02-07-2010, 11:30 | #1 (permalink) |
Junior Member Join Date: Feb 2008 Location: phillipines
Member: 699396 Status: Offline Thanks Meter: 2 | how to unlock n96 V30.333 I TRY TO UNLOCK THE PHONE IN NCK CALC. (NEW METHOD) BUT I GOT ERROR HERE'S THE LOGS: nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8340 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.16, (Jan 25 2010 02:27:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: xxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: xxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.94v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.81v PASSED VBAT Voltage 1.17v PASSED VBAT Voltage 4.70v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work BB5 Unlock Started... MCU Version V ICPR72_09w13.2 MCU Date 19-05-09 Product RM-247 Manufacturer (c) Nokia IMEI 354863024542832 Mastercode 72770435 Simlock Server SIMLOCK SERVER Simlock Key 5150300000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 51503F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 51503F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 008815D3 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 05F508D2D78505731D192BB0D03A4336AE30EFD1 APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35 APE_BOOT_ROM_CRC: 137A9A3B APE_SECURE_ROM_CRC: 33259D2C CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1960000C8A720052E518C57152CD749162578140 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0020880400006B21, ST, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: AD7799ABC45695918C0B8E955FAD5FF12650E6AE APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) Booting RAP... APE_SYSTEM_ASIC_ID: 008815D3 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 05F508D2D78505731D192BB0D03A4336AE30EFD1 APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35 APE_BOOT_ROM_CRC: 137A9A3B APE_SECURE_ROM_CRC: 33259D2C CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1960000C8A720052E518C57152CD749162578140 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... BB5 Unlock Failed -> Failed to Read NCK Codes, Possibly: 1) Your PM308 is damaged (subblock DEAD0400), 2) Decryption not running (new rom?), 3) Cyclone Box Firmware is not upgraded! (must be >= v01.16) TIA...... |
02-07-2010, 12:45 | #5 (permalink) |
No Life Poster Join Date: Jun 2008 Location: ****** Age: 45
Member: 801286 Status: Offline Sonork: [email protected] Thanks Meter: 54 | its free but you needed 101 credit |
The Following User Says Thank You to nokia-ps For This Useful Post: |
02-07-2010, 12:46 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You will need 101 credits in your balance but they won't be used BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
02-07-2010, 13:45 | #7 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Palestine - Nublus
Member: 431775 Status: Offline Thanks Meter: 94 | yes i was try unlock on rpl its only 5 min to unlock mobile or u can use old way there not save and very hard its try its talk about 3 hours to unlock it |
02-07-2010, 23:34 | #8 (permalink) |
Junior Member Join Date: Jan 2008
Member: 684278 Status: Offline Thanks Meter: 1 | nokia 5800, n96, e63... v30 and v31 can be unlocked with NCK, but it s long process with downgrade and upgrad....etc easiest way is to use RPL method that calculats SIM Lock rpl and unlock your phone changing provider to 24407 status OPEN it s Server based so, internet conection needed BR, |
How to unlock n96 rm505 | drjaved_akhter | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-15-2010 12:23 |
how to unlock n96.n85.5800 | abuiesa | Nokia Base Band 5 ( BB-5 ) | 81 | 10-11-2009 00:44 |
How to unlock N96 | esaboy | Cyclonebox | 3 | 09-14-2009 07:47 |
how to unlock n96 with UB | smarty3399 | Universalbox | 4 | 07-01-2009 23:47 |
plz any budy help how to unlocked n96 and 95 8bg | shahzeb | Cyclonebox | 2 | 05-03-2009 19:16 |
