06-21-2011, 12:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 42
Member: 45183 Status: Offline Thanks Meter: 474 | No Code E7 Phone Hash has been readed with Cyclone 1.15.. After no Code i read it with Fenix too and Hash was same.. Anyone know reason? |
06-21-2011, 12:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Starting from update released at 10th may IT IS NOT POSSIBLE TO READ BAD HASH WITH CYCLONE. Those who know how it works ... We simply use TOO MANY CHECKS, and solutoin is really perfectly implemented. How it could be, you got bf result after 1 hour afer reading ??? http://forum.gsmhosting.com/vbb/f528...olved-1293013/ The reason your code is not found is: 1) Drivers problem 2) GPU problem - overheat,etc 3) ... Just attach BF again. |
06-21-2011, 13:16 | #3 (permalink) |
Member: 45183 Status: Offline Thanks Meter: 474 | The previous Phone was in my Hands. The one which could not be done is from a Customer.. He read it with Cyclone, Fenix and ATF and all got same Hash. The Phone has run already twice You will say now check your Masks etc.. on ocl or golubev but there is no problem cause i get all the time codes out. |
06-21-2011, 14:10 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi Guys, doesn't matter what phone it is Just follow these 3 stupid rules and with oclhashcat lite you will always find the code a) all the gpu must be same model and same speed (You can use as well 5970 and 5870 but the gpu speed must be the same for all the gpus!!) b) The temperature of the cards must never go over 89 c°: after 89C° the voltage regulator starts to slow down the gpu speed and the missing sync as speed give you the code not found. c) don't use during the bruteforce any software like flash or similar as they use gpu resouces of the primary card and create again an out of sync. Follow these 3 rules and you wiull get always your code. BR Alex |
06-21-2011, 14:18 | #8 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 225076 Status: Offline Thanks Meter: 19 | @karabey hi bro i done E7 bf and get code successfully @karabey hi bro i done E7 bf and get code successfully with hackcat software i note one thing r u read log with cyclone ver 1.15 and i read log with the cyclone ver 1.62 box firmware ver #pw+794337861505452+1# #pw+472568210557025+2# #pw+413799898334432+3# #pw+803235546854381+4# #pw+561416059267101+5# #pw+451232483450533+6# #pw+544967226169313+7# best regards mr.anderson Last edited by mr.anderson; 06-21-2011 at 14:21. Reason: add words |
06-21-2011, 14:21 | #9 (permalink) |
Member: 45183 Status: Offline Thanks Meter: 474 | @winnitsa Could you please share IMEI+HASH+RESULT to verify that OCL has no problems. thanks @mr.anderson I did also other E7 Phones but this one will not. |
The Following User Says Thank You to karabey For This Useful Post: |
06-21-2011, 14:28 | #10 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Lol, Looks like the re-make of this thread http://forum.gsmhosting.com/vbb/f528...230-a-1280200/ BR Alex |
06-21-2011, 21:14 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | When cards gets really hot it may missed some codes, so it is better to have them as cool as possible and not overclock them if don't have appropiate cooling, luck. |
06-22-2011, 03:09 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | try the attached data on your system to check if its working.... code must be found at 93.97% (it will take around 20 minutes on a dual 5970...check temps to figure out your problem) |
06-22-2011, 06:48 | #15 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Quote:
How u doing Alex. Just to Add my own Experience for this of urs line (a) About the Model is no matter we can use ASUS ATI SFX any card and can Cross flash the FW and make them Same ..As long as they have Same Model Name.. About HEating up ..The Stock clock realy works well even on a High Temp Country like Pakistan..3-4 Ventilator Fans helps alot and a Good Air System in ur Casing .. Agree Never use any other Soft while BF ... Also dont install any Security System Antivirus Kinda Stuff on that PC just leave it as it is...Disable all non Needed Sources and Unload from RAM.. These help always ... Br. | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
