VBAT Supply Voltage test failed USB Voltage 5,09v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,80v PASSED VBAT Voltage 0,01v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 0,03v is out of valid range How to solve the ah? Help! :(:( |
Hi, conect an F-bus cable or Unifbus, and check with a multimeter if you have voltaje at battery terminals, if dont, contact your reseller for exchange the box... BR |
how can I install on another computer cyclone how do I cyclone installed on another computer? I'm trying and I say this: Nokia Service Tool Initialization Started DCT4/WD2/BB5, Engine Revision: 1.0.0.7880 Open Box Error -> Security Problem # 5 Initialization has failed -> No connection was established, or box mode is not in needed |
1- UNINSTALL CYCLONE (from add/remove programs) 2- DELETE C:\PROGRAM FILES\CYCLONE BOX FOLDER 3- INSTALL INSTALLER (CHECK ON 1ST POST OF THIS TOPIC) 4- APPLY BULK UPDATE That's all |
Hi sir i buy cclone box to day. How to repair imei ?????? wd2 (6600) i already use my credit. And i got nothing. Box said "failed with bootloader" Whats mean? Thanks. Urgent... |
What mean the given messages? 1. Ticket received, Veryfing it... Authenthication error -> Socket Error # 11004 2. Cyclone Server Send Command Error -> Code: 500, Box is not registered, support is not allowed then Authenthication error -> Failed to obtain Authenthication Data |
Forgive for my English |
dear Mr cyclone box , my cyclone box met problem , cause i can not uploading the image ,so i write what it say : Nokia DCT4/WD2/885 service Tool Initialization started. Engine Revision:1 .0.07396 Handling device.{cyclone team},{cyclone boothloader} Initialization has failed -> No connection was established.or box is not in needed mode . these are words when i use cyclone ,it shows to me . what is the problem of this cyclone ? is it the quality problem ? cause i am new user ,so i dont know how to deal with it . hope you can teach me how to solve this problem cause it really make me crazy . thank you very much! best wishes Osmart |
i brought 5 pcs cyclone box in one time ,the other 4 very goods ,only this one met such problem, is it the quality problem of this cyclone box ? what should i do so that i can solve it ? thank you very much ! |
Try to update again the firmware of your box from box maintance; if you can't, PM the serial number of your box to Siroya so he can put it in needed mode on the server to update again the firmware. BR Alex |
alex ,is that the problem of box mainboard ? somebody said that is the problem of box board . |
If was a problem of board you couldn't neither see the box in bootloader mode...:) in your issue is only the firmware to update again from box maintance. Just have alook at the sticky thread http://forum.gsmhosting.com/vbb/showthread.php?t=797559 BR Alex |
thank you very much dear Alex |
you are wellcome :) BR Alex |
i cant install cyclone setup(corup..).. plzz up.new link for me..thk cyclone team |
