Nokia 500 flashing problem Hi I try flashing Nokia 500 using Fbus cable: Code:
via UBS flashing is good (sometimes is hardly to connect phone but generaly flashing ok) is Nokia 500 Fbus flashing supported? Thanx |
Fbus Supported But Must Attach Yellow Adapter & Check Software Settings. BR. Arsalan gsm2000. |
It's cable problem.l.use good Fbus cable |
i use yellow adapter tx2 enabled in software cable have good connect with all fbus pins on phone, vbat, gnd and bsi inside cable are 2 resistors too 2 Mbus pins joined together what else i must do for flashing start? |
Don't bother, nokia 500 & 700 you can't flash them using fbus cable with cyclone. You can't even do a check flashing bus. Only usb connection possible for now, tested by me. Luckily we can do all operations via usb (i think, but not tested 100%). BR Renegade |
@renegade i see you allready tried and understand problem, thanx but why support still dont answer? if fbus works, please post log or say "dont supports" :rolleyes: |
