I have problem Box Maintenance procedure started at 12:41:45 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.09, (Nov 7 2009 15:25:49), Type: Signed Production Application, Added Support for T=0 SmartCard Protocol Service Tag: 130F0E276FC9787A2AEB10872FD300FE Connecting to Cyclone Server Cyclone Server (1.0.0.563), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C00026D3 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D500003A First Name: Grzegorz Surname: Siciarek Nickname: greka Address: widok Country: Kalisz E-Mail: [email protected] Reseller: GPGIndustries, China Warranty Start Date: 2010-01-04 Warranty Period (months): 6 Warranty Stop Date: 2010-07-04 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode |
i try all on my cyclone box same error |
Check cristal oscillators. |
http://img705.imageshack.us/img705/580/xtals.jpg BR |
When I push by finger on both of them box is working ok :). how to fix? |
BR |
if you`re talking about the cristals, resolder doesn't help. I'll try to change them. Do I need to use only 12000MHz? |
Yes you need to use 12Mhz cristal BR |
Hi there I need help. I have same problem but with 32.768 MHz crystal. The box only change to main mode if I touch on this crystal. I tryed to link is cover to gnd but didn't work. Any ideas ? Thanks |
After change my box seems ok :), I will flash some phones and put the result here. |
Hi Cyclone team Please help to solve this box hardware problem. Thanks in advance |
Hi cyclone team No ideas about my problem with 32.768 MHz cristal (Y1) ? The box only change to main mode if I touch on this cristal with finger. I already changed the 3 cristals and tryed to link cristal (Y1) cover to gnd but didn't work. Only if I touch with finger on cristal (Y1) cover the box work fine. What I can do to solve this ? I'm waiting for your response. Thanks :confused: |
@ Zeittt Y1 is an 32Khz (32,768Khz) not 32Mhz.... Y2 & Y3 are 12Mhz BR |
