04-22-2011, 22:38 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | N91-1 Imei 123456... after flash [ Solved ] |
04-22-2011, 23:18 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | Do a "Check Flashing Bus" and take note of your phone "CMT_PUBLIC_ID" and look in your "Stored Files Folder" for the "NPC.CMT.CRT" bakup ( that is automatically created ) related to your phone "CMT_PUBLIC_ID", restore it and you will have the IMEI back.... BR |
The Following User Says Thank You to ptt For This Useful Post: |
04-23-2011, 12:58 | #6 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Yes, use the "write certs", the file (cert ) that you must write to the phone is the xxxxxxxxxx.NPC.CMT.crt ( where the xxxxx is the CMT_PUBLIC_ID of the phone ). and use the TX2 adapter BR |
The Following 2 Users Say Thank You to ptt For This Useful Post: |
04-23-2011, 21:29 | #8 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | To be honest, never seen this model here. Please post the Logs of the operations that you done to the phone. ( the unlock, the cert write, also a check flashing bus ) BR |
04-23-2011, 21:45 | #9 (permalink) | |||
Member: 517318 Status: Offline Thanks Meter: 88 | N91-1 Imei 123456... after flash Quote:
04-23-2011, 22:51 | #10 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | My friend are tho variants of N91-1 with 4g and with 8g. You write higher variant with 8 g on your 4g phone. Be sure you backup rpl,pm and simlock for your phone after that must full erase your phone and write lower firmware you find because papubkeys are different and dont let you write the rpl even you have save it. After full flash write back pm,rpl and simlock and will be ok. BR. |
The Following User Says Thank You to danrachita For This Useful Post: |
04-24-2011, 12:47 | #11 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Quote:
1 - I backup the phone, PM, RPL, Cert. 2 - Flashing with a 8G version. 3 - Erase phone 4 - Flash with version lower than 4g 5 - I write the backup They? please can tell me the correct procedure for the erase, I flash using Old Protocol loaders ? | |
04-24-2011, 12:55 | #12 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | Just make all backups,erase phone with erase file or any other way doesnt matter,flash phone with 4g version and write back all backups. That is all. BR. |
04-24-2011, 13:02 | #13 (permalink) | |
The file that I use to erase is this BB5Erase_8MBrap.bin or should be someone else? I have no backup of the phone when it worked well, I do now as this? Sorry for my English, I am using a translator, I speak Spanish | |
04-24-2011, 13:10 | #14 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | I hope Cyclone make backups as i know.Check in backup folder in Cyclone software and copy all backups with name like imei from phone label in a safe location just to be sure. If dont have backups of rpl is bad and you need to buy rpl for this phone. I think the erase file are ok. BR. |
04-24-2011, 20:06 | #15 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | My friend i hope you solve the phone. If no let me know to upload correct flash files and full pm if help you. I have that phone and i use it now. BR. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
