03-19-2012, 17:55 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | Can cyclonebox read pm 120-308 on dead SL3 Phones thanks.. |
The Following User Says Thank You to chandio_180 For This Useful Post: |
03-19-2012, 18:40 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Just do create rpl from phone. In emergency mode should be able to back-up the simlock too which is the essential part you need Check if in the RPL you have the simlock data and the simlock key data: if yes then you have what you need BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
03-20-2012, 08:22 | #3 (permalink) | |
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | Quote:
thanks for good rply but dear sir ,in your rply we can do all that if phone is local mode ,,but problem is for dead phones if there any way to read pm 120 from dead phone as we are making rpl from dead phone ??? thank you B,R chandio | |
03-20-2012, 08:25 | #4 (permalink) |
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | thank you for good rply but sir all we can do which you tell us in local mode , but problm is can we read pm120 from dead phone as we are making rpl backup from dead phone ??? thank you ........ |
03-20-2012, 08:34 | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Cyclone has the capability to read the rpl from phones dead for wron download or similar (not entering in local mode). The simlock is a part of the rpl Another trick is do "read all certs" in the bb5/security tab and afterward (BE SURE YOU DID READ THE CERTS!!!) with "ncp only" ticked click on erase certs: if the mobile is dead for wrong downgrade or similar software issues you should be able now to get in local mode and read the full PM; afterward just write back the related .npc.cmt cert in the phone BR Alex |
The Following 5 Users Say Thank You to moulnisky For This Useful Post: |
03-31-2012, 04:02 | #6 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Slovenia Age: 43
Member: 155186 Status: Offline Sonork: 100.1590978 Thanks Meter: 39 | I get one dead N8, because of interrupted firmware upgrade. Now i can not read RPL and PM. But i can backup certificates. Can i now "erase all certs" with "Erase NPC only" ticked? And than read PM and than write certs back and than Flash it? And when i will flash it, which firmware i must use (25.8;24.1;14.2;...) ? Code: RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Proceeding with Recovery Mode... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 1D40021844D60344CC9FB4B76197E58002A9BFF5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.24.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.24.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found NPC Backup stored in "1D40021844D60344CC9FB4B76197E58002A9BFF5_31.3.2012_45133.NPC.CMT.crt" Recovery Mode Failed, storing Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! |
The Following User Says Thank You to Frogy DJ For This Useful Post: |
03-31-2012, 06:55 | #7 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
Code: because of interrupted firmware upgrade Read All certs erase NPC only (Check if phone can go to local mode) if phone can go to local mode read all pm files ( MUST) erase phone flash with any version what you like restore certs restore backup pm Last edited by Mr.3.; 04-02-2012 at 07:27. | |
The Following User Says Thank You to Mr.3. For This Useful Post: |
03-31-2012, 06:56 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Use the function "create rpl from phone" to make an rpl back-up. check in the rpl are present the fields simlock_data simlock_key_data. if both these fields are in you can go on doing a full flash using the last firmware related to its product code. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
04-02-2012, 05:45 | #10 (permalink) | |
Member: 155186 Status: Offline Sonork: 100.1590978 Thanks Meter: 39 | Quote:
Did i sucessfully read my certs? Do i must connect via FBUS? What Not yet? What is the correct next step, i realy do not want to screw phone. | |
04-02-2012, 06:40 | #11 (permalink) | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
