06-27-2009, 11:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | **PA_SL2 5800 Unlock Success** BB5 Unlock Started... MCU Version V ICPR72_08w47.1 MCU Date 23-01-09 Product RM-356 Manufacturer (c) Nokia IMEI 353205038992556 Mastercode 3110166342 Simlock Server SIMLOCK SERVER Simlock Key 2343000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23430F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 04F00001DC7400522DB45CE34F96FE90554839DF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 04F00001DC7400522DB45CE34F96FE90554839DF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... #pw+191570905332652+1# #pw+947564858442183+2# #pw+669477607334092+3# #pw+541348592864261+4# #pw+813633689275339+5# #pw+619349941167253+6# #pw+051835571038777+7# Sending NCK Code (Level 7).. NCK Accepted! Phone unlocked OK! MCU Version V ICPR72_08w47.1 MCU Date 23-01-09 Product RM-356 Manufacturer (c) Nokia IMEI 353205038992556 Mastercode 3110166342 Simlock Server SIMLOCK SERVER Simlock Key 2343000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23430F Simlock NCK #pw+051835571038777+7# Unlock finished! A Very Special thanks to CycloneBox for his Hard Work ...!! BR |
The Following 6 Users Say Thank You to ..::Angel::.. For This Useful Post: |
08-01-2009, 11:57 | #3 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | can anyone make a small video on how to unlock a 5800? need to know what to select and what not to select. tick tx2, tx2 in pin 3 or pin 1 or pin 10 skip or not skip how to bakcup sx4 auth yes or not some guide to help me better understand this box. I should buy another box and try to sell this to somebody else. |
08-01-2009, 12:02 | #4 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, i think no need video you can unlock this phone with UFC,GPG 8pin cable, aslo don't need adapter, cause its code calculating method ... its working perfect without any problem .. BR |
08-01-2009, 12:07 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | It is easy!. First thing be sure you are using the last version of the software and your firmware is updated (Software version 7828 and firmware 1.05) Connect the mobile, using the TX2 adapter (Yellow cable) to the service port of the box. As usual be sure you can have a stable local mode. For saffety make back-up PM and RPL from Phone. SX4 bypass must be NOT THICKED. Click on unlock when you get asked to calculate the NCK codes wait about 10 seconds for the mobile being in local mode.. if it is not, press power on on the mobile and wait about 5-6 seconds then click on yes.. Job done.. If for any reason the code get calculated but the mobile can't be found just input the codes manually via the mobile keyboard. BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
5800 unlock problem how to unlock it | doller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 06-19-2010 04:56 |
5800 unlock with MT Dejan ? | chimeto | Nokia Base Band 5 ( BB-5 ) | 1 | 02-28-2009 00:52 |
nokia 5800 unlock | Braycel | Universalbox | 5 | 11-27-2008 17:02 |
