all user i need hlp i need the solution Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.77v PASSED VBAT Voltage 1.12v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 2.23v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
Box Selftests Failed -> VBAT Supply Voltage test failed, 2.23v is out of valid range normal |
It is the regulator IC faulty (normally this happens servicing a faulty mobile or a bad move using an UFC cable). You can ask details to PTT about which IC is to replace (if you want fix it - It would be the faster way to solve the problem) or contact your reseller for the box fixing or replacement. BR Alex |
@ ABDULLAHI MUHD Read the post "Box Selftest fail What to do" you find info about your problem in that post BR |
