How to Wright Backup RPL BB5 7210c Help How to Wright Backup RPL BB5 7210c Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.03, (May 1 2009 17:13:05, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0000218 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000042 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.10v PASSED VBAT Voltage 4.75v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.02v is out of valid range Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2A70010456CD5850C957E344A6FECB1F6C25472A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 APE Subsystem Not Found Restarting MCU... Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2A70010456CD5850C957E344A6FECB1F6C25472A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 APE Subsystem Not Found Restarting MCU... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2A70010456CD5850C957E344A6FECB1F6C25472A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 APE Subsystem Not Found Restarting MCU... Write RPL Finished! but not wright 123456..........? Plz Help Me Here is My Backep RPL http://www.4shared.com/file/11385786...0_120_120.html |
sory u cant do bcoz sl3 cant support |
next time don't post your serial number and what problem u have????? b.r sherry mobiles |
better if u use mt use 10 pin cable only after writing backup if imei does not appear downgrade handset to some lower version wbr |
have you try with Yellow adapter of cyclone ? you must need TX2 for witing npc,cmt .... BR;) |
no...... all you need to do is go to stored files folder inside cyclone(c:/program files/cyclone box/stored files) and click "write rpl" use that back up and use cyclone adapter......... i encountered that same problem twice.... and that is all i do and it works all the time.... no need to edit the rpl or logs:) |
The rpl you have is only about the SP data.. is ok only to rebuid the security. To have back your imei you need or the PM308 or a full rpl.. Did you get the error with cyclone (and if yes in which operation) or you got the mobile in this mode? BR Alex |
As our friend, moulnisky said: Provided RPL file have only Simlock data, flashbus part is completly empty, so yuou can't repair your imei, you need to obtain full RPL file from Nokia itself (ask your reseller) |
Is Cyclone rpl backup is full rpl? how to make backup of full rpl from cyclone? |
Using the function read rpl from phone.. BR Alex |
