cyclone & nokia 2760 & nokia 6030, dont detectĦĦĦ Hi , please if somethign can helpme to unlock these phones with cyclone box, i was instaled a file named: RM-225_0525_6030b.exe but nothing thanks |
do u need to unlock ur 6030b ? u can unlock it without file just click unlock button.. post some results Br, |
GO to DCT4 tab / Security tick Old Asics Method click direct unlock |
the cyclone is update the phone on but i can detect the phone .... |
Use JAF nokia cable click check bus phone will go to local mode after successfully check bus then make unlock |
the box dont detect the phones: nokia 2760 and nokia 6030 i am using new cables of ipmart. some solution please because i have 40 phones to unlock thanks |
cyclone & nokia 2760 & nokia 6030, dont detectĦĦĦ i have a lot of nokia 2760 & nokia 6030 to unlock or flash but cyclone cant detect the phones.. i am using ipmart cables compatibles with the models i dont know to do.. P.D: i unlock with the same box and options a lot of nokia 2600c ( 16 pieces), with nokia 2600c i dont have troubles... thanks |
If the Box & Software was able to unlock other DCT4 phone, that means the Box & Software are OK, you should check your cables... Make sure that your cables have UFS/JAF pinout What you get if you do a "Check Flashing Bus" ? |
hola, i get this: Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding |
Are you using the latest Cyclone Software version ? is your Box FW up to date ? When you connect the Phone to the Box, is it going to "Local mode" ? |
One question, do you attach phone to SERVICE PORT? Also, is it powered on (LOCAL MODE) on display? |
i was used the box wizard and is update when i connect the phone to the box, not happen nothing and cant detect the phone. Quote:
yes i attach the phone to SERVICE PORT, not display nothing in the display. i have eset antivirus.. but with the nokia 2300 i dont have any problems i can unlock and flash lot of nokias 2300 thanks |
If the Nokia 2300 can be serviced OK, then is NOT the BOx or The Software Check the nokia 2760 and nokia 6030 Cables |
