cant flash n81 8gb @moulnisky please need help cant flash the phone,now is dead after stop at erasing process now phone dead and cant flash Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM179_20.0.056_prd.C00 Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM179_20.0.056_prd.C00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1170010AC46700525B262791CFDC86F2F513EE20 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 RM179_20.0.056_prd.C00, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 10 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND EraseArea[0,CMT]: 0x00B80000-0x05F7FFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.516s Writing all blocks... Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM179_20.0.056_prd.C00 please need help |
TX2 line problem, are you using the TX2 adapter ? Check cable, check ( redo ) solders in TX2 adapter, clean contacts in phone PCB. do an " Check Flashing Bus " to see if TX2 is working properly. BR |
