Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-23-2009, 13:25   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
*** Cyclone Box - Download - Installation - First Steps ***
(Updated 07.07.2010 - )
1. Download final installer from: http://www.**********/CycloneBoxInstaller.exe and Install it. While installing agree to install box drivers, etc.
2. Connect box to PC. PC should detect new device - "Cyclone Bootloader". Simply do automatic driver installation, till installer installed them in Win32 INF already.
3. Run Start -> Programs -> Cyclone Box -> Cyclone Box
At bottom, you should see "Connected [Bootloader Mode]". That means your box was detected by software, and you can proceed with box registration - needed step to activate your box.
4. Run Box Registration Wizard, click Prepare Box.
Select your reseller from list, and fill all needed data.
If you see "Box registration status: Registered OK" that means all passed ok. You can proceed with box activation.
5. Run Box Maintenance Wizard, and click Maintenance box. In 1-2 minutes your box will be initialized.
**** VERY IMPORTANT : During box upgrade, please DON'T disconnect your box, even if software may act as hang ! We use ciphering on few layers during upgrade, and if you have slower PC, decrypting RSA and other ciphers, may take quite more time !! And then, if you disconnect your box, it will not be upgraded. It is no problem, because it will not be damaged, but You will lose YOUR time and OURS time, asking for next update credit !!
6. Your box is registered and activated. Now your security card needs be initialized. To initialize security card, box needs be activated! Run Security Card Manager. Read your card, and click Fill Credits. Box should change its mode to Cyclone Box and Windows should install new drivers again (same steps as for Bootloader). On bottom of screen you should see "Connected [Main Mode]".
8. All is done. You can run DCT4/WD2/BB5 tool and check if necessary selftests will be passsed, so you can enjoy using your Cyclone Box One note: security card having 1000 credits at initialization. Each card operation tooks those credits, so after some time you need to reinitialize card (when counter reachs 0). This operation is of course free and realtime, using server.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.9912
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.45, (Jul  6 2010 19:20:51, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27
Box Serial Number: C0000005
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: D0000001
Card Firmware Revision: 0108
Card is activated
Box is activated
Started box selftests procedure
USB Voltage    4,99v    PASSED
MCU Voltage    3,30v    PASSED
Core Voltage    1,79v    PASSED
VBAT Voltage    0,01v    PASSED
VBAT Voltage    4,73v    PASSED
Box VPP disabled
VPP Voltage    0,02v    PASSED
Internal Box VPP Enabled
VPP Voltage    4,88v    PASSED
Box VPP disabled
VPP Voltage    0,00v    PASSED
External Box VPP Enabled
VPP Voltage    0,04v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Remember to check the Version of the software and the firmware of your Cyclone box
Enjoy your box!
Note : Mirror for installer and exe : Index of /downloads
The Following 238 Users Say Thank You to karwos For This Useful Post:
Old 03-24-2009, 04:05   #2 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Originally Posted by HONEY View Post
Hi,
Features & benefit you can read in other threads where the descriptions are.. also you can have a look at official web.
About why to buy or support, its a new box and for sure there will be support for years, I don't think there is anyone who can tell you what all it will support in year 2010 or 2011..
BR.
well said honey...they expect the product developer to predict their own future..
Old 03-24-2009, 04:05   #3 (permalink)
rk_grover77's Avatar
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
sorry double post.
The Following User Says Thank You to rk_grover77 For This Useful Post:
Old 03-24-2009, 06:58   #4 (permalink)
selective member algo bruteforce SL3
Mr.Ultimate's Avatar
Member: 665113
Sonork: 100.1583029
Thanks Meter: 1,165
I think support have missed my question (or maybe there is nothing to say - no advantages...?)
I will just repeat myself once again.
Please give us some good reasons why we should buy it? Most of us have plenty tools for nokia phones nowadays... I have 5 different tools that does all my needs for now... so whats so special with CycloneBox ?
(P.S. - Im one of the customers who is interested in your new product, so make a good comparison between your tool and others, advantages and disadvantages please...)
(PLEASE REPLY WITH AN ANSWER - NOT WITH AN EXCUSE AS U ARE TOO BUSY)
Old 03-24-2009, 19:53   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Nothing is missing. THe ppls which using this device should post their feedback about advantages or disadvantages, that is all.
The Following 2 Users Say Thank You to karwos For This Useful Post:
Old 03-24-2009, 22:06   #6 (permalink)
Member: 181405
Thanks Meter: 249
manual instalation cliclone box by OROBAS
Originally Posted by Cyclonebox View Post
1. Download final installer from http://www.***************/downloads/...xInstaller.exe
2. Install it. While installing agree to install box drivers, etc.
3. Connect box to PC. PC should detect new device - "Cyclone Bootloader". Simply do automatic driver installation, till installer installed them in Win32 INF already.
4. Run Start -> Programs -> Cyclone Box -> Cyclone Box
5. Run Box Registration Wizard, click Prepare Box.
6. Run Box Maintenance Wizard, and click Maintenance box. In 1-2 minutes your box will be initialized.
7. Your box is registered and activated. Now your security card needs be initialized. To initialize security card, box needs be activated! Run Security Card Manager. Read your card, and click Fill Credits. Box should change its mode to Cyclone Box and Windows should install new drivers again (same steps as for Bootloader). On bottom of screen you should see "Connected [Main Mode]".
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.6588
Initializing box...
Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
LINK Manual in Spanish full
http://www.4shared.com/file/94775835...spaol__2_.html
The Following 8 Users Say Thank You to hector bermudez For This Useful Post:
Old 03-26-2009, 01:48   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Originally Posted by hector bermudez View Post
Thanks for contribution
Old 03-26-2009, 07:39   #8 (permalink)
tims's Avatar
Member: 67367
Thanks Meter: 47
Hello cyclone box team...
I like your ads... But i'm not satisfied yet.
Can you give 5 reasons why we buy your box?
Old 03-27-2009, 10:31   #9 (permalink)
kikikokoki's Avatar
Member: 748785
Sonork: KIKO_GSM
Thanks Meter: 309
info good work team...........
Description :
Cyclone Box is a brand new tool for flashing and servicing of the latest Nokia BB5, DCT-L, DCT4, DCT4+ cell phones.
Features
* USB BUS powered only, current in idle is 55mA
* World's first flexible configurations via software. It can be used TX2 pin on any RJ48 output i/o pin.
* First in the world built-in 10 pin diagnostic service for measuring phone damages via: voltage, current, frequency, STI BUS
* High speed flasher, real BUS speed up to 10-11Mbit, using 2 data lines
* UFS/JAF compatible pinout
* Switchable VPP - externally or internally generated signal, high speed flashing/erasing
* Advanced self-testing system
* Supports both FLASHBUS and USB connections for Nokia phones
* Built-in secure smart-card
* Cyclone Box uses it's own Smart Card and FTDI drivers so there are no conflicts with other devices
* Free 100 ASK-RPL credits are included into Cyclone Box pack to perform RPL calculation for Nokia DCT4 and DCT4Plus. The user does not need to wait for ASK-RPL online calculation.
Supported models and features
DCT4
Features
* Flash software (upgrade/downgrade)
* Reset SP SIM locks
* Lock phone to any network
* IMEI repair for the latest models
* Flash Bluetooth
* Save user settings
* Full factory (UI) defaults
* Software upgrade defaults
* Reset user lock (security code)
Supported DCT4 models
1100, 1100, 1101, 1108, 1110, 1110, 1110i, 1112, 1112, 1112i, 1600, 1600, 2112, 2125i, 2126i, 2128i, 2255, 2300, 2300, 2355, 2600, 2600, 2650, 2651, 2652, 2760 Americas, 2760 Europe/Asia, 3100, 3105, 3108, 3120, 3120, 3125, 3128, 3129, 3152, 3155, 3155i, 3200, 3205, 3205i, 3220, 3220, 3230, 3300, 3300, 3320, 3321, 3360, 3361, 3510, 3510i, 3520, 3530, 3560, 3570, 3585, 3586, 3586i, 3587, 3587i, 3588i, 3589i, 3590, 3595, 3595i, 3600, 3620, 3650, 3660, 5070, 5070, 5100, 5140, 5140, 5140i, 6010, 6012, 6015, 6015i, 6016i, 6019i, 6020, 6020, 6021, 6030, 6030, 6050, 6060, 6060, 6061, 6070, 6070, 6080, 6080, 610, 6100, 6101, 6101, 6101, 6102, 6102, 6102, 6102, 6103, 6103, 6108, 6111, 6112, 6152, 6155, 6155i, 616, 6170, 6170, 6200, 6220, 6225, 6225i, 6230, 6230, 6230i, 6235, 6235i, 6236i, 6255, 6255i, 6256, 6256i, 6260, 6260, 6310, 6310i, 6340, 6340i, 6360, 6370, 6385, 6500, 6510, 6560, 6585, 6590, 6590i, 6600, 6610, 6610i, 6620, 6650, 6651, 6670, 6670, 6800, 6800, 6810, 6820, 6820, 6820i, 6822, 6822, 7200, 7210, 7250, 7250, 7260, 7270, 7270, 7280, 7280, 7360, 7380, 7600, 7610, 7610, 7620, 7650, 7700, 7710, 810, 8310, 8390, 8587, 8800, 8800 Sirocco Edition, 8801, 8910, 8910i, N-Gage, N-Gage QD
Supported DCT4+ models
1200, 1208, 1208b, 1650, 1650b, 1680c-2b Classic, 2310, 2610, 2610b, 2626, 2630 Americas, 2630 Europe/Asia, 2670h
All ASIC11 models supported
Nokia DCT-L
Features
* Unlock
* Set FAID
* IMEI repair
* Set UI defaults
Supported DCT-L models
9290, 9210, 9210i (communicator)
Nokia BB5
Features:
* USB high speed flash supported
* Easy RPL service for damaged phones
* SIM lock and IMEI rebuild to the factory state
* Set product code after flashing
* Reset/read user lock (security code)
Supported Nokia BB5 models:
3109 Classic, 3110 Classic, 3120 Classic, 3250, 3500 Classic, 3600 Slide, 3610 Fold, 5200 XpressMusic, 5200, 5220 XpressMusic, 5300 XpressMusic, 5310 XpressMusic, 5320 XpressMusic, 5500, 5500 Sport, 5610 XpressMusic, 5700 XpressMusic, 5710 XpressMusic, 6085, 6086, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Vodafone, 6125, 6126, 6131, 6131 NFC, 6133, 6135, 6136, 6151, 6210 Navigator, 6212 Classic, 6220 Classic, 6233, 6234, 6267, 6270, 6280, 6282, 6288, 6290, 6300, 6300i, 6301, 6500 Classic, 6500 Slide, 6555, 6555 Classic, 6556 Classic, 6600 Fold, 6600 Slide, 6630, 6631 (NM850iG), 6650 T-Mobile, 6680, 6681, 6682, 7310 Supernova, 7370, 7373, 7390, 7500 Prism, 7510 Supernova, 7610 Supernova, 7900 Prism, 8600 Luna, 8800 Arte, E50, E51, E60, E61, E61i, E62, E65, E66, E70, E71, E90 Communicator, N70, N71, N72, N73, N75, N76, N77, N78, N79, N80, N81 8GB,N82, N85, N90, N91, N92, N93, N93i, N95, N95 8GB, N95 NAM, N95 8GB NAM, N96
Package contains
# Cyclone Box - 1 pc.
# Cable adaptor - 1 pc.
# 100 ASK-RPL credits
Weight: 0.2kg
Available in Hong Kong stock
Buy now
Price 139 USD | Suggest your price
Old 03-27-2009, 19:56   #10 (permalink)
Member: 454648
Thanks Meter: 18
Why is this happening? Cyclone box team...
Box SN: XXXXXXX
Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box Maintenance Error -> '2009-03-27' is not a valid date
Old 03-27-2009, 20:28   #11 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Box SN: XXXXXXX
Please tell me your date/time zone
The Following User Says Thank You to karwos For This Useful Post:
Old 03-27-2009, 20:43   #12 (permalink)
Member: 454648
Thanks Meter: 18
27 - March - 2009
Colombia
Hour 14:41
GMT-05:00
Help please Mr Cyclone Team.
Old 03-27-2009, 20:59   #13 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
27 - March - 2009
Colombia
Hour 14:41
GMT-05:00
Send me your SERVICE TAG @ PM
Old 03-27-2009, 21:02   #14 (permalink)
Member: 454648
Thanks Meter: 18
Send to private messaging
Thank you very much for your help.
Old 03-27-2009, 21:04   #15 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Excuse me, do you mean?
Use private messaging.
And send me "SERVICE TAG". You can see it during box upgrade.
MANUAL: FIRST StEPS WITH CYCLONE BOX Hell-GSM Cyclonebox 18 08-12-2012 17:51
Cyclone box not instaled CHERIFA Cyclonebox 15 07-02-2009 21:33
6263 Tmobile U.S.A need to flash please help! Team Cyclone box is my first time flash mymiela0419 Cyclonebox 3 05-21-2009 11:28
Welcome cyclone box india + world first vodafone india strom unlock ready chiragp Main Sales Section 0 03-31-2009 07:13
Page generated in 0.34307 seconds with 9 queries
