06-26-2012, 20:48 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | Help for flashing n70 [ Solved ] cable is good. i am using yellow adaptador. here is log flashing Code: Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0052B2E9, NOR EraseArea[0,CMT]: 0x006A0000-0x006BFFFF, NOR EraseArea[0,CMT]: 0x006DF000-0x006EFFFF, NOR EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR Waiting 320s for erasure finish... Erase taken 1.422s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM84_50638301.C0 here is chek fbus flashing Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: AC9C7319171EB5ACCA237844CC47552E9732458A APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 06000203889D5D51DCC79AC6DEAF3146273E2E63 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
