04-14-2009, 09:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | 6233 falsh error whit f-bus Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.6634 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application Box Serial Number: C0000156 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D10000AC Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.10v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Read certificates operation not possible for USB bus Backing up simlock... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [BB5 BootRom]: Found 1 active devices [Nokia USB Flashing Generic]: Opening Connection [Nokia USB Flashing Generic]: Port opened OK! CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! Failed to Process all Image files -> Failed to prepare BB5 USB Flashing Processing pre flash tasks... Read certificates operation not possible for USB bus Backing up simlock... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [BB5 BootRom]: Found 1 active devices [Nokia USB Flashing Generic]: Opening Connection [Nokia USB Flashing Generic]: Port opened OK! CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! Failed to Process all Image files -> Failed to prepare BB5 USB Flashing Processing pre flash tasks... Backing up certificates... Booting RAP... Failed to Read All Certificates -> RAP Not Responding Certificates backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm123_145_30005.600.mcusw (CMT)... Booting RAP... Processing Flash Image Failed -> RAP Not Responding Failed to Process all Image files -> Failed to process rm123_145_30005.600.mcusw Processing pre flash tasks... Backing up certificates... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found CMT NPC Not Found CMT HWC Not Found CMT CCC Not Found CMT R&D Not Found CMT VARIANT Not Found CMT PAPUBKEYS Not Found CMT KEYS Not Found Restarting MCU... Read all certificates finished Certificates backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm123_145_30005.600.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm123_145_30005.600.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0000FFFF, NOR EraseArea[0,CMT]: 0x00010000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x000A0000-0x0021FFFF, NOR EraseArea[0,CMT]: 0x00220000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR Waiting 320s for erasure finish... Erase taken 4.907s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm123_145_30005.600.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm123_145_30005.600.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm123_145_30005.600.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Internal Box VPP Enabled External CMT Phone VPP Enabled, Source: Box Internal 5V Warning: PAPUBKEYS Hash Missing! Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0000FFFF, NOR EraseArea[0,CMT]: 0x00010000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x000A0000-0x0021FFFF, NOR EraseArea[0,CMT]: 0x00220000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR Waiting 320s for erasure finish... Erase taken 4.235s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm123_145_30005.600.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm123_145_30005.600.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1C000109BCC100546639469864550C837588C41B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm123_145_30005.600.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 10 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0000FFFF, NOR EraseArea[0,CMT]: 0x00010000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x000A0000-0x0021FFFF, NOR EraseArea[0,CMT]: 0x00220000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR Waiting 320s for erasure finish... Erase taken 4.219s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm123_145_30005.600.mcusw SHERRY MOBILES Last edited by ptt; 01-16-2010 at 23:55. Reason: add code tag |
The Following 3 Users Say Thank You to oMeR_Rasheed For This Useful Post: |
04-14-2009, 10:32 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: nothing
Member: 494167 Status: Offline Thanks Meter: 292 | this is the hole story if you flash any phone bb5 or dct4 after flashing no ring tone no thems and no game in side the phone. |
The Following User Says Thank You to software zone For This Useful Post: |
04-14-2009, 11:34 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
The Following 4 Users Say Thank You to karwos For This Useful Post: |
04-14-2009, 13:11 | #5 (permalink) |
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | same phon same cable same file and phon is ok whit mt-box here is log please seee VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm123_145_30005.600.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg CMT Certificates Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0000FFFF] Erase RAP3 [00010000 - 0007FFFF] Erase RAP3 [000A0000 - 0021FFFF] Erase RAP3 [00220000 - 011DDFFF] Erase RAP3 [011DE000 - 011DEFFF] Erase RAP3 [011DF000 - 011DFFFF] Erase[17.75 MB]... Waiting response for 320 Sec...in 3.09s Flash[16.27 MB]...in 58.88s * * Processed file in 69.34 seconds Processing File: rm123_145_30005.60.image_w Low level format...OK Content area page size is 128K. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [016E0000 - 01E7FFFF] Erase RAP3 [01E80000 - 01FDFFFF] Erase[9.00 MB]... Waiting response for 320 Sec...in 46.47s Flash[2.06 MB]...in 8.84s * * Processed file in 70.02 seconds Extract content...OK Processing File: rm123_145_3005.60.ppm_w Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [011E0000 - 016DFFFF] Erase[5.00 MB]... Waiting response for 320 Sec...in 20.45s Flash[4.64 MB]...in 16.27s * * Processed file in 43.73 seconds * * * Phone flashing done in 3:30 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 05.60/14-09-07/RM-145 (c) Nokia IMEI: 352749010454979 Factory Default Settings...OK Reset user code...Successfull, code is 12345 b.r sherry mobiles |
The Following User Says Thank You to oMeR_Rasheed For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
