[13,1] State: CLOSED Type: MCC-MNC Data: 73002F
MCU Date 29-08-07
Product RM-132
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
APE_SYSTEM_ASIC_ID: 17100708
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 4C62C10D75E1E44DFBCCB3DF68AFC9ED13E2AA5D
APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000
APE_ROM_ID: 1DFD66132C872FD4
CMT_PUBLIC_ID: 06A0000CC59B57506E2071479B273968BAAFD570
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Date 29-08-07
Product RM-132
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!
Old 05-03-2009, 05:41   #5 (permalink)
Member: 124442
Thanks Meter: 7
mera k510 jo k hang hota he main ne sofwearbhi kiya he lekin masla same hi he plz help me
Old 05-03-2009, 06:00   #6 (permalink)
kikikokoki's Avatar
Member: 748785
Sonork: KIKO_GSM
Thanks Meter: 309
good info sir good cyclone box
Old 05-03-2009, 06:43   #7 (permalink)
Member deceased !!
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Thanks Meter: 1,348
its not sony ericsson section
its cyclone section
Old 05-03-2009, 07:19   #8 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
Truely Losted U R...no DOubt
1 :- Wrong Section
2 :- Against Forum Rules no Other language then English
Old 05-03-2009, 11:44   #9 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,141
5610 well done
MCU Version V 06.60
MCU Date 07-03-08
Product RM-242
IMEI 352028020646860
Mastercode 3463542141
Simlock Key 4250200000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 42502F
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_PUBLIC_ID: 13700109B0954F500F04A65C080547B75766BBA1
Box VPP disabled
PAPUBKEYS Hash for CMT: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB
Restarting MCU...
Restarting MCU...
Booting RAP...
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 06.60
MCU Date 07-03-08
Product RM-242
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished!
Old 05-04-2009, 21:36   #10 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Thanks all for nice feedback and of course knowledge how to use attached TX2 ADAPTER
Nokia 5610 RM-359 T-mobile Full Pm Need gsmbee Nokia Base Band 5 ( BB-5 ) 8 01-18-2010 13:52
5610 rm 359 unlock ok universalbox shahid41 Universalbox 1 09-08-2009 16:14
Flash Nokia 5610 RM-359 with RM-242 creeve4 Nokia Base Band 5 ( BB-5 ) 10 08-31-2009 17:23
Nokia 5610 RM-359 Flashing creeve4 Nokia Base Band 5 ( BB-5 ) 8 02-21-2009 20:35
hi i need nokia 5610 firmware rom is rm-359 software version is 5.92 r3ject Exchange Section 0 11-03-2008 17:29
Page generated in 0.40598 seconds with 9 queries
