E65 After write Full PM Contact Retailer How to Fix @nadeem my friend How can i fix my problem, i write a Full PM to my E65 and it went to Contact Retailer. 1st the problem is when i turn on the phone only nokia but with out sim card its ok, i try to write pm and it went to Contact Retailer, how can i restore it back to normal? Thanks in advance |
do you have back up of your pm????? try to put it back |
maybe it over write your original PM DATA... u must restore it back... to be safe, make a "SELF TEST".. then post your logs... |
did u write PM without 120 & 308 field or full PM from another phone? |
Yup it's modified PM but still contact retailer, but i will restore the RPL file i backup and i will post the logs here, i try to use selftest and st security is the error, you think guys i can restore it back using the RPL i've backup? |
1 Attachment(s) Quote:
post here phone self test after writing PM |
The phone was already on nokia logo.. Normally this happens after a wrong upgrade/downgrade of the phone. Make the self-test of the mobile and check what is wrong.. look at the infos as well. If everything looks OK then go on with the full job. Make all the back-ups you can then full erase, emo, flash, rpl, sx4, full PM no 308.. if it keeps being in CS then you need to buy RPL. BR Alex |
How can i full erase? Procedure please What do you mean by EMO? |
ENO not EMO is a special firmware with the lowest version, it does not start the phone and it is just for the preparation. Post the selftest as required above |
I have exact Prblm. on E65 Ver. V 1.0615.25. APE s/w. not matched with MCU s/w. I try different versions ,I think onyway is to go back to Previous Ver. |
